drjohn71a
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
Posted: Wed Jun 09, 2010 11:52 am Post subject: |
MIke,
Also, somewhere on this site is a photo of some bunk beds made over the dinette and a slidable extension which makes the dinette berth wider.
Additionally, if, like me, you don't use the Wallas stove much in the summer, you could mount a portable a/c unit atop the normal stove position and anchor it into the starboard or head wall for stability. In my boat, the Starboard side needs more weight usually.
Mike...
Photos: Accelerando
Posted: Wed Jun 09, 2010 11:54 am Post subject: |
Captains Cat wrote: | Mike, mount it on the armstrong bracket on a secure mount of sorts with a visible lock. You can make a cover for it if you're not in a covered berth. You'll only use it for about 4 months anyway and the cable can be run up the stbd side to the shore power receptacle.
That would work. But the issue is getting over the generator to get into the boat, particularly when it is running!
mike |
drjohn71a
Photos: Tom-a-Hawk
Posted: Wed Jun 09, 2010 11:55 am Post subject: |
My aluminum box allows you to climb over it, even if the genset is running. On a hot day you have to put a towel or something over the metal or it will burn you whether the genset is on or off.
John |
Mike...
Photos: Accelerando
Posted: Wed Jun 09, 2010 12:08 pm Post subject: |
drjohn71a wrote: | Have you checked out my generator box installation on my TomCat, in the photo album? |
Neat! Do you board the boat over that? Use it as a step? If so, does that work out ok?
EDIT: Never mind, I see you already answered the question in your next post.
drjohn71a wrote: | Also, in my houseboat, I could never get my three boys to sleep in the bunks. They wanted to sleep in the cockpit or on the floor of the cabin - yes right in the way to the bathroom! |
That may work - but obstacles directly in the path of the head are dangerous.
mike |
drjohn71a
Photos: Tom-a-Hawk
Posted: Wed Jun 09, 2010 12:29 pm Post subject: |
Coming up the dive ladder, the top of the aluminum box is just below knee level. One can step over it, but usually, if at sea, we just sit on the box and swivel our legs into the cockpit, then stand up. That reduces the risk of falling.
If the genset is on, a life jacket or towel will have to be put on the top of the box before sitting on it. We keep the box closed when the genset is operating. Also, the spare fuel tanks are placed on the Armstrong bracket, between the engine tubes when the unit is running. So far, none have ever fallen off.
John |
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Wed Jun 09, 2010 1:55 pm Post subject: |
drjohn71a wrote: | and a slidable extension which makes the dinette berth wider. |
I've never seen this and would appreciate a link, if anyone knows where it is!
M/V Lori Ann
Anacortes, WA
drjohn71a
Photos: Tom-a-Hawk
Posted: Wed Jun 09, 2010 3:39 pm Post subject: |
Maybe the booth extensions were on another site. One had a slot with a 'breadboard' type board that slid out and a leg was plugged in the extended end.
Another had two boards hinged for each seat with piano hinge which were opened to form an "L" with one leg on the floor and the rest horizontally resting on the seat. There would be some leveling problems with the side trim as things are on C-Dory's right now, but a spacer or such would help that.
I think there is enough room on the TomCat to extend the dinette bed and still be able to slide by between the sink and the bed edge.
Re: the Genset Box, there is plenty of room, over an inch, in the lid to allow for some dense thermal or sound insulation, and I had planned to do that in the beginning, but we have had no problems running the unit as it is. It is pretty quiet since most of the sound is bounced aft off the transom and we are usually pretty wet coming aboard off the swim ladder and have plenty of towels handy. So far no problems, but with small kids, maybe the heat would be a danger.
John |
Joined: 02 Nov 2003 Posts: 20818 City/Region: Pensacola
Posted: Wed Jun 09, 2010 4:45 pm Post subject: |
The honda generators will NOT pull fuel up from the tanks. The head is way too much. You cannot use a low pressure pump either--that puts too much pressure on the Honda tank. The only practical solution is a tank at about the same head level as the fuel tank in the generator. _________________ Bob Austin
drjohn71a
Photos: Tom-a-Hawk
Posted: Wed Jun 09, 2010 4:56 pm Post subject: |
As Dr. Bob says, it's too complicated to run fuel from the main tanks. The benefit of having a generator running on the swim step is that the natural flow will vent the area well. Even the Honda extended run tank has to be set at just the correct height to run. I have the extended run tank, but it is too cumbersome for our boat sizes.
I rarely have to run the A/C more than a few hours at a time, and usually only for 15 to 20 minutes to run some appliances.
To put things in perspective, the Honda i2000 will run a De Longhi 11,000 BtU A/C unit at full speed in 90-100 degree weather for 8 hours on it's internal tank. In the mid 80's, it will run in the Economy mode for 12 or more hours. Things usually cool off at night so it it no big deal for the genset to turn itself off after you've had 8 hours of uninterrupted sleep.
It is so very nice to run the genset when cooking a big meal so you can use toaster oven, microwave, TV, etc., or heat the water tank.
The TomCat's Armstrong brackets allow a lot of space for storing extra gas tanks, but you have to be careful to arrange them to allow full and free movement of the outboards while underway.
Once you start running new fuel lines in the hull, you are opening a dangerous can of worms unless you are an expert.
John |
Mike...
Photos: Accelerando
Posted: Wed Jun 09, 2010 9:20 pm Post subject: |
drjohn71a wrote: | Coming up the dive ladder, the top of the aluminum box is just below knee level. One can step over it, but usually, if at sea, we just sit on the box and swivel our legs into the cockpit, then stand up. |
It does seem about the only place to put a generator is on the Armstrong bracket.
You know, if it were not for those stupid fish boxes, I could put the generator in the cockpit right up near the cabin. Maybe even get a nice, vented lockable fiberglass box built in there. But no, those useless fish boxes taunt me yet again!
John, here it looks like you have a metal flap that partially protects the generator's air intake from seawater. Is that the case?
mike |
Alok
Joined: 19 Mar 2005 Posts: 291 City/Region: League City
State or Province: TX
Photos: Top Cat
Posted: Thu Jun 10, 2010 7:33 am Post subject: |
A generator in the cockpit could be a carbon monoxide hazard unless the exhaust is vented to the outside of the boat in a safe manner. _________________ Alok
C-Dory Tomcat (Topcat) sold January 2012 |
Mike...
Photos: Accelerando
Posted: Thu Jun 10, 2010 9:11 am Post subject: |
Alok wrote: | A generator in the cockpit could be a carbon monoxide hazard unless the exhaust is vented to the outside of the boat in a safe manner. |
That good point, but it doesn't matter anyway unless I am willing to have the fish boxes removed. And that seems way too big a task to undertake for little gain (except to say that I won over those damn fish boxes).
mike |
drjohn71a
Photos: Tom-a-Hawk
Posted: Thu Jun 10, 2010 10:16 am Post subject: |
Way back, long ago, on one of the early TomCats, someone posted pics of an insulated exhaust system for a genset located in the live well area and it looked very expensive and took up a lot of room.
Mike, I had several worries about putting a gas genset in a small metal box and consulted several designs used in semi-truck cabs, etc.
I don't know what is intake or outtake now, but I thought that grill around the muffler under that large flap was the outflow of air, not the intake. In any case, I did not want the hot exhaust exit inside the box.
The outboard cables and fuel lines on my boat are very close to the swim step and I wanted to have some sort of protection between the hot exhaust and all of that delicate and explosive equipment, so that was the major reason for the large flap. It does serve to protect from rain and sea water.
I am amazed at how little problem sea water has been in this installation. You can see it coming right up on the top of the Armstrong surfaces at times, but it just runs right off quickly through the drains and this large opening in the photo. I had considered raising the generator with a floor platform in there, but the water has not risen above the rubber feet so far.
Originally, I had to cut the huge hole in order to get that huge 30 amp yoke to fit in, but having the exhaust end of the genset right out in the open outside air seems to be keeping the temperature inside the box nice and low.
That flap also deflects the exhaust flow down ward and aft which I am thinking reduces the chances of much carbon monoxide blowing up and over the transom into the cockpit.
I put one of those cheap, fuzzy, thin rubber bath mats you get at Wal-Mart down in the Armstrong bracket surface to dampen any vibration and it is working well. I put 6 3/8 inch SS bolts through the bottom of the box into the Armstrong bracket, but four would probably work just as well.
What does not show in the photos is that I put a full length, 3 inch high, screened vent across the bottom of the forward wall of the box to allow cool air intake with little chance for water intrusion. I also wanted a natural venting action should gasoline be spilled inside the box.
John |
Posted: Thu Jun 10, 2010 8:56 pm Post subject: |
Any generator in a box needs good air flow over the generator/alternator coils. Even the water cooled marine units, often have to have blowers put in a box, if you totally enclose the unit. I haven't looked at the Honda (other than changing oil and clearing the carb)--but I suspect that there is some fan pushing across the electrical part of the generator. |
Mike...
Photos: Accelerando
Posted: Thu Jun 10, 2010 11:40 pm Post subject: |
thataway wrote: | Any generator in a box needs good air flow over the generator/alternator coils. Even the water cooled marine units, often have to have blowers put in a box, if you totally enclose the unit. I haven't looked at the Honda (other than changing oil and clearing the carb)--but I suspect that there is some fan pushing across the electrical part of the generator. |
It is interesting how much of a quandary this generator is causing me. Mostly because I want to mount it permanently somewhere and be done with it. I really don't want to haul a 75lb. generator around every time we head out to the boat.
Mounting it on the Armstrong bracket appears to be the logical choice, but that's the easiest way onto the boat. Maybe it would work if I built some sort of hinged platform with legs that we could fold down over the top of the generator to use as a step while boarding.
I also pondered perhaps getting a stainless mount made for the the generator. I found a couple of ideas here and here. But, there is no room on the Armstrong bracket for this, and I can't hang it off the side, as the supports would interfere with docking.
So it remains a quandary.
mike |
