dave
Joined: 21 May 2005 Posts: 381 City/Region: Riverview
Vessel Name: Cocoon
Posted: Fri Dec 03, 2010 1:18 pm Post subject: Dinghys again 2 |
We have never had a dinghy before, so this is new territory for us. We are looking for a small inflatable dinghy to explore and take the dogs to shore. The three I was looking at were
Achilles LSI-230
Alaska Series 240-TDS
Mercury 240 Air Deck
While reading past threads I saw that Saturn has a couple of boats and prices that interested me. They are the
Kaboat SK396
SD230
I also noticed that some have the transom recessed and some like the Alaska series 240-TDS are oval shaped. How does that difference change the handling?
I was also thinking of the 2HP Honda, because it is air cooled and our main is a Honda. The previous threads talked me out of that. I think the 3.5HP Tohastu might be the best choice for a motor.
Any insights, comments, contrast and comparisons, and other observations will be appreciated. We will keep it deflated when not in use. |
Posted: Fri Dec 03, 2010 1:42 pm Post subject: |
There may be some advantages of each of the boats. You are looking at air floors, and I consider that wise, especially with dogs. The Kayak is going to be too large to put on the top of the cabin (I think)--unless you put a rack aft over the cockpit. But it will easier to row or paddle.
Of the bunch I would go with the Achillies. This is avery well established brand, which uses Hypalon, a more UV resistant and perhaps more abrasive resistant coating on the fabric. I prefer a transom boat, in that it is easier to use the outboard. My last oval boat was in the 60's--but the Alaska Boats do have a number of followers and are of good quality.
I agree with your choice of engine. _________________ Bob Austin
NewMoon
C-Dory Year: 1991
Vessel Name: Cindy Sea
Photos: Cindy Sea
Posted: Fri Dec 03, 2010 1:47 pm Post subject: |
I'd go for the lighter but also tougher models, like the Alaska or the hypalon Avon Redcrest (our dinghy). But - I've never had a flat transom dinghy.
If I were doing it over again, I might choose the 3.5 Tohatsu rather than our 22lb 2hp Yamaha. The Yamaha sure is light and easy to rig, but occasionally it seems we could use a tad more power. I guess we still wouldn't ever hit much more than about 4 knots, however. _________________ Richard Cook
"Cruising in a Big Way" |
Posted: Fri Dec 03, 2010 3:17 pm Post subject: |
Basic shapes ---roundboat or donut vs V-shape, transom or flatback.
V - shape, better in directional control and use with an outboard.
Round boat, advantage, if in rough water, your have flotation all around, meaning less chance of getting turned sideways or down hill and getting "Pooped" wave coming over the transom . Maybe more functional as a "life boat" but harder to propel in a desired direction, even with an outboard, (not a planning shape or hull bottom.
Other info above is good info.
SleepyC  _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
Posted: Fri Dec 03, 2010 8:41 pm Post subject: |
Since you're in Florida, think about a Hypalon dinghy. The sun is hard on polyester dinghys.
I have an Achilles and have found it to be an excellent quality dinghy. Previously, I've owned Avons but they got too expensive. Get a small one with a flat/hard transome if you're going to run an outboard. A round transome requires a special outboard bracket, which is just another thing to buy and carry.
Defender has some good deals on a lot of different dinghies, so you can compare sizes, features and cost as well a outboard weights and costs. Lighter is better (from a good brand.). Select "Boats and Motors" under Categories. Remember: Hypalon.
As to a motor size, 2 hp doesn't cut it. I know they're lighter, but against swells or a wind, you will need more power than a 2 hp will have. Save yourself the upgrade later and get a 3-5 hp now. I had a 3 hp Johnson 2-stroke. Great motor, but not enough power at times. Got a 6, and it was wonderful.
Boris |
dave
Vessel Name: Cocoon
Posted: Thu Dec 09, 2010 2:15 pm Post subject: |
I have narrowed the search to 2 boats From A to Z
Achilles LSI-260
Zodiac Cadet Airlite 260
Any further observations or suggestions? |
centerisland
Joined: 19 Feb 2007 Posts: 336 City/Region: Mercer Island
Vessel Name: Lulu
Posted: Thu Dec 09, 2010 3:56 pm Post subject: |
thataway wrote: | You are looking at air floors, and I consider that wise, especially with dogs. |
Why the air floor for dogs? Wouldn't a wood / plastic floor be less likely to puncture? Or are you thinking of small dogs? Ours is a 55lb samoyed and I was thinking RIB or solid floor.
I have an Avon 310 Rollaway (plastic slats) that I was thinking of trying...any idea if that would fit on the cabin top under a tall arch? Everyone seems to be using tenders that are about 1/2 meter shorter. I know it's a bit on the heavy side at 90-something pounds, but - um - I already have it. <smile> |
Posted: Thu Dec 09, 2010 4:07 pm Post subject: |
Air floor is lighter, by several (10 -25) lbs, , depending on the size. Hard floor is good for dogs, if you don't mind the extra weight. Ontheair floor, cover it with some good carpet for extendede wear and protection.
SleepyC  |
centerisland
Vessel Name: Lulu
Posted: Thu Dec 09, 2010 4:13 pm Post subject: |
hardee wrote: | Air floor is lighter, by several (10 -25) lbs |
Indeed - lighter is important!
Anyone care to comment on being able to fit a 310 versus a 240/260?
My dream dinghy is actually an Aquapro Superligt RIB, but I think the aluminum hull would interfere with the radar when carried on the cabin top of a 22. |
Spike38
Joined: 29 May 2008 Posts: 63 City/Region: Punta Gorda
Posted: Thu Dec 09, 2010 4:19 pm Post subject: Zodiac vs. Achilles |
I had a Zodiac Cadet and liked it fine except that at that time the Zodiacs were not Hypalon. Neither the seams nor the material withstood the FL sun well. Later I had an Achilles and considered it a much better boat. Good luck with whatever you choose! |
Posted: Thu Dec 09, 2010 4:32 pm Post subject: |
I just sold a Avon Vinly articulating floor and it works fine for dogs. I agree--too heavy--in fact ours had wheels for transporting it, with the 15 hp motor. The air floors are tough enough to withstand the dog's claws with hypalon material. We have had labs, a chow shepard mix and a border collie which are been fine with air floor boats. The dogs claws will make some marks on the floor, but not damage it to the extent that it has been an issue. |
dave
Vessel Name: Cocoon
Posted: Fri Dec 10, 2010 1:31 am Post subject: |
Thanks All
I told my wife about the selection. She asked what was the approximate cost for the boat and motor? I told her. She said "Merry Christmas".
I'll be going to see some tomorrow. I'll let you know. |
breausaw
Vessel Name: Triple J
Photos: Triple J
Posted: Fri Dec 10, 2010 2:09 am Post subject: |
2hp or 3.5hp nether will get you up on plain I think. Once you start pushing a bow wake you have reached your max speed. We have the Alaska Series 240-TDS, nothing but praise for this dink. We push it with a 2hp Honda and it gets the job done. Sure the Honda it a little peculiar because it has a clutch that engages the prop once give it enough throttle, but other than that it’s a bullet proof motor. You never have to flush this motor because its air cooled, just stow it and forget about it. Three of use in the dink be speed along at 4.5 to 5 mph at 1/3 throttle, more throttle and maybe a tad more but waist of fuel.
Three season on Prince William Sound, no complaints for either. _________________ Jay
Posted: Fri Dec 10, 2010 7:15 am Post subject: |
Jay,
I sure like to hear that about the Alaskan and the 2HP Honda. I have a "sort of"alaskan, and have thought all along that the Honda 2 would be a good match. Just trying to avoid paddling, not waterskiing.
SleepyC
matt_unique
Vessel Name: Napoleon
Photos: Napoleon
Posted: Fri Dec 10, 2010 8:06 am Post subject: 3.5 |
I can plane off in my Mercury Roll-up 200 with my Mercury 3.5 engine in the right conditions with careful balancing. Ha ha - but it's really just better to put along celebrating the fact you don't have to row against the wind and current! _________________ Captain Matt
Former owner of Napoleon (Tomcat) Hull #65 w/Counter Rotating Suzuki 150's. |
