Les Lampman Dealer
Joined: 30 Oct 2003 Posts: 779 City/Region: Whidbey Island
Posted: Sat Aug 13, 2011 5:21 pm Post subject: Mascoat Delta-T thermal insulation coating... |
Mascoat Delta-T thermal insulation coating is now a standard item on Marinaut boats.
We decided to use Delta-T on the entire boat. The hull below the floor pan (which is one piece from bow to stern) is sprayed and so is the underside of the floor pan so that the "bilge" space is fully insulated. We wanted to control whatever condensation occurs and to help in the reduction of sound levels (they weren't obtrusive before but quieter is better).
The whole structure above the floor pan (including the transom area, under side decks, cockpit sides, etc) is coated with the v-berth and cabin area receiving extra coats.
Also, the hull sides, cabin sides, and cabin front all now have a coring of 6mm Soric material which adds strength and adds (a bit) of insulation for temps and sound. Mostly it was done for strength and quality but every little bit with regard to thermal and sound insulation helps. _________________ Les
www.marinautboats.com |
Aurelia
Photos: Aurelia
Posted: Sat Aug 13, 2011 11:31 pm Post subject: |
Nice move Les. Hard to do all that after the build and most folks want it.
Gig Harbor
Ari - 19 Cruiser sold 2023
Joined: 02 Nov 2003 Posts: 20812 City/Region: Pensacola
Posted: Sun Aug 14, 2011 1:40 pm Post subject: |
Great moves to make a higher quality boat. Can you share the laminate schedule on both the bottom and sides? _________________ Bob Austin
Les Lampman Dealer
Posted: Mon Aug 15, 2011 9:40 am Post subject: |
thataway wrote: | Great moves to make a higher quality boat. Can you share the laminate schedule on both the bottom and sides? |
Hi Dr. Bob,
I'll have to share than when I have the final documentation. Since the hull that's being done now is the first one that's being hand laid and has the extra coring we didn't have a "set in stone" schedule going in but now that the hull as been done I'm due to get the full layup schedule soon.
If I don't post back here within the week or so please remind me! |
C-Nile
Joined: 09 May 2008 Posts: 638 City/Region: Connecticut
State or Province: CT
C-Dory Year: 2012
Vessel Name: Betty Ann
Photos: C-Nile
Posted: Mon Aug 15, 2011 12:41 pm Post subject: |
Les,
I'm impressed that you are using Mascoat Delta-T throughout the boat. Not knowing much about the product, I got onto the Mascoat website, and was astonished by the insulating and sound-deadening properties of this light-weight material. Add to that that you are using double coatings of the material in the interior cabin and berth, this will make for a very comfortable boat with less condensation issues.
Rich _________________ Marinaut 215 - "Betty Ann" Sept-2011
CD 16 Cruiser "C-Nile" Sold 06/2011 |
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
Posted: Mon Aug 15, 2011 3:03 pm Post subject: |
Les,
As one of the first C-Brats to use the Mascoat product, you have made an excellent decision. After 4 years I finally painted it so it would be easier to clean. Why I waited 4 years I don't know. When I sold my 22 it looked like a new boat on the inside. _________________ Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981- |
Les Lampman Dealer
Posted: Wed Aug 17, 2011 11:56 am Post subject: |
Thanks for the comments everyone! They're much appreciated.
Les |
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Thu Aug 18, 2011 3:50 am Post subject: |
Les, Are you interested in doing Mascoat applications on existing boats?
M/V Lori Ann
Anacortes, WA
Les Lampman Dealer
Posted: Thu Aug 18, 2011 8:54 pm Post subject: |
Doryman wrote: | Les, Are you interested in doing Mascoat applications on existing boats?
Warren |
Hi Warren,
Not for now. The application is being done at Townsend Bay Marine (TBM) when the hull is built so we're not set up to do it at the Cornet Bay location at all. TBM might do it on an existing boat but I think it would likely be an expensive thing to do through them if they have to work around the existing interior structure. I'll be happy to send you their contract info if you wish.
Les |
Les Lampman Dealer
Posted: Thu Aug 18, 2011 8:58 pm Post subject: |
Ah, I might also mention that doing the Delta-T in a new boat is quite a lot different than adding it to an in-service boat. We used something on the order of 12 gallons of material to coat the entire Marinaut; it's not a "cheap" addition at all. I think the material is in the neighborhood of $60 to $65 per gallon.
Les |
