Correct prop for a 22' Angler?
easternshore22
City/Region: Eastern Shore
State or Province: MD
Vessel Name: Hunky Dory
Photos: Hunky Dory
PostPosted: Mon Jul 12, 2010 2:20 pm    Post subject: Correct prop for a 22' Angler? Reply with quote
Hi,
I recently purchased a 1996 22 Angler with a 1996 Johnson 70. It came with the standard prop, 17" pitch. I serviced the engine and the mechanic indicated that the prop pitch is not correct. I get a max of 4200 RPM when I should get 5000+.
Any ideas on what prop to use?
Franco
____________________________
1996 C-Dory Angler 22'
Choptank River
Eastern Shore, MD
PostPosted: Mon Jul 12, 2010 3:17 pm    Post subject: Reply with quote
Franco-
The usual prop for that boat would range from 13 to 15" of pitch, with a diameter of around 13 to 13-1/2".
The 15 inch props are more suitable for the 90 hp engine, and the 13 for the 70 or 75 hp models.
Loading makes a difference, too, with heavy loading needing less pitch to allow the motor to wind up properly.
Elevation of operation also figures in, as well.
Overall, with the 70, my best recommendation would be to go to a 13 inch three blade prop and see what maximum rpm you get.
Each inch in pitch equals about 200 rpm (rule of thumb), so a four inch reduction should yield +800 rpm, and with your present 4200, should yield about 5000.
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Mon Jul 12, 2010 3:22 pm    Post subject: Reply with quote
The old rule of thumb always was 200 rpms for each reduced inch of pitch, I believe. But other things come into play like cupping if you change prop type. It would seem 13P is in the realm of reason for the same model prop.
Those new fairly inexpensive adjustable pitch composite props might be a good bet as well. Maybe someone who uses one can comment.
(edit) Sorry Joe, as you can see it takes me over 5 minutes to type 4 sentences!
Chris Murphy
Alamo, CA
87 22' Angler 08 Etec 90/07 Johnson 9.9
cemiii
City/Region: Alamo
PostPosted: Mon Jul 12, 2010 4:05 pm    Post subject: Reply with quote
I just looked up those adjustables (Propulse) and it looks like they don't adjust down enough for your situation.
easternshore22
Photos: Hunky Dory
PostPosted: Mon Jul 12, 2010 7:05 pm    Post subject: Reply with quote
Thanks for the feedback. I will try the 13" one and see how it goes. I started to look at Solas propellers, the 13" one looks like it comes only in a 12.5" diameter. The max I can have is 13 1/4" diameter. Will that make a difference?
Franco
cemiii
City/Region: Alamo
PostPosted: Mon Jul 12, 2010 7:17 pm    Post subject: Reply with quote
Franco, I'd be surprised if your lower unit would not take up to a 13 3/4 0r 14" diameter. My 88 Johnson 70 did. Usually, I think those 12.5 ers are for the 40-50hp class. I could be wrong though.
If I were you I'd check it out and look at this E-Bay find: New 13 3/4 x 13 SST Stainless for like 79 buy it now. Almost to good to be true? Check your model out at iboats.com and see what sizes it supports.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300444582887&viewitem=&sspagename=STRK%3AMEWAX%3AIT
cemiii
City/Region: Alamo
PostPosted: Mon Jul 12, 2010 7:50 pm    Post subject: Reply with quote
I just looked up the solas and do see some 12.5 dia props listed for certain 70 hp omc's so i'm not sure what to tell you. I guess you should discuss the diameter issue with your dealer or at least measure the radius from your shaft to the anti-ventilation plate before buying anything non returnable.
easternshore22
Photos: Hunky Dory
PostPosted: Thu Jul 22, 2010 3:06 pm    Post subject: Intsalled a 14 x 13 Reply with quote
I finally decided for a Michigan Match Aluminum 3 Blade 14" dia x 13" pitch. I installed it and test it yesterday. RPMs went up from 4200 to 5200. Speed from 18 mph to 21mph. Not a great improvement in speed, but the engine runs much better, before it looked like it was overworked and it seemed to be overheating.
Thanks all for your help,
Franco
Page generation time: 0.0351s (PHP: 69% - SQL: 31%) - SQL queries: 21 - GZIP disabled - Debug on
