G Gallagher
Vessel Name: Reel Salty
Posted: Wed Sep 21, 2011 11:40 pm Post subject: Fuse in the dashboard bilge switch? |
I have a2 2 ft cruiser- 2002-
I have a question. I am replacing my bilge pump. Problem is the new one does not work- checked wires for continuity and it leads back to the bilge switch that was factory installed. I think that it probably contains a fuse
I am afraid to pry to hard and screw it all up.
Can anyone give me a little guidence or encouragement on this?
Gary Gallagher |
Alyssa Jean
Joined: 02 Nov 2003 Posts: 2376 City/Region: Guemes Is.(Anacortes)
Vessel Name: Alyssa Jean
Posted: Thu Sep 22, 2011 12:06 am Post subject: |
I doubt that the switch itself has a built in fuse. Is there a circuit breaker button next to the switch? Or possible the switch is bad. _________________ David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51 |
G Gallagher
Posted: Thu Sep 22, 2011 12:19 am Post subject: |
No, there is no fuse or circuit breaker near the switch. Maybe the switch is bad!. However, I am not applying enough pressure to remove the back of the switch.I'm afraid that I will shatter the back of the switch,only to finally realize that I am missing a fuse somewhere else. I'll keep on looking.
Gary |
Dreamer
Joined: 01 Jan 2006 Posts: 1766 City/Region: Really Sunny SaddleBrooke
Photos: Dreamer
Posted: Thu Sep 22, 2011 1:14 am Post subject: |
If the switch looks like this or is similar to it, No, there is no fuse in it. Don't pry it apart. They don't go back together well.
Use a voltmeter to diagnose power to the pump circuit. _________________ Roger
Dreamer- Sold 25 Feb. 2013 |
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
Posted: Thu Sep 22, 2011 1:16 am Post subject: |
Doesn't the bilge have an always on connection for automatic operation and a switched connection for manual override? You checked continuity, but do you have a voltmeter to check if you're getting any power? |
Joined: 07 Nov 2003 Posts: 7932 City/Region: marysville
Posted: Thu Sep 22, 2011 1:42 am Post subject: |
I have had seveal pumps not work right out of the box. test the pump on a battery first to see if it is good. Then test the power to the wires to see if you have power. if not trace the wires back to the switch and the battery to see if there is a fuse. sucks tracing wires but you have to do it. I had to remove a fuel tank on a buddies jet sled to find a fuse for a light. not fun _________________ Thomas J Elliott
cbgale
Vessel Name: Raton
Posted: Thu Sep 22, 2011 8:14 am Post subject: |
If installed correctly, it was installed as a seperate circuit, and there should be a fuse close to the battery, positive wire. Trace the positive wire from the pump to the battery. |
Posted: Thu Sep 22, 2011 11:32 am Post subject: |
It may be a 3 position switch. OFF in the middle, AUTO on one position (when the creek rises ) and ON for a manual on all the time.
Let us know what sort you have.
K4KBA |
ferret30
Photos: Lily Pad
Posted: Thu Sep 22, 2011 12:21 pm Post subject: |
Mine's a 2006 so it could be very different, but my switch at the helm only has auto and on settings, no off. I'm kind of glad because I'd hate to ever bump it and turn it off by accident! |
dotnmarty
Joined: 03 Nov 2003 Posts: 4209 City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
Posted: Thu Sep 22, 2011 12:22 pm Post subject: |
cbgale wrote: | If installed correctly, it was installed as a seperate circuit, and there should be a fuse close to the battery, positive wire. Trace the positive wire from the pump to the battery. |
Our boats had one of these hanging off the positive terminal on one of the batteries. It was there, I guess, to keep the bilge pump cycling properly when the boat is in the water and the batteries are off. I used to remove the fuse when the boat was on the trailer and the plug was out.. _________________ MartyP
BrentB
Joined: 15 Jul 2006 Posts: 4420 City/Region: Greenwood
State or Province: IN
Photos: BrentB
Posted: Thu Sep 22, 2011 3:55 pm Post subject: |
I agree with Marty.
If wired directly to the battery, check if an inline fuse is present.
Second check each wire connector for flaws (not waterproof, heat sealed, use automotive connector instead of marine) or a corroded wire at the connector.
Post an update.
These problems are not always straightforward to resolve
m2cw _________________ Brent Barrett |
Posted: Thu Sep 22, 2011 5:01 pm Post subject: |
I'm not sure what bilge pump you're using for a replacement, but here are a few comments.
First, the Rule-Mate pump I bought to replace the original model had a electronic float switch, which will not work in oil. It had a separate test switch, which one pushes and holds. No idea how it "tests" the circuit.
Second, if you have a Rule-Mate exactly like the one which came with the boat, it has an internal float switch, so that one has to either manually push the float up or stick it in a bucket of water, or flood the hull. Your choice.
Third, both pump types (and others) come with 3 wires: one for return, one for manual operation, and one for emergency operation. The first, which is black, goes to the battery ground. The second, which is brown is the one which goes directly to the battery for automatic operation, via a fuse. The third goes to the DC panel switch for manual operation. The panel switch has a breaker incorporated next to it, the white button. Please check to make sure you're wiring and mine are the same. You should see what the wires are doing and going with a voltmeter.
I don't trust automatic thingies in emergencies, especially those hecho en Mexico, so I bought a pump which uses an external float switch and installed pump and float switch in place of the Rule-Mate pump. This pump came with the three wires as discussed above, and works great.
Bon appetit, Boris |
G Gallagher
Posted: Sat Sep 24, 2011 11:21 pm Post subject: |
OK, Thanks for all the info and help. I found it.!!! There is a fuse about 10-12 inches from the positive terminal of the battery.
My problem was that my red wire which was hard to see and trace became an orange wire of larger guage, that contained the blown fuse. I overlooked it several times , before seeing the change.
Again, many thanks for ll the help.
Gary |
Joined: 02 Nov 2003 Posts: 21378 City/Region: Pensacola
Posted: Sun Sep 25, 2011 1:40 pm Post subject: |
Now that you have traced the bilge pump wire, and most likely several others, use a labeler and out and ID on each wire--preferably on each end of the wire, and each place where you an see it. _________________ Bob Austin
G Gallagher
Posted: Sun Sep 25, 2011 7:28 pm Post subject: |
Bob,
What a great idea. I'll do it.
Gary |
