Can I make my own sling slots?
RonJr
City/Region: Olympia
Photos: Beagle
PostPosted: Wed May 11, 2011 10:35 pm    Post subject: Can I make my own sling slots? Reply with quote
I have a 2010 King trailer with bunks. Has anyone made their own sling slots? If so, what's the best way to make them?
I plan to launch at Cap Sante this weekend because I understand they can lift a 22 C-Dory without slots. But I would like to make some if practicle.
Ron & Rose
1987 22 Cruiser - sold 2012
2006 16 Cruiser - sold 2015
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Thu May 12, 2011 8:16 am    Post subject: Slings Reply with quote
The problem is the load bearing areas in the bunks. You would need direct load bearing support on both sides of the desired spot where you would consider cutting the bunks to create a spot for the sling.
Captain Matt
PostPosted: Thu May 12, 2011 11:30 am    Post subject: Reply with quote
the slots on my bunks and most bunk trailers I have seen are not made from removing material but adding it. leave your current bunk in place and add a second layer or bunk on top of it minus the spots where you want the slots. So its two layers of bunks with slots in the top layer only. the sling operator will thread the straps thur the slots of the top layer. I will try to take a picture when the boat is off the trailer next.
Jazzmanic
Photos: C-Dancer
PostPosted: Thu May 12, 2011 11:36 am    Post subject: Reply with quote
What Tom said. I actually did this project a few years ago. I used 2 x 6 treated outdoor wood, covered with bunk carpet, and screwed them from underneath the original bunks with galvanized hex head screws (I think). It did raise the level of the boat by a couple of inches but it hasn't seemed to affect the towability of the boat. I don't think I took pictures but if you look at the King Trailer site under accessories, they have a picture of their sling bunks, made out of a plastic or rubber material. Yes it's a very easy project.
Peter & Caryn
Email: pjamero@gmail.com
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Thu May 12, 2011 12:01 pm    Post subject: Yes Reply with quote
Great point! I was thinking in my terms of jack access points from the ground but of course with slings you can thread them through the holes cut out on the 2nd level.
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Thu May 12, 2011 12:06 pm    Post subject: Reply with quote
On a King-
Remove the slick bunks, if so equipped.
Add a second 2x6 to the existing bunks, leaving a slot for the sling.
It is easiet to install the slick bunk material to the new 2x6 sections before installing them.
You may not need slots forward if enough room exists for a sling forward of the bunks.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
Page generation time: 0.0458s (PHP: 58% - SQL: 42%) - SQL queries: 20 - GZIP disabled - Debug on
