Fiberglass radar arch for a CD 22'?
C spot swim
City/Region: Juneau
Vessel Name: George C. Williams
Photos: George C. Williams
PostPosted: Fri Dec 03, 2010 8:28 pm    Post subject: Fiberglass radar arch for a CD 22'? Reply with quote
I was just wondering if anyone has gone this route for a radar arch rather than metal; I am considering it.
Any thoughts pro or con?
Thanks.
Most evolving lineages, human or otherwise, when threatened with extinction, don't do anything special to avoid it.
George C. Williams
PostPosted: Fri Dec 03, 2010 10:45 pm    Post subject: Reply with quote
C spot swim-
These are not very commonly discussed around here at all, if ever!
(To my memory!)
Do you have any examples of commercially available, ready-made, fiberglass radar arches?
PostPosted: Fri Dec 03, 2010 11:21 pm    Post subject: Reply with quote
Many production boats use Fiberglass/polyester radar arches. But the tooling for one would be relitatively expensive. Many of them are actually aluminum, with paint--rather than glass. The arch has to be hollow, for the wiring (and weight).
It certainly could be done--but unless you want to make your own molds, It would be expensive. My Radar mount is PVC pipe--and I have done 4 Radars that way, and it works well. (and cheap).
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Sat Dec 04, 2010 2:09 am    Post subject: Reply with quote
The ones I have seen are on larger boats, appear heavy and lack the flexibility and modification characteristics of tubular aluminum or stainless.
Boatless for now but looking
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Sat Dec 04, 2010 12:26 pm    Post subject: Reply with quote
Fiberglass arches are ususally used to blend the arch into the overall boat design. Since the C-Dory "look" isn't about sleek and sexy, I would think a fiberglass arch would look odd on the boat.
It would certainly be interesting to see one done, though.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
C spot swim
City/Region: Juneau
PostPosted: Sat Dec 04, 2010 12:33 pm    Post subject: Reply with quote
I have a call out to fiberglass shop to see if it can be done locally. There are a few images on the internets but none that really strike me as proper for a C-Dory yet.
If I can't get it done locally, I probably won't do it at all and just stick with a bolton stainless radar arch.
I'll keep you all posted when I find out.
Cheers.
PostPosted: Sat Dec 04, 2010 7:11 pm    Post subject: Reply with quote
Are you going to glass a fiberglass radar arch onto the C Dory roof? If so, consider how your are going to do that. To make it blend in, will not be easy or cheap. If you are having a fiberglass shop build an arch, then I assume that you would have them also apply it to the boat. You will still have to deal with a hollow structure, for wiring. You will have to have access into the center of the arch.
C spot swim
City/Region: Juneau
PostPosted: Mon Dec 20, 2010 10:39 pm    Post subject: Fiberglass radar arch a 'no go' Reply with quote
Just an update, couldn't find a willing fiberglass expert to make an arch. No worries, went with a nice stainless. Sometimes money won't buy everything. Confused
Cheers
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Tue Dec 21, 2010 10:10 am    Post subject: Reply with quote
I haven't seen any of this in a long time but they do make fiberglass electrical conduit. It's often times used on cooling towers and smoke stacks. What I installed many years ago was 1 1/4" trade size. It might be handy for some applications around a boat.
marvin
Page generation time: 0.0512s (PHP: 60% - SQL: 40%) - SQL queries: 22 - GZIP disabled - Debug on
