TOGO
C-Dory Model: 19 Angler
Vessel Name: TOGO
Photos: TOGO
Posted: Sat Apr 02, 2011 6:51 pm Post subject: Towing Mirrors |
I am one of the worlds worst trailer backers. Because of a few messed up vertebra I need to use mirrors. With the empty trailer I loose sight of the trailer on the ramp. I think that extending the mirrors may help. I do some times open the back gate which helps. I tow with a Ford Explorer V8 7500 lb towing.
I have been on the net looking there are a lot of different types of mirrors what works and what does not.
Will some of you please share your opinions with me. thank you
Guy |
TOGO
Vessel Name: TOGO
Photos: TOGO
Joined: 01 Mar 2005 Posts: 7481 City/Region: from island boy to desert dweller
Posted: Sat Apr 02, 2011 7:59 pm Post subject: |
The stock extending mirrors on the Chevy/GMC pickups are great. If you can find something aftermarket like those, they are two piece - one regular mirror and one wide angle. Also, if you don't have them, goal posts on the trailer might make it easier to see in your mirrors. |
Tug
Joined: 22 Jun 2007 Posts: 991 City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
Posted: Sat Apr 02, 2011 9:24 pm Post subject: |
What i use , i attach those magnetic trailer backing and hitching guides by Align-Quik on the rear trailer frame..they are orange in colour and about 44 inches tall. Even if i loose sight of the trailer i can still see the orange guides to back up the trailer.......they also work great when backing the truck up to attach the trailer to the hitching ball. Tug |
Posted: Sat Apr 02, 2011 11:51 pm Post subject: |
The Ford F-250 has the small rear view mirrors, but both give a true view, objects are NOT closer than they seem. I don't know how that one slipped through, but I appreciate it.
The only problem I have backing the trailer is when the empty trailer goes over the edge of the ramp, that is, the trailer starts down the slope, and it disappears from view. And no mirror is going to help that. I think that, as mentioned above by Tug and Jim, a stick with a flag would be the best help in backing the trailer. One on each end would let you see when the trailer starts to go cattywampus. And let you correct it at once.
Boris |
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Sun Apr 03, 2011 7:19 pm Post subject: |
I would be concerned with vibration -- that is a problem with most clamp-on mirrors. If you end up buying them, please post your experiences.
On my Dodge I replaced the factory mirrors with Power Vision mirrors. The biggest problem I had with them is that the right mirror was not convex so my field of view was much less than with the factory mirrors. I looked at the CIPA but they do not make models with turn signals and do not recommend installing on trucks with turn signals, like my GMC. So I may take another look at PowerVision down the road, because they do offer models with turn signals.
M/V Lori Ann
Anacortes, WA
Posted: Sun Apr 03, 2011 7:27 pm Post subject: |
On my Tundra, the mirrors are electric. Works great to tilt them and swing them in to keep track of the empty trailer. On my Dodge van I used to have a set of 5x7" curved mirrors, that came from Thrifty Auto. Stainless, and absolutely eliminated any blind spots. Yes they were curved and "objects might appear smaller" but if there was a kid standing next to the van, they did show up.
As to backing, Pull forward until every thing is straight and pointed right, then back, slow and turn the wheel VERY Little. Turn the BOTTOM of the steering wheel the way you want the back of the trailer to go.
Good luck and enjoy,
SleepyC
Socrateur
Vessel Name: Sea Skipper
Photos: Sea Skipper
Posted: Sun Apr 03, 2011 8:02 pm Post subject: |
These have worked for me. Cheap and easy to take on and off. They don't vibrate at speed either, as long as you're going in the forward direction. _________________ Capt Jay |
dotnmarty
Joined: 03 Nov 2003 Posts: 4209 City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
Posted: Sun Apr 03, 2011 9:30 pm Post subject: |
I have a pair of the mirrors Jay suggests. They worked fine on the Volvo 240 pulling our 16 footer. Once I put them on in the Spring I just left them on until I put the boat away for the winter. I recommend them. _________________ MartyP
"...we're all in the same boat..." |
TOGO
Vessel Name: TOGO
Photos: TOGO
Posted: Fri Apr 08, 2011 9:30 pm Post subject: |
I will give the Camper World mirrors a try. and will do something for visible posts. thank you all for your input. I will keep you informed on my progress.
Guy |
c-ness
Joined: 21 Jul 2010 Posts: 521 City/Region: Bellingham
C-Dory Model: 24 Tomcat
Vessel Name: C-weetness
Photos: C-weetness
Posted: Sat Apr 09, 2011 8:47 pm Post subject: |
Everyone has their own backing style. I too use mostly just the mirrors but not because I cannot twist in the seat. Rather, I find that the mirrors give me a pretty good way of directing the boat once I know which way I need to go. When backing the boat straight I try to have the same amoutn of boat in each mirror. The boat should be backing straight. If the boat appears to be filling more of one mirror and is disappearing from the other, I steer into the mirror where the image is growing. That is, if I find that the boat is filling the left hand mirror I just turn the wheel to the left and the boat straightens out. If the boat is filling the right hand mirror, I turn to the right. Conversely, if I want the boat to move to the left my left), I turn into the right hand mirror to make the boat disappear from the right hand mirror. And if I want to turn the boat to the right my right), I turn the wheel to the left to make the boat disappear from the right hand mirror.
It sounds a bit weird but it works for me. I seldom feel the need to pivot around and look at the boat. |
icewater
Joined: 08 Dec 2003 Posts: 23 City/Region: North Pole
C-Dory Year: 1981
C-Dory Model: 22 Classic
Vessel Name: Blessing
Posted: Sat Apr 09, 2011 9:41 pm Post subject: Add on mirrors |
Several years ago our son gave us a set of the add-on mirrors from JC Whitney for our 99 Dodge Ram. Still use them. Provide just enough extra vision that I'm comfortable with all sorts of trailers; boat, car, snowmachine, cargo, etc. I've used them all over Alaska and down into Texas without a problem (except the right one has to be readjusted a couple of times every day). |
