In Hull Transducer CD 22?
rogerar
City/Region: SW FL
Vessel Name: Duck
Photos: Duck
PostPosted: Mon Mar 08, 2010 7:28 am    Post subject: In Hull Transducer CD 22? Reply with quote
Has anyone succesfully installed an in hull depth transducer in a CD 22?
Thanks
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Mon Mar 08, 2010 12:15 pm    Post subject: Reply with quote
To install an inhull transducer will require digging out part of the core where the transducer will be installed, and then glassing in material to strengthen the area.
Is there a reason you can't use a transom mount transducer?
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
rogerar
City/Region: SW FL
Vessel Name: Duck
Photos: Duck
PostPosted: Mon Mar 08, 2010 1:40 pm    Post subject: Reply with quote
No reason, I was just hoping to get it inboard, on less thing underwater!
Thanks
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Mon Mar 08, 2010 3:04 pm    Post subject: Reply with quote
I have tried one and it works fine, but haven’t installed yet. My 07 model 22 has the raised cockpit insert, and at the stern where the bilge pump sets is a solid area with no air pockets. When an in-hull transducer is placed in that spot and tested with a couple inches of water it works fine. I had planned on installing it permanently with the intentions of using as a backup when the stern mounted transducer eventually gets torn off; it is currently being held together with epoxy putty. Most likely what will happen is the stern transducer will get ripped off and I’ll be wishing I’d installed the in-hull.
I think C-dorys manufactured prior to the raised cockpit insert have an area at the stern that is un-cored fiberglass, so if you place your transducer there if should work fine.
Boatless for now but looking
Page generation time: 0.0241s (PHP: 59% - SQL: 41%) - SQL queries: 17 - GZIP disabled - Debug on
