dotnmarty
Joined: 03 Nov 2003 Posts: 4209 City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
Posted: Sat Mar 06, 2010 2:54 pm Post subject: Rub Rail |
There is a very small space between the top of the rubrail and the boat. Should I cover this with a bead of clear silicone? If yes, what do you recommend? Thanks. _________________ MartyP
Posted: Sat Mar 06, 2010 10:01 pm Post subject: |
Not a bad idea to run a bead of clear silicone along the top. You can use maksing tape above and on the railing--and use a small hole in the caulking gun you put the silicone down with. _________________ Bob Austin
