Freezing pops seals out of water pump -- Yamaha 100 4stroke
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Tue Feb 15, 2005 11:10 pm    Post subject: Freezing pops seals out of water pump -- Yamaha 100 4stroke Reply with quote
I have a 100 HP Yamaha 4 stroke......problem........winter freezing weather has popped the water pump oil/water seals out of the water pump housing (cocked them) causing water to leak into the lower unit gear grease. Sad The dealer said all they've done is pushed em back and locktighted them back in. Have you had an experience, or heard of the problem up in good 'ol AK. I wonder if it is just a bad design for the 100's or if there is a new part, new seal, or different housing that might take care of it. Thanks, Digger
previous snoopy-c owner, previous c-miner owner, current C-Sik owner(22 angler)
PostPosted: Wed Feb 16, 2005 12:33 am    Post subject: Reply with quote
you mean all they have done after replacing the gear case oil...right?
C-WEED
City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Wed Feb 16, 2005 9:40 am    Post subject: Reply with quote
Digger: Just wondering. Did this happen with the boat on the trailer? Or boat in the water with motor tipped up? Not positive but I think that lower unit is used on 75 thru 115. I have noticed if I unscrew the fresh water adapter after the motor has drained in the down position on the trailer I get more water out of the fitting. Not sure if this would cuase and trouble but it couldn't help in freezing weather.
Chris
digger
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Wed Feb 16, 2005 10:21 am    Post subject: water pump, Yamaha 4 stroke Reply with quote
This happened on a trailer, in my garage, with the motor down. I've just been told that in addition to loctiting the seals in, a drainage hole is enlarged to assist in draining. Got to find out what size to drill out the hole, I guess. Supposedly, the part numbers for current models are still the same. Ron
Redƒox
Guest
PostPosted: Wed Feb 16, 2005 7:00 pm    Post subject: Reply with quote
Ron, nope never heard of it up here in old Alaskie! Neutral
I always worry about that kind of stuff though (even though it's not happened to me) I always let the engine drain out before I let it sit on trailer in the up position (while trailering home) just to not let sea-water sit in the housing for long, getting stagnant and growing little (itty-bitty) sea-monsters Mad I don't always get a chance to flush it out either. Rolling Eyes
Page generation time: 0.0305s (PHP: 66% - SQL: 34%) - SQL queries: 17 - GZIP disabled - Debug on
