Fuel tank for Webasto - feedback requested
brevity
Vessel Name: BREVITY
PostPosted: Sun May 03, 2015 2:14 pm    Post subject: Fuel tank for Webasto - feedback requested Reply with quote
BREVITY has a Webasto AirTop 2000s that is, in my opinion, the best accessory ever for cold weather boating. Absolutely love it.
HOWEVER. The 2-ish gallon aluminum fuel tank it came with has no gauge and is very hard to fill through the deck fill. So I routinely 1) spill diesel fuel and 2) run out of diesel for the heater.
I could drill the tank for a gauge, but I think a simpler solution to switch to a translucent plastic tank, like the ones that are used with Wallas stoves. I could easily take it out of the boat to refill it, and it would be easy to see the fuel level by looking at it.
Is this an acceptable idea? Is there some reason that a plastic tank would not work as a diesel tank for the Webasto?
I appreciate your input!
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Sun May 03, 2015 2:53 pm    Post subject: Reply with quote
My boat has had a removable 2 gallon plastic tank for the the Wallas heater for years without any problems.
brevity
PostPosted: Sun May 03, 2015 11:35 pm    Post subject: Reply with quote
Awesome, thank you!
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Mon May 04, 2015 4:29 pm    Post subject: Reply with quote
We use a 10 liter low profile plastic tank after using a smaller more vertical 5 liter tank and like the larger tank if you can fit it. With the larger tank we don't need to ever carry separate additional heater fuel.
both tanks shown here,
http://www.scanmarineusa.com/wp-content/uploads/Fuel-Tanks-2014b.pdf
Greg
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
PostPosted: Mon May 04, 2015 7:57 pm    Post subject: Reply with quote
Patty here. We have a Webasto heater and we have a removable 2 gallon plastic tank. Have had no issues with using diesel. Can't imagine not being able to remove the tank for easy refueling.
brevity
PostPosted: Tue May 05, 2015 1:05 am    Post subject: Reply with quote
It is a huge relief to hear that the smart and practical folks here are using plastic tanks. The little aluminum tank is a giant pain to fill using the deck fill.
Thanks all!
Page generation time: 0.0826s (PHP: 38% - SQL: 62%) - SQL queries: 24 - GZIP disabled - Debug on
