15" Shaft Kicker on CD25
Jim & Dara
City/Region: Santa Rosa
Vessel Name: PLAN B
Photos: Jim & Dara (TBD)
PostPosted: Fri Sep 24, 2010 1:03 pm    Post subject: 15" Shaft Kicker on CD25 Reply with quote
I (perhaps foolishly) pounced on a Nissan 9.8 kicker with approximately 10 minutes on the motor for our new dinghy.
I understand that kickers on the 25 tend to have a 20" shaft but I'm hoping to find a bracket that will allow me to use the 15" shaft. Does anyone have experience with this set up or recommendations for a bracket that will work?
I don't fish much so trolling isn't an issue.
Thanks in advance!
PostPosted: Fri Sep 24, 2010 3:54 pm    Post subject: Reply with quote
You can do fine with one of the fold up/fold down brackets. We mostly used our 2.5 hp Sizzuki, but have also put the 15 hp Honda Electric start on the same bracket. The problem will be that you will not do well in reverse--since the prop will not be entirely below the water line--but with the setback of the bracket and the 15" shaft--you can still use the short shaft. The motor cowling will be closer to the water, but since the 25 stern lifts fast, we never had any problem with waves over the motor. If runnng it down wind/waves you might have some probelms with ventillation of the prop.
Jim & Dara
Vessel Name: PLAN B
PostPosted: Sat Sep 25, 2010 7:52 pm    Post subject: Reply with quote
Thank you for the info Bob. I was hoping/thinking this would be the case.
PostPosted: Sat Sep 25, 2010 10:04 pm    Post subject: Reply with quote
I've used the short shaft motor for our dinghy on the back our CD-25. We use an adjustable motor mount... with the mount all the way up, the motor is easily clear of the water; all the way down, it keeps the short shaft in the water.
http://www.cabelas.com/product/Auxiliary-Outboard-Adjustable-Motor-Brackets/700685.uts?rid=0987654321
This isn't the exact mount we have (not at the boat right now), but it is similar.
Hope that helps.
Swee Pea
City/Region: Bath
Vessel Name: Swee Pea
Photos: Swee Pea
PostPosted: Sun Sep 26, 2010 7:32 am    Post subject: Reply with quote
Although I have a 22', the bracket I used is the one being referred to. I likewise have a 15" shafted (Nissan 6hp) motor for my inflatable that can do "double duty" as a backup for the 22'.
If you go to the Swee Pea Photo Album page 4, there are quite a few photos of the install. The bracket has plenty of adjustment to lower the motor to a proper depth and still be able to steer. It is a good compromise solution. I also used a mounting plate so the bracket could be removed easily.
Hope this helps.
Swee Pea
PostPosted: Sun Sep 26, 2010 10:09 am    Post subject: Reply with quote
The Nissan 9.8 outboard is the lightest of them all, but I bet it's a 4-stroke.
The outboard bracket Jim/Wild Blue shows above is labeled "Not for 4-stroke use". The one C-Dory gave us is:
GARELICK Model #: 71091
Aluminum Auxiliary Motor Bracket For 4-Stroke Motors
# Horse Power Rating: Over 7 1/2 HP to 25 HP motor
# Vertical Travel*: 15 1/2” (39cm)
Defender Item #: 303618
Manufacturer: GARELICK
Our Price: $395.99
Sorry the URL for the Defender page doesn't seem to work.
Jim & Dara
Vessel Name: PLAN B
PostPosted: Sun Sep 26, 2010 11:48 am    Post subject: Reply with quote
Thanks for all your responses.
I checked on the Cabelas site and did find a Panther bracket that works for 4 stroke as well. (Thanks for pointing that out Boris).
PostPosted: Sun Sep 26, 2010 1:16 pm    Post subject: Reply with quote
Jim & Dara
You might want to check out the other specs on that bracket. The only Panther 4 stroke bracket I found was a fixed bracket. If you have the short shaft outboard, I would assume that you would want the maximum lift, so that you can keep the motor out of the water when it's up and have it low enough to drive the boat when it's down. That's the good feature of the Garelick. Plus it's relatively easy to lift and lower the engine.
They do show a Marine Tech Outboard Motor Bracket for a 4 stroke, which is cheaper than the Garelick, but doesn't have any lift handles or any apparent stops.
BoatBandit has the Garelick mount for $250.
How do you measure the shaft length on an outboard? Journey On's Honda 9.9 measures 28" from the top of the mounting bracket (where it rests on the bracket) to the centerline of the prop. How does that translate into shaft length?
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Sun Sep 26, 2010 1:39 pm    Post subject: Motor Bracket Reply with quote
I have a Garelick 71091 with a Honda 8HP short shaft on mine - works fine with plenty of range to put the motor in the water, or hold it clear.
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
PostPosted: Sun Sep 26, 2010 2:58 pm    Post subject: Reply with quote
This may help:
Long Shaft, Extra Long Shaft, and Short Shaft Outboard Motors
PostPosted: Sun Sep 26, 2010 6:03 pm    Post subject: Reply with quote
Boris,
You have a 20" shaft. My 15 Honda (same frame as the 9.9) measures 23" from bracket to bullet noise or center of shaft. It is close to 17" from top of bracket to cavitation plate--which as Joe illustrated--is the correct way to measure shaft length.
Jim & Dara
Vessel Name: PLAN B
PostPosted: Mon Sep 27, 2010 9:25 am    Post subject: Reply with quote
Boris,
Thanks for pointing that out. I hadn't realized Panther was a fixed bracket. I was leaning toward the Garelick I had seen on their website, now I'm sold.
Cheers
Miafun1
City/Region: Illinois
State or Province: IL
Vessel Name: Lake Effect
Photos: Lake Effect
PostPosted: Thu Oct 21, 2010 5:56 am    Post subject: Reply with quote
Hope that helps.
James,
I'm looking for advice on an auxiliary motor setup which can do double duty with a dinghy. Your setup seems very functional. How well does the dinghy motor push your 25 if required? What hp are you using?
dan
PostPosted: Thu Oct 21, 2010 8:17 am    Post subject: Reply with quote
Miafun1 wrote:
James,
dan
Hi Dan,
That small Merc is a 2.5 hp. I had the dinghy and motor before getting the C-Dory. The 2.5 will move the 25 at about 3 knots in a no-wind/current situation. I sure wouldn't consider it a "get home" motor if you were 50 miles off-shore. But, it will move the boat and with the main engine down, that acts as a rudder and gives you "vague" steering from the helm.
I like the little motor because it is lightweight; easy enough to move it from the motor bracket to the dinghy as needed. I've never had to use it to get home on the 25, only tested it to see what it would do. Having said that, our Honda has been reliable with 1,200 hours on it. My original intent was to get a 9.9 as a kicker... but, then I'd be hauling 3 motors around. Our cruising weight is heavy enough, as is. Wink
Bottom line: if you think you're going to need the small motor to get home, get enough motor to do the job. I also have BoatUS towing insurance... and haven't used that, either.
I had a Honda 5 as a dinghy motor before the 2.5. It probably would work better to move the CD-25, but that motor was a beast to lift, vibrated like a paint mixer, and seemed to have a mind of its own regarding starting.
Good luck with your search.
jacuthbert
City/Region: Vail
Vessel Name: Pohaku
PostPosted: Sat Apr 02, 2011 1:44 pm    Post subject: kicker motor Reply with quote
Dear folks
I just retrieved my 5hp Honda from storage and have installed it on my CDory 25. My question is really about trailering. I am a little nervous that the 5 will fall off in transit. It looks so precarious sitting back there next to the 150 Honda. Do you have any suggestions? I thought about tying it up, but that seems a bit over top...
Amanda
Page generation time: 0.0571s (PHP: 50% - SQL: 50%) - SQL queries: 28 - GZIP disabled - Debug on
