Honda BF150 Electronic Monitoring Options
Mike...
Photos: Accelerando
PostPosted: Sat Jun 12, 2010 1:10 pm    Post subject: Honda BF150 Electronic Monitoring Options Reply with quote
Hello everyone.
I have Honda BF150 outboards on the TomCat, and I am wondering what my electronic monitoring options are. Currently I have gauges for RPM and trim, but no fuel flow monitoring. I'd like to get as much data as I can on an electronic display, something like Bad Boy has here with the Mercury Vessel View Display.
Does Honda have something like this? Or can I use NMEA0183 or N2K (preferred) sensors to accomplish the same thing with one of the many electronic displays out there?
mike
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Sat Jun 12, 2010 5:10 pm    Post subject: Reply with quote
It looks like only very few of the Honda engines are NMEA 2000 compatible, and the 150 isn't one of them.
http://marine.honda.com/pdf/accessories/OTR54146_NMEA_2000_PGN.pdf
They do have a digital fuel flow / speedo gauges that will work with 2005 and newer 150's, but it look slike you need one per engine.
There isn't going to be a gauge like the Mercury Smartcraft for Honda. Maretron is probably the biggest manufacturer for NMEA 2000 equipment, sensors and the like, and I don't see anything of their's for Honda.
www.maratron.com
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
Mike, one of your photos shows a big Raymarine Display, an E120 perhaps? Read your book, I think one of those pages can be set up to display engine stuff, not sure what the interface is though. Do a little research...
Matt Gurnsey
Dealer
PostPosted: Sat Jun 12, 2010 5:37 pm    Post subject: Reply with quote
I don't think you can get engine data from the Hondas to a NMEA 2000 bus (and to the raymarine display). Searching Maratron's knowledge base page brings up no hits for "Honda"- although their search engine isn't any better than the one on the C-Brat site (no offense intended). Very Happy
Dreamer
Photos: Dreamer
PostPosted: Sat Jun 12, 2010 5:53 pm    Post subject: Reply with quote
Mike,
If you have electronic Tachs and Speedo, you will have fuel flow, mileage, trip and fuel used readouts on the speedo head. The tachs show the state of trim and RPM. As I recall, they were about an $800 option in 2006.
Dreamer- Sold 25 Feb. 2013
PostPosted: Sat Jun 12, 2010 6:05 pm    Post subject: Reply with quote
Roger these are his tachs from his album. Looks like the wrong ones.
Can he replace them with the electronic ones? Not sure if all the wiring is there or not.
Dreamer
Photos: Dreamer
PostPosted: Sat Jun 12, 2010 7:37 pm    Post subject: Reply with quote
Charlie, Mike,
The Honda harnesses seem to be set up for any possibility. The manuals for the electronic gauges outline the electrical hook up combining the info from both engines for the total fuel flow. The mileage readout is not very good since it uses the pitot pressure port on the engine. Easy to do the math though when you're using 11 gallons per hour and running 22 kts per the GPS. Shocked
Mike...
Photos: Accelerando
PostPosted: Sat Jun 12, 2010 8:41 pm    Post subject: Reply with quote
Matt, it looks like you are right. Looks like my only option is the Honda Electronic gauges. I'll look into those. Thanks.
mike
Mike...
Photos: Accelerando
PostPosted: Sat Jun 12, 2010 8:44 pm    Post subject: Reply with quote
Hi Charlie.
That's a barely used c-70 (maybe 20 hours on it), and I'm pulling it soon.
mike
Mike...
Photos: Accelerando
PostPosted: Sat Jun 12, 2010 8:47 pm    Post subject: Reply with quote
Dreamer wrote:
[color=darkred]Charlie, Mike,
I am hoping all the wiring is already there. It would make sense to use the same harnesses for all installs.
mike
Mike...
Photos: Accelerando
PostPosted: Sat Jun 12, 2010 9:35 pm    Post subject: Reply with quote
Ok, I found the Honda electronic gauges (06373-ZY3-800 and 06375-ZY3-800), but they are definitely ugly and expensive. And as Matt pointed out, I'll need 2 of each. Yuck!
The only positive thing here (besides getting fuel flow) is that I'll recover some of the space on my helm by consolidating gauges.
There really are no other options to these gauges?
mike
Dreamer
Photos: Dreamer
PostPosted: Sat Jun 12, 2010 10:18 pm    Post subject: Reply with quote
Mike,
You'll need only one speedo and two tachs. Still expensive! Confused
Mike...
Photos: Accelerando
PostPosted: Sun Jun 13, 2010 12:18 am    Post subject: Reply with quote
Dreamer wrote:
Mike,
True, but since it is a multifunction meter, I think it makes sense to have two. I am hoping to eliminate all the analog meters I have now. Maybe that is not practical?
mike
Mike...
Photos: Accelerando
PostPosted: Sun Jun 13, 2010 1:22 am    Post subject: Reply with quote
Hmmm. Anyone know anything about these? They say they are Honda compatible.
mike
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sun Jun 13, 2010 3:26 am    Post subject: Honda pressure gauge Reply with quote
Kind of in line with this thread............
I have a 2002 200hp Honda.
There is a gauge on the dash that is a Honda pressure gauge to 50 psi. When at cruise, 4000 rpm's, it is pegged out over 50 psi.
What is the gauge monitoring??? Pressure of what???
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Page generation time: 0.057s (PHP: 70% - SQL: 30%) - SQL queries: 32 - GZIP disabled - Debug on
