runaway crabs
Chester
City/Region: home
Photos: Chester
PostPosted: Thu Oct 07, 2010 6:21 pm    Post subject: runaway crabs Reply with quote
How to keep the little buggers from scuttling behind the fuel tanks?
How to contain them?
Inquiring minds want to know.
PostPosted: Thu Oct 07, 2010 6:32 pm    Post subject: Reply with quote
Steve,
I know they shoot halibut. Would a 9mm do or would you need something bigger Question Razz Laughing
How about a cut to fit 1" by 8'' that lays across the cockpit floor? I'm just guessing how high the little buggers could jump.
How about 2 buckets, one for legal and one forthe little buggers that need to grow or get a sex change.
PostPosted: Thu Oct 07, 2010 6:39 pm    Post subject: Reply with quote
I'd try sprinkling some Old Bay Crab Seasoning around there. That's what we use on the Right Coast in cooking them and it'll probably scare them off... Mr. Green
PostPosted: Thu Oct 07, 2010 6:54 pm    Post subject: Reply with quote
I dump all the crab into a ice chest or large bucket when I pull the traps and sort thru them after I rebait. Then I sort and move them to another ice chest full of water or ice. works great. Also as I sort I place them on thier backs so they cant walk off. They scare the dog a bit and he does not like going near them.
Walldog
City/Region: Port Isabel
State or Province: TX
C-Dory Year: 2014
C-Dory Model: R-27 Tug
Vessel Name: Willie's Tug
PostPosted: Fri Oct 08, 2010 6:20 am    Post subject: Reply with quote
Here is what David of Anna Leigh uses. The little bat does a great job of stunning them, and also breaks the cockleshells that he uses for bait.
Walldog aka Herb Stark
2014 R31 Tug "Willie's Tug"
Port Isabel TX/Ballard WA
http://walldogsjourneys.blogspot.com
PostPosted: Fri Oct 08, 2010 9:17 am    Post subject: Reply with quote
Tom,
I've heard of people getting tickets from the WDFW for not sorting crabs immediately. E.g. it's best to sort and toss the non-legal ones prior to re-baiting the traps. I even had a WDFW officer tell me that I had to sort them prior to dumping them in my boat. When I explained that I couldn't do that safely (clearly he never crabbed himself) he backed down. Nonetheless, there are a lot of "recreational" crab poachers so WDFW has gotten tighter on their enforcement. Just an FYI.
PostPosted: Fri Oct 08, 2010 1:26 pm    Post subject: Reply with quote
roger maybe I did not make myself clear. if I have three pots and pull all three in 10 minutes I dont , nor need too, sort between pots. I pull all three, resettting each one as I go and then sort. crab on on the boat for maybe 10 minutes.
if you have not crabbed a lot make sure you are mesurring your crab right and know how to check for soft shells. Lots of softs this summer and they are not worth eatting. winter crab is a more firm and better eating. thanks to the new rule changes starting 2011 we will get a full winter crab season.
PostPosted: Fri Oct 08, 2010 3:43 pm    Post subject: Reply with quote
Confused HTH did he expect that? Sort them right from the pot while the pot hangs over the side, banging on the boat? I really don't get that.
...check for soft shells. Lots of softs this summer and they are not worth eatting...
Indeed. I always release softies. No meat in the shells, so why kill them? It's better to release them and let them fill the shells out.
In answer to the first question if you place the crabs up-side down on their shells they will ususally go into a state of "tonic immobility" and stop moving. I do that all the time, especially while I'm sorting, so I don't get pinched in the toe. Wink
Chester
City/Region: home
Photos: Chester
PostPosted: Sat Oct 09, 2010 12:26 am    Post subject: Reply with quote
Let's see, suggestions for 9mm or larger rounds and Old Bay seasoning. Hmmm.
OK, I'll stuff the Old Bay into the hollow point bullets! Thumbs Up
I love this place!
PostPosted: Sat Oct 09, 2010 1:16 pm    Post subject: Reply with quote
Get er done Steve,
And actually, since most of my crabbing experience is from "Deadliest Catch" I thought you had to sort as you emptied the traps.
Capn Jack
City/Region: La Conner
C-Dory Year: 1988
Vessel Name: Pocket Yacht
Photos: Pocket Yacht
PostPosted: Sat Oct 09, 2010 2:27 pm    Post subject: What about the "CCR"? Reply with quote
Don't forget the CCR Crook
While you're holding the trap with one hand and sorting with the other,
your pen should be in your teeth filling out your CCR. Smile
Big Brother Angry May be watching you Sad and by the way...Don't forget the "Body Bag" to take all of your back shells home. Wink
Jack CoolSmile
PostPosted: Sun Oct 10, 2010 11:33 pm    Post subject: Reply with quote
Tom,
I've crabbed plenty but if you don't sort between pots, you are leaving yourself open to getting a ticket from one of the eager beaver WDFW officers. I've seen it happen a couple years ago right out in the Snohomish delta in front of Everett. I'm not saying it's right, I'm not saying it makes sense. I'm just saying that it happens and can be avoided by sorting ASAP. I agree on the winter crab being better. I'll be heading out this winter to get my fill for new years eve.
PostPosted: Mon Oct 11, 2010 12:11 am    Post subject: Reply with quote
this winter area 8 will not be open. the new regs do not take affect until next year. area 9 and 10 should be open.
Capital Sea
City/Region: Olympia
Vessel Name: Capital Sea
Photos: Capital Sea
PostPosted: Fri Nov 26, 2010 8:51 pm    Post subject: Reply with quote
I put them in an ice box or 5 gallon bucket with salt water and a few frozen water bottles if the sun is out. We like the little guys alive right up to when we cut them in half clean them and throw them into boiling water with a little spice in it.
Capn. Steve (after a long time away)
Capn Steve & 1st Mate Kath
Save our Sound!
Socrateur
City/Region: Danville
Vessel Name: Sea Skipper
Photos: Sea Skipper
PostPosted: Fri Nov 26, 2010 10:16 pm    Post subject: Reply with quote
Crab are afraid of heights, so put them right here:
Note how this one is holding on for dear life even though the water is right below.
Capt Jay
Page generation time: 0.0839s (PHP: 69% - SQL: 31%) - SQL queries: 32 - GZIP disabled - Debug on
