2004 Marineco/AFI wiper blade refills?
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Tue Apr 20, 2010 7:13 pm    Post subject: Reply with quote
Sea Wolf wrote:
Pat-
Too bad you can't get the same service with the studs on the crapper!
Joe. Laughing Thumbs Up
I thought Pat was the "stud".............(sorry, I couldn't resist.... Mr. Green
Dave S.
"Sea Shift"
C-Brat #16
Dreamer
Photos: Dreamer
PostPosted: Thu Apr 22, 2010 2:08 am    Post subject: Reply with quote
Before throwing my obscenely expensive AFI wiper blades away, I thought I'd try to find the practical solution to the wiper problem. At my local NAPA store, I found refills. NAPA part # 60-1502, $4.39/each. They are 15" long and can be shortened to 11.5" with a knife and a chisel to clip off the little stainless stiffners. A few minutes and I have a like new pair in my spare parts box.
Dreamer- Sold 25 Feb. 2013
PostPosted: Sat Apr 24, 2010 9:16 am    Post subject: Reply with quote
Roger,
Nice job. Maybe this will work on ours too. Another project to look forward to.
timflan
Photos: Two Lucky Fish
PostPosted: Sat Apr 24, 2010 10:02 am    Post subject: Reply with quote
This won't work for my oddball blades, but I like the creativity!
Timothy R. R. Flanagan
mdoug
City/Region: Meredith
State or Province: NH
Vessel Name: Mikey
PostPosted: Thu Nov 18, 2010 7:13 am    Post subject: Reply with quote
I have a 2005 C-Dory 22, and my mechanic also can't locate wiper blade refills. The electric motor is AFI
May try the NAPA blade suggestion; the price is right!
Mikey
mdoug
Vessel Name: Mikey
PostPosted: Fri May 06, 2011 2:48 pm    Post subject: Reply with quote
Marina owner doesn't have my blade in stock--2005 22 cruiser--and his assistant can't match anything up either. My attempt to get a blade from West Marine resulted in wrong blades and a return shipment at my expense. Guess I'll try writing directly to C-Dory.
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Sat May 07, 2011 1:04 am    Post subject: Just replaced the rubber on my 2007 22 CD Reply with quote
I got perfect fit and form factor 12 inch squeegee rubber from my "car Quest" auto parts store. $3.50 each. That included the useless squeegee holder. I just pulled the squeegee out of the holder and it was a perfect fit to the squeegee holder on the AFI wiper on my boat.
So are you trying to replace the whole blade/squeegee assembly, or just looking for the squeegee?
Testosterone Tales-Amazon.com
KG7RC
mdoug
Vessel Name: Mikey
PostPosted: Sat May 07, 2011 6:18 am    Post subject: Reply with quote
Just the squeegee.
Great idea!
RobMcClain
City/Region: Summerlin, NV
State or Province: NV
Vessel Name: Freedom
Photos: Freedom
PostPosted: Thu Feb 14, 2013 3:18 pm    Post subject: Reply with quote
Thanks for this thread! Just after buying our boat I replaced 1 of our Marinco wiper blades with a factory replacement at a cost of roughly $30. With our 2nd Marinco blade now tearing and in need to replacement, and not wanting to pay another $30 for a new one, I followed this thread and bought a single 24" Rain-X wiper blade from Target at a cost of $9. I then removed the blade itself from the Rain-X bracket and cut the blade roughly in half, to 11.5". It is a perfect fit. The existing metal side rails from the old blade were still in very good condition so I reused them, but since I also had the side rails from the new blade I trimmed them down for use as spares if ever needed. The new blade works great, plus I already have a complete spare ready for use whenever the need arises. A fast and easy fix at a fraction of the cost. Thanks!
Rob
Miafun1
City/Region: Illinois
State or Province: IL
Vessel Name: Lake Effect
Photos: Lake Effect
PostPosted: Fri Feb 07, 2014 7:43 am    Post subject: wiper replacement Reply with quote
After searching several stores over the years for in stock wiper blade replacement...I finally found success at Napa. I needed the 12 inch size and asked for the same. He asked, 'pin or hook?' I said, 'pin' and out he came from the behind the counter parts area with exactely what was a perfect fit. No more fabricating wiper blades for me. And only $5.91 tax included.
Key West, Fla.
mdoug
Vessel Name: Mikey
PostPosted: Fri Jun 13, 2014 3:15 pm    Post subject: 2005 c-dory 22 cruiser wiper replacement Reply with quote
How do I get the wiper arms off my 2005 C-dory 22 cruiser to replace wiper blades? Any help will be appreciated. I do think I have the right replacements. Guess I'll see.
Miafun1
Photos: Lake Effect
PostPosted: Fri Jun 13, 2014 4:21 pm    Post subject: Wiper blade replacement Reply with quote
You don't need to take the wiper arms off to replace the blades but to answer your question the arms are held on the motor shaft with a small set screw. Often, they can be hard to remove.
mdoug
Vessel Name: Mikey
PostPosted: Fri Jun 13, 2014 4:34 pm    Post subject: Re: Wiper blade replacement Reply with quote
Thanks, but it looks as if I am going to have to replace the blades themselves. Got the wrong wiper blade holders again from C-Dory. It will be easier to replace the blades with wiper arms off, I think.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Mon Aug 24, 2015 7:24 pm    Post subject: Replacement ANCO blades for a CD 22 Reply with quote
I just went to NAPA and got replacement blades for the boat. The part number is 60-1233, and they are the exact same blades as the originals, perfect fit. If the store has problems, tell them to look in the "Vintage" ANCO blades.
It took me a minute to realize that the tab that sticks up from the part that attaches to the arm just needs to be pulled back. Very easy to do.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon Aug 24, 2015 7:46 pm    Post subject: Reply with quote
And the NAPA 60-1233 wiper blade, is only $8.10... Order the blades at your local NAPA store via the internet and you will receive a 10% discount. If you are military and show your ID, they will give you 10% off at the counter. They only give one discount...
Steve Baum
Homeport of Portsmouth, VA
Page 2 of 3
Page generation time: 0.0436s (PHP: 69% - SQL: 31%) - SQL queries: 28 - GZIP disabled - Debug on
