Prop size for a 22 Angler with a DF90
easternshore22
City/Region: Eastern Shore
State or Province: MD
Vessel Name: Hunky Dory
Photos: Hunky Dory
PostPosted: Wed Feb 09, 2011 9:18 am    Post subject: Prop size for a 22 Angler with a DF90 Reply with quote
Hi,
I decided to change the old Johnson 70 for a DF90. I am trying to find out the proper prop size for the 22 Angler. After reading the posts in the Propellers forum it is not clear which prop will be the best fit. It seems that fellow C-Brats are using from 13 to 20 pitch in a 22 powered with a 90HP.
I am going to get a SS prop since the bottom in this area is generally mud and the chances of hitting something hard are slim. The boat will generally be loaded on the light side.
Thanks for your feedback,
Franco
____________________________
1996 C-Dory Angler 22'
Choptank River
Eastern Shore, MD
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Thu Feb 10, 2011 8:23 am    Post subject: engine Reply with quote
Is the DF90 a Suzuki engine if it is ,We had a 90 hp Suzuki the 2litre one same block as the 115hp we put a S/S 14by 18 pitch it was perfect 35-36 mph and 4-5 mpg also revved up to 5800rpm
If on the other hand its a newer suzuki 90 small block 1.6 litre you might need a smaller pitch .The suzuki has a bigger gear case then honda or yamaha .
WE now have a CC-23 with a yamaha f-115 and we use a 13by 15pitch S/S prop we can rev up to 5500rpm and about 32 mph top end about 4-5mpg
easternshore22
Photos: Hunky Dory
PostPosted: Thu Feb 10, 2011 10:29 am    Post subject: Reply with quote
Jim,
Thanks for your reply. Yes it is the newer Suzuki DF90. I think I will ask the dealer to start with a 14x17 test prop and see how it performs.
Franco
rogerar
City/Region: SW FL
Vessel Name: Duck
Photos: Duck
PostPosted: Tue Nov 08, 2011 5:04 am    Post subject: Reply with quote
What prop did you end up with and how's the WOT RPM?
I am setting up a new Suzuki 90A on my C Dory 22, and the 14 X 18 prop seems too big.
Thanks
easternshore22
Photos: Hunky Dory
PostPosted: Tue Nov 08, 2011 7:48 am    Post subject: Reply with quote
Roger,
The dealer end up recommending the 14x18 prop. At WOT it runs at 5900 RPM and 34mph. That is in the lower range of the WOT. I have a spare 13.75 x 15 aluminum prop that gives me the full WOT and 32mph with light load, with heavy load it would only reach 29mph and it feels like it is trying harder to push the boat.
I cruise with the 14x18 at 4500 RPM at 25mph. The SMIS gauge reads 4.5-5mpg. I am ok with that so I decided on that prop.
If you have the option of trying both props, do that with your normal load so you can get a feeling of which one will fit better.
Franco
rogerar
City/Region: SW FL
Vessel Name: Duck
Photos: Duck
PostPosted: Tue Nov 08, 2011 9:51 am    Post subject: Reply with quote
Thanks, I'll try another WOT run, I can't seem to get it over 5400, though the dealer reported 5800.
easternshore22
Photos: Hunky Dory
PostPosted: Tue Nov 08, 2011 9:55 am    Post subject: Reply with quote
You are welcome. The 5400 RPM reading is with the engine trimmed all the way down? 5400 WOT RPM is what I get with the engine trimmed all the way down. When I trim it up I get the max WOT.
Franco
rogerar
City/Region: SW FL
Vessel Name: Duck
Photos: Duck
PostPosted: Tue Nov 08, 2011 4:16 pm    Post subject: Reply with quote
I'll take it out tomorrow and try the trim adjustment, then I'm hauling out for the 20 Hr. break-in service. I really like this motor, the fuel economy is excellent and the 75 lb. savings over the older DF90 are impressive! My stern floats an inch higher.
Thanks
Page generation time: 0.1246s (PHP: 88% - SQL: 12%) - SQL queries: 26 - GZIP disabled - Debug on
