C-curity System
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Mon Mar 07, 2005 9:33 am    Post subject: C-curity System Reply with quote
Hi all, Recently, C-Dog Fishwisher was the victim of a damaging break-in http://groups.msn.com/FishWishersHomePage/2500reward.msnw . As a result of his misfortune I resolved to research a security system for Adeline. As she is safely secured @ my home, this is intended as marina security. This thread is intended as a starting point and I hope others will add their thoughts.
1st, we presume that your boat has a 12 volt battery / charging system,
possibly supplied by your motor / engine. You need to have a constant 12
volt source for any alarm system to operate.
2nd, the DEI Merlin 2000 sports alarm is designed for many different uses
when moisture is a big factor.
Merlin 2000 alarm http://www.caraudio-caralarms.com/merlin2000.html
It is the only alarm system in DEI's large selection of alarm systems that
has the two following characteristics...
* Water Resistant CPU (the brain)
* Waterproof remotes
DEI 470T
Remotes http://www.caraudio-caralarms.com/remote_transmitters/470t.html
From our years of experience, the Merlin 2000 is the # 1 choice for your
boat, and we do not have any # 2 recommendation.
You will probably want to turn the built-in shock sensor to its lowest
(almost off) setting, as the boat in mooring, bumping against anything
would set off the alarm. If it is supported entirely by lines, and cannot
hit a bumper, then you may be able to have the shock sensor set to some
appropriate level to detect intrusion.
3rd, you can certainly use a magnetic separation switch on the cabin door,
as long as you have a place to mount it on the door frame and door
opening. Probably the DEI 8600 pre-wires switch would work best.
DEI 8600 Magnetic switch http://www.caraudio-caralarms.com/8600.html
4th, the Merlin comes with a waterproof key-switch siren. See page 14 in
the Install Guide below. You want it to be installed outside the cabin so
it can be heard. Under the roof overhang near the cabin door would be one
suggested possible location.
Merlin Owners
Guide http://www.directechs.com/guides/manuals/og/merlin/122M.pdf
Merlin Install
Guide http://www.directechs.com/guides/manuals/ig/merlin/N122M.pdf
5th, As your boat does not have the normal "chassis ground" of an
automobile or sports vehicle, you will need to run a ground wire to the
various components from the boat's battery.
6th, you can also add a DEI 508D Perimeter Sensor to the system to trigger
the alarm before someone enters the cabin, and it would provide protection
to the stern area.
DEI 508D http://www.caraudio-caralarms.com/508D.html
We suggest that you could mount it inside the glass on the cabin door,
probably up near the top, facing out toward the motor. We would give you
more information if you are interested in this.
7th, you could also add the DEI 520T Back Up Battery to the system.
DEI 520T http://www.caraudio-caralarms.com/520T.html
If your battery and connections are near the motor, and possibly accessible
to disconnect or cut the battery cable, then putting a DEI 520T inside the
cabin in the 12 volt supply line assures the Merlin 2000 will have
poser. It would also trigger the alarm if power is lost.
8th, yes, you can add the DEI 795W pager system.
DEI 795W Pager http://www.caraudio-caralarms.com/795W.html
9th, DEI has just recently discontinued manufacture of the DEI 793T Pager
Strip antenna and does not have any know plans for a replacement part. The
DEI 795W pager was designed to use a vehicle's radio antenna, or the 793T
pager strip antenna. You may have to use a car radio antenna with the 795W
pager.
Here's a summary of the above information that you can select from.
DEI Merlin 2000 Alarm $95.00
DEI 8600 magnetic switch $7.00
DEI 508D Permitter Sensor $41.00
DEI 520 Back Up Battery $31.00
DEI 795W Pager $112.00
Let me know if you have any questions.
Thanks for your business!
Doug,
Auto Preservers
_____________________________________
At 04:14 PM 03/06/2005, you wrote:
>Please recommend items for my boat . I would like a system that will
>detect an entry through the door, sound an alarm, and page me. These are
>all the features I need. I believe I will require a module connected to a
>magnetic seperation switch, a siren, a strip antenna, and a pager. Please
>e-mail part #s so I may order online.
AUTO PRESERVERS ~ The Car Alarm Experts since 1980
"We're Committed To Your Safety And Security"
6724 Perimeter Loop Road - #142, Dublin, OH 43017-3202
Phone (614) 264-1586, FAX (614) 791-0389
e-mail: autopreservers@wowway.com
Web site www.autopreservers.com
Web site: www.caraudio-caralarms.com
Pete
Salty Dog
City/Region: Traverse City
Photos: Salty Dog
PostPosted: Mon Mar 07, 2005 9:59 am    Post subject: Reply with quote
Adeline,
Great thread to start. I noticed that the company you contacted is in Dublin, Ohio. Just so happens, this company is only about 4 miles from my office, so if anybody needs any more info than what is on the website/brochures, etc., I can always try to swing by and talk to them directly and get any measurements of anything. Just send me a PM or e-mail and I'll see what I can find out for you.
Jack
C-WEED
City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Sat Mar 26, 2005 11:06 am    Post subject: Reply with quote
FreighterGazer: That address caught my eye. I grew up on Sawmill road in Dublin. Just South of Ohio State University airport. Don Scott field in the old days. Brother-in -law and sister both work at Honda. Things really went south when Jack Nicholas built the big golf course. About 1979 at midnight I rode in a friends factory (Just like Smokey and the bandit)79 Trans Am. A Columbus policman had ordered it thru Hadocy pontiac with all options and declined it. So my friends parents bought it for him. As I clung for dear life we headed out route 33 towards Marysville at midnight. I watched as the speedo that went to 100 get wraped around to 45 and stopped. But the tach continued to climb. To demo the 4 wheel disk brakes he locked em up at 100 mph until we stopped. The cloud of stinkin tire smoke cought up to us about 10 seconds later. Then demo'd the posi-trac as (pinned in my seat) we emediatlly luanched back up to 100 mph. I have never ridden in a car that was so quick off the line and had unlimited top end. Right from the factory. Amazing. I never rode in that car again. He spun the main bearings at 8000 miles. Before that car he had the exact 1977 Starsky and Hutch Ford Grand Torino. With a flashing red light people really do pull over...
But that is a whole nuther story.
Back to on topic: Nothing yet for the CD other than to leave the door unlocked while in the yard. That way they won't break down the door as they steal my outdated GPS.
Poor mans anti-theft for tow vehicle: For the big sum of about $2 I always wire up a micro switch to the safety switch that is already on the clutch peddle. For an automatic trans I wire it to the safety switch that tells the vehicle to be in park or nuetral. Either way the vehicle won't crank until you hold in the momentary micro-switch. I usually place it around the parking brake release on the truck just under the dash lip. Nobody ever notices that I push the switch to start. I even showed my dad where the switch is hidden and he can't start it. (Switch is smaller than a pencil eraser). If somebody else wants to drive it, I have a wire with two alligator clips. Just bridge the connection under the dash and truck starts as normal. Most car jackings are in gas stations or intersections. Sure buddy steal my truck. The keys are in it! Mr. Green Like the owner this device is cheap and always armed and ready.
Luck to be alive...
Chris
Adeline
Photos: Adeline
PostPosted: Tue Apr 12, 2005 3:48 pm    Post subject: Reply with quote
Hi all, I found a system that MAY work. I'll keep ya posted. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5766704928&rd=1&sspagename=STRK%3AMEWA%3AIT
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Tue Apr 12, 2005 8:18 pm    Post subject: Reply with quote
For an EBayer that person sure has a marginal feedback history. 27 negatives in the last month! I would be VERY careful buying from them.
Gary Johnson
KB7NFG
PostPosted: Tue Apr 12, 2005 8:26 pm    Post subject: Reply with quote
Using 27Mhz to transmit on, the range won't be very great so, unless you're quite close to your boat, you won't hear the page. If you could use the phone lines Phone , it'd be a lot more reliable. Might be better to buy a Rottweiler and throw food into the boat once a day and muck it out once a week! Cry
M1911
City/Region: Framingham, MA
PostPosted: Tue Apr 12, 2005 9:00 pm    Post subject: Reply with quote
The first car I bought was a '78 Trans Am with the high output 6.6 liter V8, 4spd manual, positraction rear end. It sure seemed fast at the time. IIRC, about 220 HP and 320 ft-lbs of torque. 0-60 was about 7.5 seconds. The best mileage I got was 18 mpg. The worst was 11.
I now own a 2003 4Runner with a 4.7 liter V8, 4WD, and 5 spd automatic transmission. hp and torque ratings are almost identical to my old Trans Am. The 0-60 time is just about identical as well. But the mileage is significantly better (about 19 mpg on highway, 17 mpg in mixed city/highway), plus I've got 4WD and lots more room.
The 78-79 Trans Am may have seemed fast in its day, but it's nothing compared to what you can get now. Check out the new Mustang GT. 0 to 60 in around 5.5 seconds and price is less than $30k.
Page generation time: 0.0393s (PHP: 66% - SQL: 34%) - SQL queries: 20 - GZIP disabled - Debug on
