Jimmylee
Joined: 06 Sep 2007 Posts: 34 City/Region: Bellingham
Vessel Name: She's a Keeper
Photos: Jimmylee (Name TBD)
Posted: Tue May 17, 2011 6:30 pm Post subject: Stuck Window |
We have a 22-ft cruiser that sits in our driveway year round up here in Bellingham. Even though I have used the boat all winter, it had been a while since I tried to open the port window. When I did this past weekend, it was stuck solid. I cleaned up the green stuff on the outside of the window tracks, but it still wont budge.
Any ideas on how to free the window???
Thanks in advance
Chip |
Aurelia
Joined: 21 Aug 2009 Posts: 2335 City/Region: Gig Harbor
Photos: Aurelia
Posted: Tue May 17, 2011 6:51 pm Post subject: |
I would try pushing more up on the window handle while trying to move the window backward. If you have another person handy, try using two hands on the outside and two on the inside (steam them up first for sticking action) then lift up on the window because it is likly stuck in the bottom track more than anything. I would also flood the track with warm water to lube it up without making a mess. After you get it free, clean the tracks out and use one of the many lubes out there to get that thing slipping again. I like teflon spray or silicon but there are others out there. Those big suction cups with handles for autobody work would come in handy if you have access to one or two. Nice to see another C-Dory out there with little kids aboard!
Gig Harbor
Ari - 19 Cruiser sold 2023
Joined: 02 Nov 2003 Posts: 21357 City/Region: Pensacola
Posted: Tue May 17, 2011 7:17 pm Post subject: |
Use liquid rollers by Mary Kate (silicone) in the track regularly. This prevents the problem. Good description of how to free it up. _________________ Bob Austin
Posted: Tue May 17, 2011 7:39 pm Post subject: |
I used a power washer to clean out the tracks; just sprayed down/up the windows from outside. Amazing amount of PNW "green" washed out. Then I followed up w/ what Gred did and lubed the bejeezus out of the tracks w/ spray silicone. _________________ "We can go over there...behind the 'little one'....."
Jimmylee
Posted: Tue May 17, 2011 8:54 pm Post subject: Stuck Window |
Thanks for the replies guys, very helpful. |
bjidzik
Vessel Name: Betty Joe
Photos: Betty Joe
Posted: Tue May 17, 2011 9:02 pm Post subject: |
Even with a wash out & lub, my starboard side window will not open sometimes.
I have a loop of line that I put into the latch. A simple push down on the latch and a pull back on the line will usually free the window. _________________ 2002 16' Cruiser (Cachita) traded in 10/2009
2009 25' Cruiser (Betty Joe)
Brian & Helen Idzik |
Posted: Wed May 18, 2011 8:55 am Post subject: |
Used to happen on my 22. I found that I could use a bladed device (screwdriver or the like) between the frame and latch and VERY CAREFULLY pry there loosening the window. Be sure you lift up the latch so that it is free to slide. Then, lubricate that track as others have said.
K4KBA |
matt_unique
Vessel Name: Napoleon
Photos: Napoleon
Posted: Wed May 18, 2011 9:26 am Post subject: Ditto |
Captains Cat wrote: | Used to happen on my 22. I found that I could use a bladed device (screwdriver or the like) between the frame and latch and VERY CAREFULLY pry there loosening the window. Be sure you lift up the latch so that it is free to slide. Then, lubricate that track as others have said.
Charlie |
This is just what I did when I first received Napoleon (with the standard feature of a stuck window I used a cloth over the edge of the screw driver to prevent scratches but you just need to move it a pinch. Then spray on a lube like WD-40 or Liquid Rollers and it will slide.
Now I just hit the window frames with WD-40 a few times a season and it keeps them moving freely. Others prefer Liquid Rollers. _________________ Captain Matt
Former owner of Napoleon (Tomcat) Hull #65 w/Counter Rotating Suzuki 150's. |
lloyds
Joined: 02 Aug 2005 Posts: 1724 City/Region: sublimity
Vessel Name: undecided
Posted: Wed May 18, 2011 11:09 am Post subject: |
I have a cribbage board sitting right under the front of that window. When it won't open I put it in the gap between the frame and the handle and pry. Comes right open. Everything on a boat has to perform multiple functions. |
digger
Vessel Name: C-Sik
Photos: Snoopy-C
Posted: Wed May 18, 2011 11:58 am Post subject: |
One thing that I've found is that sometimes the window has moved in a way to tighten the latch. If I push the window closed even more, then I can release the locking mechanism, and pull it open. Just a thought. Ron |
Posted: Wed May 18, 2011 1:35 pm Post subject: |
On my older "87 Cruiser, the latch mechanism has multiple ribs on which the lever/catch can engage. (On Edit: I think this is the same issue which Ron discusses above, with a slightly different degree and/or solution.)
If you "slam" the window shut, it over-tightens on the farthest rib, making dis-engagement difficult, so you learn not to do that!
If, however, you accidentally over do it, then you need to open the lever with one hand and with the other hand with a broad blade screwdriver, pry between the metal catch lever and the metal window frame to force it open.
I don't like to pry on glass (whenever I can avoid it), as it tends to fracture and chip.
Algae and mold build-up aren't a problem in a covered slip on an inland lake.
slapshot
C-Dory Year: 2011
Vessel Name: C's Slap Shot
Photos: C's Slap Shot
Posted: Wed May 18, 2011 4:34 pm Post subject: stuck window |
Both windows were stuck on our new boat. It turns out they were jammed. With starboard side to dock, Jack on the inside and me on the outside, I pushed the back bar of the window while he pulled the latch. Pop! It was open. The hard part was the port side. Jack climbed on the side, had one hand on the top rail and banged on the back bar while I pulled inside. Pop! Good news is that he didn't launch into the water. I'm not sure his knees will ever be the same. We sprayed all window tracks (and screen tracks) with spray silicone. All are sliding nicely. _________________ Jack & Julie Canny |
lloyds
Posted: Wed May 18, 2011 4:58 pm Post subject: |
The back bar requires some care. I think it is either a pressed fit or glued. not sure which. I know I pushed on mine last week and it started to come off. |
