TomCaz
State or Province: MD
Posted: Fri Oct 15, 2010 7:06 pm Post subject: milky oil |
The crank case oil is milky, I noticed a slight milky color and changed the oil and over the past few outings the oil continues to get milky but at a faster rate.
The power does not seem to be lacking, Is this a major $$$$$$$$$$$$$$$$ repair or worse?
TomCaz _________________ "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery"
Winston Churchill |
BrentB
Joined: 15 Jul 2006 Posts: 4420 City/Region: Greenwood
State or Province: IN
Photos: BrentB
Posted: Fri Oct 15, 2010 7:16 pm Post subject: |
For cars, the head gaskets are bad. _________________ Brent Barrett |
Spike
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
Posted: Fri Oct 15, 2010 7:32 pm Post subject: |
I imagine that you know that a milkyness in oil means water in your oil. Not good get it checked out at the soonest. _________________ Chuck
Bootleg Hooch |
Posted: Fri Oct 15, 2010 7:58 pm Post subject: |
It does sound like water getting into the system and that probably means a gasket or seal is broken somewhere in the system. Could be a head gasket, could be a number of other seals depending on make and model. Regardless of the cost to find and fix the problem, it will not get any cheaper the longer you run it with this problem especially if you are introducing salt water into the inside of the engine. You should seek fairly immediate help if your running in salt water. _________________ Roger on Meant to be |
TomCaz
Posted: Fri Oct 15, 2010 8:08 pm Post subject: |
yes, I knew it was water but do not know the point of entry. Its going in the shop asap. I thought it was odd to be taking on water in the crank case and not have any loss of power
TomCaz |
Sam & C-Chickie
Vessel Name: Scout
Photos: Scout
I have a Suzuki 90 h.p. and had the same problem. Turns out it was just a bad thermostat. It was replaced and all is well... The good folks at Kitsap Marina took care of me., I wish you good luck.., Sam |
Tug
Joined: 22 Jun 2007 Posts: 991 City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
Posted: Fri Oct 15, 2010 9:23 pm Post subject: |
Could be just the seals in the lower unit, just replace them and see if that fixes the problem.I would also check to see if the vent/fill screws .( lower unit ). are sealing properly.I would replace them too..they are cheap.I had the same problem ...milky oil..when i had some-ones fishing line get wrapped around my propeller and messed up the seals.Tug |
Joined: 02 Nov 2003 Posts: 21385 City/Region: Pensacola
Posted: Fri Oct 15, 2010 9:29 pm Post subject: |
The oil in the crank case is completely separate from the lower unit. If the milky material is in the lower unit--then definately seals.
No matter what don't run the engine any more, and get it taken care of next week. I would change out the oil now, and leave the clean oil sit in the unit until it is fixed. There can be multiple causes. _________________ Bob Austin
Jack in Alaska
Joined: 17 Aug 2004 Posts: 1191 City/Region: Anchorage/Ninilchik
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
Posted: Sun Oct 17, 2010 1:06 am Post subject: |
My 90 Honda did exactly that....it was the thermostat. They are cheap and an easy self repair.
Jack _________________ On the HIGH TIDE-II, wife Carolyn and I.....Another summer fishing on the HIGH TIDE II in the Cook Inlet at Cape Ninilchik, Alaska.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Bare hull & trailer sold in Nov. |
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2783 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Sun Oct 17, 2010 1:17 pm Post subject: |
Jack in Alaska wrote: | My 90 Honda did exactly that....it was the thermostat. They are cheap and an easy self repair.
Jack |
If it is running cold, incomplete combustion will cause milky oil. I had that issue on an 8hp Honda classic, but never (yet) on the Honda 90... The cure on the 8hp was a different thermostat, and hotter plugs. _________________ "And in the end, it's not the years in your life that count. It's the life in your years." - Abraham Lincoln |
Hunkydory
Joined: 28 Mar 2005 Posts: 2720 City/Region: Cokeville, Wyoming
State or Province: WY
Vessel Name: Hunkydory
Posted: Sun Oct 17, 2010 1:43 pm Post subject: |
One of our twin 40 Honda's thermostats stuck open on our 2007 Southeast Alaska cruise. Would hardly run at idle and crankcase filled with unburned gas mixed with the oil, but remember color of oil and gas to be darker if anything then normal. Bought my replacement thermostat from Les at EQ (now carry a spare in boat) and though I thought the engined might have been damaged he suggested otherwise. It now has 1336 hours on it and has run great for the last 300 hours since the thermostat stuck , so appears he was right.
