pee hole clogged
TomCaz
City/Region: Edgewater
State or Province: MD
PostPosted: Tue Sep 07, 2010 9:38 pm    Post subject: pee hole clogged Reply with quote
my honda 40 has consistent pee hole clogging. I saw tips on other post and have utilized the weed wackwer line and compressed air. Both give positive results but it is short lived. 10--30 minutes and the flow shuts down to a trickle again.
I assume Im dealing with a larger problem with corrosion and crud build up.
the engine is soaking in fresh water now, is there any chemical or solvet I can spray down the pee hole that would help? Is this an expensive cure? otherwise the engine runs strong. If I dont clear thr pee hole numerous times on a day trip the the overheat alarm will sound off.
thank
Tom
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery"
Winston Churchill
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Sep 07, 2010 9:45 pm    Post subject: Reply with quote
m2cw is it's time to repair the water pump due to impeller breakdown
Brent Barrett
Mike...
Photos: Accelerando
Hi Tom. Just to be clear here, I have never tried this. So, please wait for opinions from those here who know more than me. Smile
Having said that, I know a fellow boat owner who solved his similar problem with SaltAway Flushes.
mike
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Tue Sep 07, 2010 9:47 pm    Post subject: Reply with quote
Had you considered Flomax ?
Or maybe a new waterpump impeller ?
Marc
Wefings Marine Website
Since 1909
TomCaz
PostPosted: Tue Sep 07, 2010 10:04 pm    Post subject: Reply with quote
water pump and impeller have about 20 hours on them, both were changed about 6 months ago.
a local wrench not a marine engine mechanic told me to spray carb wd-40, then some card cleaner down the pee hole??? not sure about that?????
Tom
tomherrick
Guest
PostPosted: Tue Sep 07, 2010 10:19 pm    Post subject: Reply with quote
Certainly, there are a number of causes for the water evacuation port to put our less than optimal flow. A crapped-out impeller could do it. In my locale, small mud-dauber-like wasps get in all sorts of places and stucco them up with mud. The Honda 90 I have was out in a farm field for 10 years before I got it and it was seriously daubered-up. Might be worth a look. I removed the engine cover and took the small rubber hose off of the coolant water evac-hole to provide access. The dirt was all the way up into the hose as well as the metal tube.
Something to look at...
On edit, just saw where someone suggested spraying WD-40 down the hole. If it's mud, water's the better solvent. Compressed air can go a long way to assist as well.
Good luck with it.
T
Plan C
City/Region: Port Townsend
Vessel Name: Susie Q
PostPosted: Tue Sep 07, 2010 10:20 pm    Post subject: Reply with quote
Take your engine cover off and be sure the tube to the pee hole is firmly in place. Your pee could be leaking inside.
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Wed Sep 08, 2010 8:44 am    Post subject: pee hole clogged Reply with quote
Hi,
I thought I remembered someone I think Wild Blue getting an acid flush to rid the inside of his motor of any salt build up. Maybe send Wild Blue a pm if he does not chime in here. I know most people here don't agree but I was advised to get a new impellor done in my out board done every other year. For me if seems like cheap insurance. Some have found waiting a long time makes for frozen bolts trying to remove the lower unit if you operate in salt water. Then things get more expensive. Sometimes bugs make mud houses and or cocoons up in the motor by crawling up your pee hole on your outboard. Some tape a piece of sponge coated a dryer sheet to cover the entrance hole to keep critters from making a home in your outboard when they store for longer periods.
D.D.
TomCaz
PostPosted: Wed Sep 08, 2010 9:04 am    Post subject: Reply with quote
when i use weed wacker line or compressed air i connect direct to the brass fitting on the pee hole. the rubber hose is frree and clear--no bugs
Ill remove the brass fitting next perhaps some large bit are floating around and cant get thru the narrow pee hole
Tom
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Wed Sep 08, 2010 9:19 am    Post subject: Reply with quote
I had the same problem when i first got my C-Dory, tried vinegar in the Salt Away applicator , these only worked for awhile and than the Pee Hole stream would get clogged again.My water pump was not the problem it was calcium and other crud build up in the lower unit. I found it was just as quick to remove the cowling, free the hose from the fitting and work a thin,stiff wire into the water hose as far as it would go.This always unplugged the calcium buildup,some chunks were a couple of mm in size,than i would flush the motor with fresh water and the Pee Stream would be good and strong again. Tug
TomCaz
PostPosted: Wed Sep 08, 2010 8:16 pm    Post subject: Reply with quote
I pulled the brass nipple on the pee hole to give me a larger port to blow out any crud that could be stuck. I placed some small gas hose in the port so I would not get water in the exposed parts of the engine,.
when she started up she had very little water flow, then a few minutes later it was spiting water 15 feet, I let it run for 15 minutes screwed the nipple back on and replaced the small section of rubber hose.
when i restarted the engine the pee port flowed very good for about a minute then slowed back to a very light flow.
I guess I need to figure out how to clear the crud/ salt
Tom
BrentB
Photos: BrentB
PostPosted: Wed Sep 08, 2010 9:50 pm    Post subject: Reply with quote
Has the thermostat been replaced? Was there a lot of buildup on it?
mailbox101
City/Region: Pacifica
Vessel Name: Blue Eagle
Photos: Blue-Eagle
PostPosted: Thu Sep 09, 2010 12:07 am    Post subject: Reply with quote
If it is calcium buildup, you could try running it in hot CLR. It is sold for dissolving the calcium, lime, and rust out of the heater coils of coffee pots. It will work c old, but much slower.
David
"In all systems, as complexity approaches infinity, mean time between failures drops to zero." - Streib's Law
Wefings
Dealer
PostPosted: Thu Sep 09, 2010 12:41 am    Post subject: Reply with quote
could be chunks of rubber from a previous disintegrated impeller .
marc
BrentB
Photos: BrentB
PostPosted: Thu Sep 09, 2010 7:00 am    Post subject: Reply with quote
Are there other descaling chemicals safe for outboards?
Page generation time: 0.0517s (PHP: 48% - SQL: 52%) - SQL queries: 27 - GZIP disabled - Debug on
