Changing lower unit grease on 40hp Hondas
Big Mac
City/Region: Chehalis
Vessel Name: Mary Ellen
Photos: Mary Ellen
PostPosted: Sat Nov 13, 2010 12:02 pm    Post subject: Changing lower unit grease on 40hp Hondas Reply with quote
Just curious how most of you change out the lower unit grease. Hot or cold? I have always had it done during service visits, but am going to do it myself this time. I changed out the impellors last year and checked the grease and saw no water so I left it alone. I am going to change the engine oil and filters before I drain the carbs so I could put the engines in gear while I warm them up, which should warm up the lower unit oil? Thanks in advance for any comments,Big Mac.
PostPosted: Sat Nov 13, 2010 12:14 pm    Post subject: Reply with quote
I've always done mine cold. Takes a little longer to drain but it will drain. Be sure to use NEW washers in the plugs, that's the source of a lot of water intrusion if you don't.
Unless you run it a long time, won't warm it up much in the water anyway Doesn't get very "hot" ever...
PostPosted: Sat Nov 13, 2010 12:21 pm    Post subject: Reply with quote
It will certainly drain faster if it's warm, so why not warm it up a bit?
Could use a portable electric heater to blow some warmth on it if necessary.
Or just let it drain overnight, or all week, if it's that cold in Washington!
Or you could move down to SUNNY California and change it in the summertime, no additional heat required!* Laughing
* Just for Roger/Dreamer, and others, who left it all behind. CoolSmile
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sat Nov 13, 2010 4:29 pm    Post subject: Lower unit Reply with quote
I have always changed mine at the same time save the 20 hour service. For me that means first of November in Massachusetts.
This is a silly detail to point out but it's actually 90w oil (not grease). I let mine run out for about 10 minutes. I make a point to have a clean oil pan so I can carefully inspect the oil for contaminants and water.
Captain Matt
mjsiega
City/Region: NYC
State or Province: NY
PostPosted: Sat Nov 13, 2010 5:22 pm    Post subject: Reply with quote
Just curious, but if oil molecules are larger than water molecules, and after you change the lower unit oil and no oil is leaking out through the vent or fill hole, how can water get in through those holes?
mjsiega
City/Region: NYC
PostPosted: Sat Nov 13, 2010 7:18 pm    Post subject: Reply with quote
meant to say "if water molecules are larger than oil molecules".
PostPosted: Sun Nov 14, 2010 11:15 am    Post subject: Reply with quote
If there's a leak at a seal or a washer, oil can and will leak out. When that happens, there's a void and water can and will leak in... Crook
seabeagle
City/Region: Farmington Hills
Vessel Name: Sea Beagle II - Sold 4-19-12
Photos: Sea Beagle II
PostPosted: Sun Nov 14, 2010 5:43 pm    Post subject: Reply with quote
Odd? I thought the lower in my Honda 50 was 30w. Confused
I am the 125% I work so the 99% don't have to.
http://www.youtube.com/SeaBeagleII
jstates
City/Region: SHELTON
Vessel Name: Endurance
Photos: Endurance
PostPosted: Mon Nov 15, 2010 1:07 am    Post subject: Changing lower unit lube Honda 40 Reply with quote
Remember to re-fill from the bottom, to prevent trapping air.
Page generation time: 0.0579s (PHP: 45% - SQL: 55%) - SQL queries: 22 - GZIP disabled - Debug on
