Draining fuel tanks
Goto page 1, 2, 3  Next
CheckRaise
City/Region: Kingston, WA
Vessel Name: CheckRaise
Photos: CheckRaise
PostPosted: Sat Jan 22, 2011 2:45 pm    Post subject: Draining fuel tanks Reply with quote
I've got a 22' cruiser with 2+ year old, untreated gas in its tanks. I'm hesitant to burn it off, even at an idle. Has anyone determined a (relatively) easy way of pumping/draining gas out of their tanks?
- john
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sat Jan 22, 2011 3:11 pm    Post subject: Gas Reply with quote
I have drained gas tanks before using a hand pump.
Captain Matt
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Sat Jan 22, 2011 3:28 pm    Post subject: Reply with quote
I just use a long clear siphoning hose and a few good draws on the hose and your set.I just drape the hose over the gunnel and empty into a gas can. With the clear hose you can see the gas coming and that way you do not end up swallowing any gas.Works for me. Tug
Chester
City/Region: home
Photos: Chester
PostPosted: Sat Jan 22, 2011 4:45 pm    Post subject: Reply with quote
The fuel line connector that goes to the engine has a check valve that can be opened by inserting a small tie wrap, WD-40 hose or similar soft object. Put the opened connector into an empty fuel can below the bottom of the boat and start the siphoning process by squeezing the fuelline bulb. Please note the bulb is sensitive to the attitude it is held at.
This is slow but it works OK.
Steve
jimcinfra
City/Region: Crystal Springs, MS
State or Province: MS
Vessel Name: Delta Belle
Photos: Delta Belle
PostPosted: Sat Jan 22, 2011 6:57 pm    Post subject: Reply with quote
I don't know if it is the best way, but I used a shop vac to drain my tanks. I was scared the whole time. I put some water in the shop vac each time I ran it.
Delta Belle
Crystal Srings, MS
Alok
City/Region: League City
State or Province: TX
Photos: Top Cat
PostPosted: Sat Jan 22, 2011 8:04 pm    Post subject: Reply with quote
No kidding! Shocked
Alok
PostPosted: Sat Jan 22, 2011 11:19 pm    Post subject: Re: Draining fuel tanks Reply with quote
Just park it in a tough neighborhood and somebody will relieve you of your old gas!
(AND maybe a lot more....................!)
Starcraft Tom has some friends that have borrowed a few things from him before.
Maybe he could set you up with an appointment, and you could get localboy to arrest the thugs after they serviced your boat?
Joe. Laughing Thumbs Up
PostPosted: Sat Jan 22, 2011 11:28 pm    Post subject: Reply with quote
Alok wrote:
No kidding! Shocked
"Houston, we have ignition.......!"
Pretty good for a $39.95 Sears Craftsman ShopVac!
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Sun Jan 23, 2011 4:55 am    Post subject: Wow Reply with quote
OMG...glad you're still here to tell the tale!
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Sun Jan 23, 2011 8:12 am    Post subject: fuel tanks Reply with quote
This would be a perfect time to take out those check valves if you have them then I would use long hose connected to fuel bulb drape over gunnel squeeze the bulb a few times and then remove bulb this should then siphon off rest of gas works for me
I keep a fuel line an extra bulb on board .With the cc-23 the alum fuel tank pickup is in front of tank so when you are on plane with a few degrees angle of attack fuel goes to back of tank so you are not pulling all the gas out . 30 gallons and maybe you can use 25 gallons .So I keep the bulb and line to transfer fuel to other tank if I get caught with less fuel in one tank I can transfer fuel to the tank im using .
PostPosted: Sun Jan 23, 2011 7:31 pm    Post subject: Reply with quote
From a safety standpoint--I hope that the shop vac post was a spoof. That is a very good way to blow up the boat and yourself....
I have used my fuel polishing and transfer system to take fuel out of the tanks of a number of boats. I put the fuel into 30 gallon plastic containers or 5 gallon cans. After filtering with a 2 micron filter and adding addatives, plus adding 2;1 fresh gas, I have burned it in my SUV. This gets away from "what do I do with the old fuel".
jimcinfra
Photos: Delta Belle
PostPosted: Sun Jan 23, 2011 7:43 pm    Post subject: Reply with quote
No, not a spoof. I quess from the reaction I was completely a dumb ass for doing what I did. Thank the good Lord for protecting me!
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Mon Jan 24, 2011 12:14 am    Post subject: Reply with quote
Jim, I am really glad that the good Lord was looking out for you and that you survived an "accident waiting to happen".....In my occupation, we call "practices" like this job security.
About four days ago a couple of folks were driving in a van in Bellevue, Wa. They were having difficulty keeping their van's engine running. As I recall from the news stories, they removed the engine cowling that extends inward between the driver and front passenger seat thereby giving them direct access to the engine's carburetor. Then they had an open bucket of gas and were apparently using a cup or glass to dip into the gasoline and pour it directly into the carburetor to provide fuel to the engine. With the buildup of fumes in the passenger compartment it wasn't long before an explosion occurred engulfing the van and its' occupants in flames. Apparently both have survived their critical burns, but the van is "toast". Video clips of the van on TV showed it while it was still engulfed in flames.
(Perhaps, one of you computer nerds can locate the Seattle TV news video footage of this and transfer it to this thread.)
P.S. I love the name of your C-Dory.....very appropriate for where you live. Thumbs Up
Dave S.
"Sea Shift"
C-Brat #16
PostPosted: Mon Jan 24, 2011 12:30 am    Post subject: Reply with quote
Here's some raw video of the end of the fire and here's some of it fully engulfed.
DaveS
Photos: Sea Shift
PostPosted: Mon Jan 24, 2011 12:48 am    Post subject: Reply with quote
Thank you Roger! That was fast.....16 minutes from my request for video footage to your having it posted on the "thread".
Page 1 of 3
Page generation time: 0.0456s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
