water underneath cockpit floorboard
ktplaytime
City/Region: Great Falls
Photos: ktplaytime 22 Cruiser
PostPosted: Tue Aug 24, 2010 12:33 pm    Post subject: water underneath cockpit floorboard Reply with quote
I have a 2008 22 cruiser with the one piece molded floor board in the cockpit, I think there might be water sitting underneath/ does any one have the same problem? and where does the leak come from?
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Tue Aug 24, 2010 12:48 pm    Post subject: Reply with quote
Join the discussion at: http://www.c-brats.com/viewtopic.php?t=12924
Mike Taylor
330-936-1030
A Fishin C
Guest
PostPosted: Tue Aug 24, 2010 1:37 pm    Post subject: Reply with quote
Why do you think that?
Tim & Dave Kinghorn
City/Region: El Dorado Hills
Vessel Name: Sound Venture
Photos: Sound Venture
PostPosted: Tue Aug 24, 2010 1:39 pm    Post subject: Where is the water coming from? Reply with quote
Check the Forum site "Hull, Deck and Fittings". See the tread, "Bilge question-Where is the water coming from?" It pretty well describes the issue for the C-dory.
Don't let the fear of tomorrow steal from the pleasure of today.
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Tue Aug 24, 2010 4:31 pm    Post subject: Reply with quote
Last year my 07 22 had water leaking down under the cockpit floor at the seal between the floor and the cabin. I saw bubbles coming up one day through standing water in that location. Cranked up the bow so the water would accumulate at the stern before sealing. Scrapped and chipped off most of the old sealer material and cleaned the surface with Acetone. I was going out that weekend so sealed it up with GOOP.
Then went in through the drain hole and drilled a plug size hole directly into the raised cockpit floor; about a half gallon of water came out. In that hole I installed a brass sleeve to except a standard drain plug
When the plug is removed now nothing but a small burst of air comes out, must have sealed it up pretty good. Been thinking about installing a vent tube.
Boatless for now but looking
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Tue Aug 24, 2010 7:26 pm    Post subject: Reply with quote
Jay,
With today's sun, you might blow the seals in the deck. I would put the vent tube in tonight.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
breausaw
Photos: Triple J
PostPosted: Tue Aug 24, 2010 8:32 pm    Post subject: Reply with quote
Hay Tom,
No S--- maybe I will just leave the plug out in dry-dock; what is that shinny thing up in the ski? Taking the wife, her sister and a friend out to Perry tomorrow for berry picking. I’ll be braking in the new kicker and trying for silvers, should be a nice day.
Heard you guys chatting at the Disk last weekend, we were fishing off Crafton. Had my son and his buddy out, the horse play nearly sent me over the edge but made it through.
Page generation time: 0.0453s (PHP: 62% - SQL: 38%) - SQL queries: 23 - GZIP disabled - Debug on
