Can you recommend a specific brand of fuel bladder
Chubby Bunny
C-Dory Year: 1998
Vessel Name: Jenny G
Photos: Jenny G
PostPosted: Thu Jul 01, 2010 6:22 pm    Post subject: Can you recommend a specific brand of fuel bladder Reply with quote
Hello, I'm interested in extending my cruising range through a collapsible fuel bladder and am seeing models from Imtra, Turtle-Pac, and others.
Does anyone have experience with a specific brand that you'd recommend?
Chubby Bunny
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Thu Jul 01, 2010 8:49 pm    Post subject: Reply with quote
Sorry this is not going to help a lot unless you end up going the same way.
I looked into bladders for range insurance for an occasional offshore albacore trip. I finally ended up purchasing four 6 gal. poly tanks after considering my number of probable uses vs. cost. Easier to fill and move around, snap on outboard hoses, can put the operational tank in the motor well. I use these auxiliaries first and then store the very light and non scratching empties on the roof/bimini under a pre-stretched truck bed bungee web. That way at least 2 or 3 are usually pretty much used up and out of the way prior to fishing.
I often take 1 poly with me, even a shorter trips. I frequently run the kicker or generator off it. I find it rides well in the splash well and provides me with options if there ever were a fuel delivery problem with the main tanks. I also once sold one to another boater with fuel problems. Though I didn't make anything off it, not having to tow the guy back in was payoff enough for me.
Chris Murphy
Alamo, CA
87 22' Angler 08 Etec 90/07 Johnson 9.9
Chubby Bunny
C-Dory Year: 1998
Photos: Jenny G
PostPosted: Fri Jul 02, 2010 5:40 pm    Post subject: Reply with quote
I think I am going to go your way....Just can't bear to part with $500 to $600 for a 20-gal bladder when four 5-gal general purpose cans from the neighborhood hardware store will be literally a tenth of the cost.
mailbox101
City/Region: Pacifica
Vessel Name: Blue Eagle
Photos: Blue-Eagle
PostPosted: Fri Jul 02, 2010 9:23 pm    Post subject: Reply with quote
I went with six of those five gallon jugs as well (the squat stable ones, not the Jerry cans) Also got a roll of that thin foam material that you put under stuff to keep it from sliding around. That way when conditions get a bit rough I can move the cans all the way forward in the cabin aisle and use them for ballast.
And, you don't need to carry all of them at one time! Thumbs Up
Good choice!
Page generation time: 0.0796s (PHP: 33% - SQL: 67%) - SQL queries: 18 - GZIP disabled - Debug on
