more battery questions
caw
City/Region: Rupert
State or Province: ID
Vessel Name: MY LEE
Photos: My Lee
PostPosted: Thu Aug 19, 2010 11:26 pm    Post subject: more battery questions Reply with quote
This topic has probably been beaten to death----but I'm going to ask anyway. I'm buying two new batteries for my 23 Venture.When I took the old batteries out, discovered both are group 24 cranking batteries---this ain't right!!! I have the normal 4 position battery switch, no isolator or combiner. AC/DC fridge with the DC mode getting abused.Sometimes I forget to switch from cranking to house for longer than I care to admit. At some point I will add an isolator but not enough time before my next extensive trip. So, with my forgetfulness, would I be better off with two deep cycle batteries rather than one cranking and one deep cycle ---dedicate one deep cycle to cranking and one to house----until I remember to install the isolator???
PostPosted: Fri Aug 20, 2010 12:34 pm    Post subject: Re: more battery questions Reply with quote
caw wrote:
This topic has probably been beaten to death----but I'm going to ask anyway. I'm buying two new batteries for my 23 Venture.When I took the old batteries out, discovered both are group 24 cranking batteries---this ain't right!!! I have the normal 4 position battery switch, no isolator or combiner. AC/DC fridge with the DC mode getting abused.Sometimes I forget to switch from cranking to house for longer than I care to admit. At some point I will add an isolator but not enough time before my next extensive trip. [color=red]So, with my forgetfulness, would I be better off with two deep cycle batteries rather than one cranking and one deep cycle ---dedicate one deep cycle to cranking and one to house----until I remember to install the isolator???[/color]
caw-
The standard answer I usually hear is one deep cycle for the house, and a "dual purpose" type starting/deep cycle battery for the motor, but since the starting amperages are so low for the motors we use, I prefer two deep cycles, since they're more bullet-proof being able to withstand deep discharging better.
You'd be OK with either choice.
My best guess!
Tim & Dave Kinghorn
City/Region: El Dorado Hills
Vessel Name: Sound Venture
Photos: Sound Venture
PostPosted: Fri Aug 20, 2010 1:47 pm    Post subject: Why An Isolator Instead Of A VSR? Reply with quote
I agree with Wolf using a start battery doesn't do well if it gets heavy discharging/recharging. Plus, when paralleled for charging, a start battery may keep the house (deep-cycle) from becoming fully charged.
But why not use a Voltage Sensing Relay instead of an isolator? I think the VSR has many advantages over isolating diodes. The Blue Sea model can handle up to 90 amps. Most motors for the 23' Venture won't put out much more than 50 amps. Leave the selector switch on position 1 and let the VSR do the charge selection.
Tim & Dave Kinghorn
Don't let the fear of tomorrow steal from the pleasure of today.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Fri Aug 20, 2010 2:52 pm    Post subject: Re: Why An Isolator Instead Of A VSR? Reply with quote
Tim & Dave Kinghorn
I do not recommend parallel charging, regardless if the batteries are of the same type or not. If they are of different states/condition, one may prevent the other from charging, and discharge it to some degree after charging is off.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Fri Aug 20, 2010 5:18 pm    Post subject: Reply with quote
I have a Walmart dual purpose battery for starting my outboard
Brent Barrett
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Sat Aug 21, 2010 7:41 am    Post subject: Reply with quote
These are simple and effective units from BEP via Marinco.
Marc
Wefings Marine Website
Since 1909
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Sun Aug 22, 2010 8:19 pm    Post subject: Reply with quote
I just bought two new Group 24 batteries this month, after i told the dealer that i had a battery selector switch and could start the engine/run all accessories from either battery he recommended that i buy two deep cycle batteries. He said that they would last longer than having one starting and one deep cycle battery in my situation. Tug
Page generation time: 0.0554s (PHP: 47% - SQL: 53%) - SQL queries: 24 - GZIP disabled - Debug on
