How Do You Install a Bronze Screw-in Bilge Drain
Tim & Dave Kinghorn
City/Region: El Dorado Hills
Vessel Name: Sound Venture
Photos: Sound Venture
PostPosted: Wed Apr 28, 2010 11:26 pm    Post subject: How Do You Install a Bronze Screw-in Bilge Drain Reply with quote
How did those of you with a bronze screw-in bilge drain plug go about the installation?
I assume you drilled the old hole over-sized (how big?), and then undercut to fill the whole thing with epoxy. Drill for a new drain tube and screw on the bronze fitting with the screw-in plug.
Did you epoxy the tube into the new hole?
I'd appreciate any input from those who have done this. Thank you!
Tim and Dave Kinghorn
Don't let the fear of tomorrow steal from the pleasure of today.
Dreamer
Photos: Dreamer
PostPosted: Thu Apr 29, 2010 1:23 am    Post subject: Reply with quote
Tim & Dave, I just installed two on the TomCat. After the holes were drilled in the transom, which has a foam core, I epoxied the inside of the hole, twice. No need to undercut since it is a fresh hole. I sealed the flange to the transom with 4200 and secured with bronze screws. See our album for the procedure.
Then, devise a fool-proof method of remembering the plugs at every launch!
Dreamer- Sold 25 Feb. 2013
Levitation
City/Region: Hemlock
C-Dory Model: R-25 Tug
Vessel Name: CHARLOTTE ANN
PostPosted: Thu Apr 29, 2010 7:45 am    Post subject: Reply with quote
The method I use upon pulling the boat is to remove the plug to drain and place it on the dash right above the steering wheel while I do tinker stuff, tie downs, etc. then put the plug back in before driving away...
At home, if the boat is outside in a rain I pull the plug at supper time and put it on the table next to my plate... After supper I go put it back in... I do not let the boat sit with the plug out...
I have adopted this method because as my tooth has gotten longer my CRS has gotten shorter...
denny-o
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Thu Apr 29, 2010 9:11 am    Post subject: Reply with quote
On a previous boat that had this type bilge plug, I mounted an additonal base plate on the inside of the transom, and kept the screw-in plug there.
I'm not sure why, but I actually prefer this type of plug versus the other type. Is there a practical reason for one over the other?
...while we're on the topic of bilge plugs - I've always put bilge plugs in from the outside, but I know some folks put them in from the inside. Is there a reason(?) or is it just personal preference? I know that on Whalers (and some other open cockpit self-bailers) folks like to put the plug in from inside to facilitate bailing while running, but I always just used the bilge pump if it was necessary.
Best,
Casey
PostPosted: Thu Apr 29, 2010 1:11 pm    Post subject: Reply with quote
Best,
Casey
Oh-Oh! I think I sense another round of the infamous (and interminable)
Da plug--inny or outy?Debate!
Joe. Rolling Eyes Thumbs Up
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Thu Apr 29, 2010 4:18 pm    Post subject: Reply with quote
Thanks Joe for posting the reference to the "Great Inny Outy Debate". I tried to locate it as well, but was not successful. We should annoint you our "C-Brat Resource/Research Librarian", because you do such a superb job in those tasks. Thumbs Up Hard to believe that the thread is from 4 years ago....my how time flies.
What I didn't remember was that the "thread" was 5 pages long. (I just skimmed over part of the thread and located my "Inny Outy Skunk Joke on page one of the thread Rolling Eyes .
Joe
Dave S.
"Sea Shift"
C-Brat #16
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Fri Apr 30, 2010 7:20 pm    Post subject: Reply with quote
You can add a high water alarm for safety
Brent Barrett
BrentB
Photos: BrentB
PostPosted: Sat May 01, 2010 6:41 pm    Post subject: Reply with quote
Interesting photo showing water absorption in foam
http://www.yachtsurvey.com/moisture_meters.htm
Tim & Dave Kinghorn
PostPosted: Sat May 01, 2010 7:42 pm    Post subject: Moisture Meters Reply with quote
Hi Brent,
Thanks for the reference. It certainly ensures that you want to properly prepare any opening into a cored material whether the hull, topsides or other structures.
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sun Sep 05, 2010 6:22 pm    Post subject: Reply with quote
My CD came equipped with a bronze 1 1/4" threaded drain plug and fitting. The plug has a 1/2" square indent for a ratchet wrench. This requires the wrench be readily available.
Does anyone know of a bronze 1 1/4" plug with a built in "T" handle ?????
I painted the plug face with white, then fluorescent red paint so it shows up when screwed in. I also mounted a plastic 1 1/4" cap on my motor extension and screw the plug into it for storage when not in the hull. I have not forgot it in two summers. I can see it from inside the boat when stored in the cap so it is easy to check just before launch. Works for me.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
BrentB
Photos: BrentB
PostPosted: Sun Sep 05, 2010 6:58 pm    Post subject: Reply with quote
is this it?
http://www.fisheriessupply.com/productgroupdetail.aspx?cid=8533&did=8526
Jack in Alaska
PostPosted: Sun Sep 05, 2010 7:32 pm    Post subject: Reply with quote
B2,
That is exactly what I want but in a 1 1/4" diameter plug.
Jack
BrentB
Photos: BrentB
PostPosted: Sun Sep 05, 2010 8:11 pm    Post subject: Reply with quote
Have you checked a plumbing supply company then braze on a handle?
BrentB
Photos: BrentB
PostPosted: Sun Sep 05, 2010 8:26 pm    Post subject: Reply with quote
Are you sure about the size? A hardware store will have a nut and bolt with thread pitch gauge
Jack in Alaska
PostPosted: Sun Sep 05, 2010 8:52 pm    Post subject: Reply with quote
Positive on t he size. It is a big hole.
Page generation time: 0.0574s (PHP: 53% - SQL: 47%) - SQL queries: 28 - GZIP disabled - Debug on
