Marine plywood advice
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Mon Mar 08, 2010 10:24 am    Post subject: Marine plywood advice Reply with quote
So I am planning to buy some marine plywood to make a new seat for my inflatable. I have no idea what to ask for and would appreciate advice as to type, etc. The only kind I have heard of is Okume, as it is used often for boat hulls but IDK if it is the best kind for my application.
Doryman
M/V Lori Ann
Anacortes, WA
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Mon Mar 08, 2010 10:57 am    Post subject: Reply with quote
Warren, I am not sure that you need to invest in marine plywood for something like a seat. Okume, also called gaboon, if I remember correctly is pretty damned expensive, and if it is just a seat... is overkill.
Personally, I would go down to a local lumberyard and pick up some good european or Canadian birch ply. Something with no voids and about 8 layers. It's not that expensive. Cut to size, router radius the edges, sand and stain/varnish...
I have the remains of a sheet in my shop that is destined to be exactly that... a seat for the dinghy...
Steve
Yellowstone
State or Province: MT
C-Dory Model: 22 Classic
Vessel Name: Farwest II
Photos: Farwest III
PostPosted: Mon Mar 08, 2010 12:31 pm    Post subject: Reply with quote
Warren - Steve's advice is sound. I've used marine plywood, including Okume, Douglas fir, and teak buiilding small craft. All are very expensive, especially teak ply. Okume is softer and stains nicely, but Doug fir is stronger but checks. The interior laminations of teak faced ply tend to be very solt. You can get cabinet grade Canadian birch ply in half inch thickness. That has nine laminations with very smooth outside surfaces.
If half inch is not enough structure for your dinghy's span, glue two pieces together. The laminations are glued with water proof glues. Also through trial and error, I have learned to create a teak stained finish on birch plywood. Start with dark walnut penetrating stain brushed or ragged on. Quickly, with clean, dry rags, rub the finish so it is even. Then follow with red oak penetrating stain and rub the finish in the same manner as before. The red oak blends in nicely and it looks like teak. You can experiment with small pieces of ply to arrive at the color you want. Make sure the surfaces are dry before putting any kind of sealer and/or exterior finish. The nice aspect of cabinet grade birch faced ply is that you need not sand the outer surfaces before you apply the final finish.
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Mon Mar 08, 2010 5:23 pm    Post subject: Reply with quote
Just stumbled onto this
Maybe ???
Pete
UncleRichie
City/Region: Bainbridge Is.
Vessel Name: C-Critter
Photos: C-Critter
PostPosted: Mon Mar 08, 2010 9:07 pm    Post subject: Reply with quote
Hi,
How big a piece do you need have some real mahogany from old sail boat ? If I have a piece big enough you can have it.
Richard
PostPosted: Mon Mar 08, 2010 9:32 pm    Post subject: Reply with quote
Maybe ???
I have a seat like that for my Avon 280 Rover inflatable. It has downward tabs on the ends of the seat that fit down into fabric slots or belts that are integrated into the sides of the tanks. You'd have to have the correct inflatable to use it.
Page generation time: 0.0413s (PHP: 52% - SQL: 48%) - SQL queries: 23 - GZIP disabled - Debug on
