Honda 90 tilt/trim indicator malfunction
Moxieabs
City/Region: Cape Neddick
State or Province: ME
Vessel Name: Widget
Photos: Widget
PostPosted: Wed Jul 06, 2011 1:30 pm    Post subject: Honda 90 tilt/trim indicator malfunction Reply with quote
My 2003 Honda 90 tilt indicator seem to have a memory issue. If the motor has been up, the indicator slowly responds to tilt down. If it has been down, it slowly responds to up tilt. It can take as long as 5 min for the true position to be displayed correctly. The little black lever at the sending unit seems to move easily in either direction. Is this a sending unit malfunction or a problem with the indicator (gauge at the helm)? Can I place a multi-meter on the wires to the indicator to see if the voltage varies at the same speed as the tilt to trouble shoot indicator vs sending unit?
Moxieabs on WIDGET
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Wed Jul 06, 2011 4:11 pm    Post subject: Reply with quote
you might try spraying the little black spring loaded lever with WD-40 first. That worked for us.
Patti and Barry
formerly C-Cakes, now
rving around N. America
Page generation time: 0.028s (PHP: 58% - SQL: 42%) - SQL queries: 15 - GZIP disabled - Debug on
