Montana Kev
Joined: 25 May 2007 Posts: 318 City/Region: Bozeman/Yellowstone
State or Province: MT
Vessel Name: Grace
Photos: Grace
Posted: Wed Nov 17, 2010 9:45 pm Post subject: Relocating Batteries in to cabin in a 22? |
I know battery relocation and placement has been covered many times here. I cannot find anything about moving the 2 batteries forward into the cabin in a 22 cruiser.
What is the consensus on moving them way forward in to a locker under the v-birth?
Kevin |
Posted: Wed Nov 17, 2010 10:00 pm Post subject: Re: Relocating Batteries in to cabin in a 22? |
Montana Kev wrote: | I know battery relocation and placement has been covered many times here. I cannot find anything about moving the 2 batteries forward into the cabin in a 22 cruiser.
Kevin |
You'll need some big cables to carry the starting and charging current that extra distance to the engines in order to avoid a significant voltage drop but other than that, it shouldn't be a big issue. What's the motivation for doing this? _________________ Roger on Meant to be |
Joined: 02 Nov 2003 Posts: 21357 City/Region: Pensacola
Posted: Wed Nov 17, 2010 10:17 pm Post subject: |
Generally when you put batteries in an enclosed cabin, you want to go with AGM batteries. The reason is that Lead acid batteries give out hydrogen gas, which is explosive--and any acid spilled will cause damage to material which is near the battery.
Currently I have only AGM batteries in the cabin of my C dory. In the past, I have had large banks of both golf carts and starting batteries, inside of a cabin of large sailboats/ motorsailors. But these have been in areas which were vented to the exterior, such as an engine room, or box with an outside vent. _________________ Bob Austin
Montana Kev
Vessel Name: Grace
Photos: Grace
Posted: Wed Nov 17, 2010 11:03 pm Post subject: |
The motivation for doing this is to shift some of the weight forward and also to free up some storage in the stern. Just not sure if it's worth the effort.
Kevin |
Posted: Wed Nov 17, 2010 11:53 pm Post subject: |
Kevin-
I did it in my CD-22.
I put two group 27's under the forward dinette seat.
You'll need very large cables, # 0's or # 00's. Use the voltage drop tables that show voltage drop for various wire gauge size vs amperage loads.
I used #6 wire cable, but still have the main two batteries back in the back of the boat, and use the forward two to back up the rear ones, and don't use them independently of the rear set. They provide extra capacity, and are wired parallel into the cables coming forward to supply the windlass. Most of the load on the windlass goes onto them because of the resistance difference/cable length.
I never start my motor on the forward ones alone with the #6 cables. Could be done with some big ones, though.
I wanted two extra 27's to provide more total capacity to use a anti-ventilation plate mounted trolling motor for lake trolling. (See below).
Don't forget a set of circuit breakers or fuses, and an Off-1-Both-2 switch up there to kill the live voltage on the cables, as those big ones can carry 100's of amps and start fires fast!
They're in battery boxes, of course.
Try to keep them centered in terms of weight distribution. I had to shuffle some ballast around to balance mine out for the overall distribution. Like the weight forward, definitely! (Also have 75 lbs. (100 ft) of chain in the bow anchor locker).
Joe.
Click in image for larger photo(s) _________________ Sea Wolf, C-Brat #31
nimrod
Joined: 15 Jul 2008 Posts: 268 City/Region: Mount Vernon
Vessel Name: 'Berta's Boy
Photos: 'Berta's Boy
Posted: Thu Nov 18, 2010 12:24 am Post subject: |
the previous owner of my boat moved the batts to inside the cabin under the aft dinette seat. Two Optima AGM batts. Convenient to get to and the weight distribution is good. He also mounted the batt selector switch to the port side aft cabin bulkhead.
jd |
breausaw
Vessel Name: Triple J
Photos: Triple J
Posted: Thu Nov 18, 2010 1:34 am Post subject: |
Another consideration is cost, 1/0 gauge marine tinned battery cable is like $6 to $8 a foot, 2/0 gauge about $8 to $10 a foot. The battery cable is going to cost you about as much as the batteries. If you trailer your boat and don’t leave it in Salt water for extended periods you could use non tinned cable, it costs way less. _________________ Jay
jennykatz
Vessel Name: Little Treasurer
Photos: Jennykatz
Posted: Thu Nov 18, 2010 5:55 am Post subject: weight forward |
Maybe if your motivation is to move weight forward .Why don't you move the water tank forward instead of batteries this would be a lot cheaper to do and safer . Also you could put a series 27-31 under sink stove and use as your house battery and keep a series 24 in the back for starting
Moving batteries will cost you also what do you do with your boat ? camping ,fishing do you really need all 20 gallons of water Do you really need lots of battery power where maybe a solar collector and group 27 would do . I guess you have to answer a few questions what is my intent balance boat ,more storage in rear , more battery power etc. _________________ retired 8/08 from UAL, still working pt tm
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Thu Nov 18, 2010 12:31 pm Post subject: |
Not that I intend to do it, but another possible reason for moving the batteries forward would be to free up the lazarette for fish or bait.
M/V Lori Ann
Anacortes, WA
Matt Gurnsey Dealer
Joined: 11 Nov 2008 Posts: 1532 City/Region: Port Orchard
Photos: Kitsap Marina
Posted: Thu Nov 18, 2010 12:42 pm Post subject: |
I have seen batteries installed between the fuel tanks in a 22, leaving the lazerette area open. _________________ Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991 |
centerisland
Joined: 19 Feb 2007 Posts: 336 City/Region: Mercer Island
Vessel Name: Lulu
Posted: Thu Nov 18, 2010 1:27 pm Post subject: |
breausaw wrote: | Another consideration is cost, 1/0 gauge marine tinned battery cable is like $6 to $8 a foot, 2/0 gauge about $8 to $10 a foot. |
I've used BestBoatWire.com for years (now apparently part of http://shop.genuinedealz.com) and 2/0 is $3.96 per foot with free shipping. It generally arrives within a few days for me on the left coast. |
Kelly Lynn
Joined: 15 Aug 2010 Posts: 63 City/Region: Springfield
Vessel Name: Kelly Lynn
Photos: Kelly Lynn
Posted: Fri Nov 19, 2010 8:03 am Post subject: |
If you are looking for inexpensive marine wire try www.tinnedmarinewire.com I just put shore ower in my 22' and I looked all over for wire. This place was the most inexpensive I found and good to work with. _________________ Kelly Lynn |
