volsman
Joined: 26 Jan 2007 Posts: 67 City/Region: Gulf Breeze
Vessel Name: Adventure
Photos: Adventure
Posted: Sat Mar 20, 2010 1:33 pm Post subject: 2007-175 HP Suzuki engine surge |
I have a problem - hope you can help. Started the engine up this spring . It started fine. However, when you push the throttle up to 3000+ rpm in neutral the engine starts surging. It runs fine below 3000 rpm. I have not tried with a load on the prop. I changed the primer bulb - I found it leaking. Also drained the fuel filter bulb - no water present. What else should I check??? _________________ Life should be like cruising - always an adventure but never a chore!
_______________________________
Carl and Jo Ann |
Wefings Dealer
Photos: Cruise Ship #4
Posted: Sat Mar 20, 2010 2:54 pm Post subject: |
Carl , thats normal for a Suzuki !! In neutral there is a 3000 RPM rev limiter to protect from over revving with no load . All is well !
Marc _________________ Wefings Marine Website
Since 1909 |
volsman
Photos: Adventure
Posted: Sat Mar 20, 2010 4:46 pm Post subject: 2007-175 HP Suzuki engine surge |
Thanks Marc- learning new things everyday. I 'll take her out tomorrow for a run. |
