Greasy Question
Tortuga
City/Region: Ventura
C-Dory Year: 1994
Vessel Name: Tortuga
Photos: Tortuga
PostPosted: Wed Jan 12, 2011 9:59 pm    Post subject: Greasy Question Reply with quote
So, I'm doing my own maintenance now on my 2009 Yamaha 90 -- following the service manual. And, under 'Lubricating' they have 3 different types of grease listed.
For tilt tube, engine mount, and cowling locks they list "Water Resistant Grease" (Yamaha grease A); for starter gear at flywheel they list "Low Temperature Resistant Grease" (Yamaha Grease C) ; and for propeller shaft & under prop they list "Corrosion Resistant Grease" (Yamaha Grease D).
On the Yamaha web site they just sell "Marine Grease".
So my question. Can I just use my basic marine grease from West Marine for all three applications, or do I really need to track down theses 3 types? BTW -- the service manual nor the Yamaha website actually describes what type of grease these are so I don't know how using a stock grease effects compatability issues.
Any suggestions or advice would be greatly appreciated.
Thanks!
Matt
Tortuga
Ventura, CA
PostPosted: Thu Jan 13, 2011 12:01 am    Post subject: Reply with quote
If I get a vote, here's what I would think.
If you use a good waterproof grease, that should do the trick for all those places. If you're superstitious, get some high temp silicone grease for the flywheel, otherwise don't worry.
Otherwise call Yahama customer service: your call is important to us, listen carefully as our menu has changed, please read our FAQ on our website. Since you're willing to buy something, they should be able to tell you what that really means.
However I don't know if I have a vote.
Tortuga
C-Dory Year: 1994
Photos: Tortuga
PostPosted: Thu Jan 13, 2011 1:25 am    Post subject: Reply with quote
Thanks Boris -- that's where I'm leaning. Anyone know of any circumstances where that approach (just using a good marine grease for everything) would be a problem?
PostPosted: Thu Jan 13, 2011 4:08 am    Post subject: Reply with quote
No, not probably, but they, probably, do use specific lubricants on the original factory installations, but don't, probably, offer them at the dealer level, so that probably, the idiots that don't service their motors, properly, have a better chance at, probably, getting them to survive, anyway, probably.
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Thu Jan 13, 2011 8:07 am    Post subject: Greasy Question Reply with quote
Tortuga,
I use marine grease on wheel bearings, and my steering fittings, prop shaft and tilt shaft. But for the for the starter gear they want a low temp grease so it does not get sticky when it's cold out is my guess. That gear needs to move up down on the shaft so thick grease might cause it to hang up in colder temperatures.
D.D.
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Thu Jan 13, 2011 11:50 am    Post subject: Reply with quote
I'm only aware of one Yamaha Marine Grease, so you can use that.
We also use a lot of BRP's Triple Guard Grease. Good stuff.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
Tortuga
C-Dory Year: 1994
Photos: Tortuga
PostPosted: Thu Jan 13, 2011 12:28 pm    Post subject: Reply with quote
Thanks everyone -- I'll just use the one Yamaha grease -- and if my boat blows up I'll let you know. Wink
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Thu Jan 13, 2011 1:30 pm    Post subject: Reply with quote
ditto
I use one Yammie grease in the grease gun
see http://www.simyamaha.com/Yamaha_Yamalube_Marine_Grease_p/acc-greas-14-ct.htm
and for the rest the purple TGG from Johnson/Evinrude.
I think it is the same grease but less expensive than the other brand names.
I buy large tubes and repack into smaller containers
Wonderful stuff!
I did buy a tube off WR #2 grease but have not used it yet
http://www.simyamaha.com/Yamaha_Grease_WR_No_2_p/90790-74046-00.htm
It was highly recommended in other forums
Brent Barrett
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Thu Jan 13, 2011 1:34 pm    Post subject: Reply with quote
One consideration worth exploring is whether using non-Yamaha lubricants will give them an excuse for denying a warranty claim. Matt? Marc?
Doryman
M/V Lori Ann
Anacortes, WA
Page generation time: 0.0337s (PHP: 65% - SQL: 35%) - SQL queries: 22 - GZIP disabled - Debug on
