Honda tach/hour meter problem
bmacpiper
Vessel Name: Big Blue
PostPosted: Fri May 21, 2010 7:54 pm    Post subject: Honda tach/hour meter problem Reply with quote
I've had problems with my Honda tach (2004 Honda BF90)--reading erratically and/or too high. As mentioned in other posts here, a thump on the face will settle the needle to the proper reading.
However, this tach also has a digital/LCD hour meter built in. When I got the boat last spring, it has 110 hours or so on it. As of today, it shows 550+. Now then, as much as I would love to have spent 400+ hours on the boat in the past year, alas, I only get out about 100 hours a year.
So--any theories on this--and any suggestions on a good gauge rebuilder if that is indicated? I'm in the Seattle area.
tx,
bmc
bmc
"Do it today, you may not pass this way again!"
2005 16 Cruiser, "Natural Blue", sold 2009
2004 19 Angler, "Crush", sold 2012
2007 22 Cruiser, "Big Blue", purchased 2012
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Sat May 22, 2010 12:17 am    Post subject: Reply with quote
We had a sketchy one on one of our 90s and we replaced it with a new gauge and all is well now.
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
PW
City/Region: Browns Point
Vessel Name: Viking Lady
Photos: Viking Lady
PostPosted: Sat May 22, 2010 1:34 am    Post subject: Reply with quote
Viking Lady had the same problem with one of it's Honda 90 tachs at about 450 hours.... replaced both and no problems since. One of the units I took off was working just fine, it's yours if you want it - let me know and I'll be glad to ship it over or you can pick it up in Seattle. I checked one repair house and it appeared less expensive to just replace the unit than have it serviced.
ron
Aboard the Viking Lady
Michele and Ron
bmacpiper
PostPosted: Sat May 22, 2010 10:21 am    Post subject: Reply with quote
Hi Ron,
Thanks, and yes, I'd like to take you up on the old gauge if you don't mind. I'm near Seattle and my wife works at 3rd and Madison.
As an aside, when you buy a new gauge, are you able to somehow change the hours, i.e. from zero to 150 or whatever you think your current hours are? Or do you just have to add 'em up? How expensive is a new gauge?
tx,
bmc
PW
Photos: Viking Lady
PostPosted: Sun May 23, 2010 11:01 am    Post subject: Reply with quote
Hi BMC - I can't remember the actual costs but bought original replacement Honda units thru King Salmon Marine who services the Honda 90's every year, but it seems like they were about $70.00 each with tax. I suspect the meters can be bought less expensively but we try to support our local shop. I could not find a way to 'reset' the hours so I hooked the meters up to a battery and ran the hour meters up to the 'old meter' hours (a mistake I wouldn't do again - as you say, 'just addem up').
I'll drop you a PM with pick up details. I will take the meters into the store today so you can pick them up anytime.
ron
bmacpiper
PostPosted: Sun May 23, 2010 11:40 am    Post subject: Reply with quote
Thanks Ron!
You are an officer and a gentleman.
ben
Salty
Vessel Name: Salty
Photos: Salty
PostPosted: Sun May 23, 2010 7:02 pm    Post subject: Reply with quote
Before you replace your tach take a look at the back of it. I seem to remember that there is a white plug or switch to change for different alternators. I was having trouble with my tach on my Honda 90 and moved that alternator thing back and forth four or five times and that fixed it. It has worked fine for the last two years. Corrosion must build up in the wiper on that selector.
bmacpiper
PostPosted: Sun May 23, 2010 7:35 pm    Post subject: Reply with quote
Did that affect the hour meter also?
tx,
bmc
Salty
Vessel Name: Salty
Photos: Salty
PostPosted: Sun May 23, 2010 7:43 pm    Post subject: Reply with quote
That is a great question. I did add some hours that just did not make sense. The hours did not increase as many as yours though.
Roamad
City/Region: Sacramento
C-Dory Year: 1988
C-Dory Model: 22 Classic
Vessel Name: Fika
Photos: Roamad
PostPosted: Sun Nov 24, 2024 7:03 pm    Post subject: Reply with quote
I know this is an old thread. But I just want to share a big “thanks” to the C-Brats community for the solution below to my wobbly tachometer problem. I was worried I would have to replace my tach. Then I found this thread and the solution below restored stability to my tach needle. I’ve attached a photo to this post that shows the adjustment dial in the back of my tach. All I did was turn the dial through its full range of motion, then return it to its original setting. Problem solved!
[/img]
Now: 1983 22’ C-Dory Classic, 2001 Honda 90hp
Then: 1988 16’ C-Dory Angler, 2008 Mercury 60hp
Page generation time: 0.0265s (PHP: 77% - SQL: 23%) - SQL queries: 23 - GZIP disabled - Debug on
