Honda 90 fuel pump leak
wapiti
City/Region: sherwood Park
State or Province: AB
Vessel Name: C-Breeze
Photos: C-Breeze
PostPosted: Sun May 08, 2011 11:18 am    Post subject: Honda 90 fuel pump leak Reply with quote
I just took my Honda 90 for a tune-up to my local Honda dealer. They told me that when they started the engine they noticed leaks from both fuel pumps. After letting the motor sit for awhile they started it again and didn't see much leakage. The motor ran well. The cost to replace two fuel pumps is around $500.00. Honda does not provide kits for fuel pump repair. Would dry gaskets and seals be the problem? Should I replace the pumps ASAP or should I run the engine and check for fuel leaks?
PostPosted: Sun May 08, 2011 3:27 pm    Post subject: Reply with quote
If it doesn't appear to be a safety hazard, I'd run it for a few hours without the cowl on so you can watch it closely.
Oh, and keep a fire extinguisher handy. an "ABC" rated type that can put out fuel fires. Wink
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun May 08, 2011 4:53 pm    Post subject: Reply with quote
I dont have these OBs. Are they mechanical or electric pumps?
Could they tell if leaking from pumps or hose connectors?
Brent Barrett
wapiti
Photos: C-Breeze
PostPosted: Mon May 09, 2011 11:13 pm    Post subject: Reply with quote
Brent;
Not sure if the pumps are electric or mechanical, but the leak is definitely from the pumps not the hose connections. Wouldn't have to replace the pumps if the leaks came from the connections. Is leakage from a Honda 90 fuel pump a common occurrence?
Wapiti
blackfish
City/Region: saltair
Vessel Name: raincoast
Photos: Raincoast
PostPosted: Tue May 10, 2011 12:08 am    Post subject: Reply with quote
not sure what year your honda is
but the bf90a have two mechanical fuel pumps
strange that both pumps would start leaking
have you pulled the pumps apart
there's not much to them
I'm looking at the fuel pumps online and I just don't see $500. dollars
but i could be looking at the wrong motor
what year is your honda?
PostPosted: Tue May 10, 2011 1:50 am    Post subject: Reply with quote
Iam sure most of the $500 is for labor. I bet this job books out at 3 to 5 hours to remove, replace and set the fuel pumps.
wapiti
Photos: C-Breeze
PostPosted: Tue May 10, 2011 9:56 am    Post subject: Reply with quote
Blackfish;
My Honda 90 is a 1996. The Dealer quoted me $186 per pump and labor to install for a rough total of $500.00. Does this may sense?
wapiti
BrentB
Photos: BrentB
PostPosted: Tue May 10, 2011 10:23 am    Post subject: Reply with quote
What did the dealer recommend?
blackfish
Photos: Raincoast
PostPosted: Tue May 10, 2011 10:38 am    Post subject: Reply with quote
boat.net lists each pump at 83.30 plus a 1.74 o-ring
I guess you might replace the fuel lines aswell
+shipping +tax and labour
I googled this and could not find anything about leaking honda fuel pumps also searched the marine engine forums.
Let us know how you make out
wapiti
Photos: C-Breeze
PostPosted: Tue May 10, 2011 8:09 pm    Post subject: Reply with quote
The dealer recommended replacement of the fuel pumps if the leaks persist. But at $186 per pump versus $83, I can see why he would like to replace them. How difficult is replacement and synchronizing of these fuel pumps?
Thanks!
wapiti
BrentB
Photos: BrentB
PostPosted: Tue May 10, 2011 9:31 pm    Post subject: Reply with quote
do you have a shop manual?
blackfish
Photos: Raincoast
PostPosted: Tue May 10, 2011 9:48 pm    Post subject: Reply with quote
www.boats.net
this is the place I have got parts for my honda
you need to register to get shipping rates
check it out , don't forget these prices are american so the standard shipping etc applies
like I said I've got stuff sent up never had to pay extra at the border
some times I got way with no hst it,s all honda parts no aftermarket
another good site is www.marineengine.com find your way to the honda out board forum there are a couple of honda mechanics that post all the time(honda dude and justintime) very helpful guys
http://www.marineengine.com/boat-forum/forumdisplay.php?21-Honda-Outboard-Forum
as for replacing the fuel pumps
the pump is held in place with two bolts thats about it
remove the fuel lines and your done (label the fuel lines there are six of them)
i've had the top one off before but not the bottom I think because its a bit harder to get at
as far as I know you don't synchronize pumps
are you thinking of the carbs maybe?
I still find it strange that your pumps are leaking
can you see where on the pump the leak is coming from
maybe you could just tighten the four screws on the front
wapiti
Photos: C-Breeze
PostPosted: Thu May 12, 2011 7:11 pm    Post subject: Reply with quote
Blackfish;
Thanks for the most helpful information and suggestions. I was going to order the fuel pumps and install them myself, but after starting my Honda 90 and running it for over 10 minutes, I found no signs of leakage around the fuel pumps. The dealer definitely told me that there was leakage from the pumps???? Will continue to monitor, but replacement of the pumps is now on hold.
Thanks again!
Wapiti
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Thu May 12, 2011 8:00 pm    Post subject: Leaking fuel pumps Reply with quote
My 90 hp Honda engine started running rough several days ago, so I changed the Racor filter. After the filter change, the engine ran okay for a few minutes and I had to squeeze the primer bulb to make the engine run smooth. I removed both fuel pumps and the in-line fuel filter below them and it took about 15 minutes to get everything removed. The filter was harder to remove than the pumps, as it is located in a bracket below the lower cowling under the linkage. I bench tested the pumps with a vacuum gauge and found that the top pump was not holding a vacuum when depressing the plunger.
I am ordering the pump on line and purchased the replacement fuel filter from Autozone for $3.69 (their part number FF3418). The installation will take about the same time as the removal...
Steve Baum
Homeport of Portsmouth, VA
blackfish
Photos: Raincoast
PostPosted: Thu May 12, 2011 9:12 pm    Post subject: Reply with quote
boy you're right about that fuel filter it's a real bear to get in or out
Page generation time: 0.0583s (PHP: 68% - SQL: 32%) - SQL queries: 28 - GZIP disabled - Debug on
