twin engine alignment
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Thu Mar 04, 2010 1:28 pm    Post subject: twin engine alignment Reply with quote
Here is an easy question for some of you. The boat I just purchased has twin Honda 35's. I am told by the mechanic that the engines should not be perfectly parallel, front to back, but slightly towed in in the rear. Has anyone else done this? If so, what should the difference in inches or fractions be between the steering bars in the front, center to center, and the prop shafts in the rear, center to center. I am told the distance across the back should be slightly less than across the front. Something about the prop wash and how it meets up on twins.
Chester
City/Region: home
Photos: Chester
PostPosted: Thu Mar 04, 2010 1:44 pm    Post subject: Reply with quote
In my experience the motors need a small amount of toe in.
Our boat came with about 3/8" toe out and keeping a steady course was difficult. I thought it was the no feedback steering system and I hated it.
After a little research I gave the motors 1/4" toe in and the problem was solved.
These measurements were made from nose cone to nose cone and prop shaft to prop shaft.
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Thu Mar 04, 2010 2:45 pm    Post subject: Reply with quote
There are several previous discussions on twin alignment. I think some toe-in is the norm. However, how much is dependent on several things including hull shape, prop depth, horsepower and engine spacing.
Do a Google search for "toe-in," with the site or domain restricted to "c-brats.com"
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
lloyds
PostPosted: Thu Mar 04, 2010 2:47 pm    Post subject: Reply with quote
Thanks, I will give it a try.
lloyds
PostPosted: Thu Mar 04, 2010 5:16 pm    Post subject: Reply with quote
Now that I think about it, what does "toe-in, toe-out" mean? Front of engines closer together than rear, or vice versa? I read all the other links and couldn't come up with the answer.
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Thu Mar 04, 2010 5:45 pm    Post subject: Reply with quote
I noticed that the engines on C-Cakes were not parallel and asked Les at EQ. He told me they were not supposed to be parallel and gave a logical reason (which I have forgotten Embarassed ) so I quit worrying. As to how much off parallel they should be, I don't know. Maybe Larry H. or Marc at Wefings could weigh in.
Patti and Barry
formerly C-Cakes, now
rving around N. America
Chester
City/Region: home
Photos: Chester
PostPosted: Thu Mar 04, 2010 10:16 pm    Post subject: Reply with quote
Put your feet on the floor side by side. If your toes are closer together than your heels think of that as toe in. If your toes are farther apart than your heels call it toe out. If you're built like me your toes are in the front... Rolling Eyes
PostPosted: Thu Mar 04, 2010 11:17 pm    Post subject: do I stand facing the bow Reply with quote
"Put your feet on the floor side by side. If your toes are closer together than your heels think of that as toe in. If your toes are farther apart than your heels call it toe out. If you're built like me your toes are in the front... Rolling Eyes "
Details, WOW Exclamation Now I'll have to go check and see what up with my twins. So when I'm checking if I have "toe in or toe out" do I stand facing the bow or the stern Confused Embarassed
Chester
City/Region: home
Photos: Chester
PostPosted: Thu Mar 04, 2010 11:46 pm    Post subject: Reply with quote
Just like yer cars front wheel toe in, facing foreward. You want the nose cones 1/4" or so closer together than the prop shafts.
EZ to check, EZ to adjust. Well worth your while
lloyds
PostPosted: Fri Mar 05, 2010 11:37 am    Post subject: Reply with quote
Okee Dokee, now I have it. Makes sense. Thanks all.
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Fri Mar 05, 2010 3:41 pm    Post subject: Reply with quote
Even if Milehog's correct it doesn't make sense to me, but will believe him unless someone else proves differently. Seems to me a 4 wheeled vehicle front being towed in keeping it in a more of a straight path would translate to the twin motors being trimmed in at the props also.
I know the Hunkydory steers straight and great so am going to take measurements on it.
Hunkydory
PostPosted: Fri Mar 05, 2010 3:44 pm    Post subject: Reply with quote
Did the measurement and its just as I thought. Props at centers are 22 inches. Nose steering attachments at the center 23 inches.
cbgale
City/Region: Calumet
Vessel Name: Raton
PostPosted: Fri Mar 05, 2010 4:51 pm    Post subject: Reply with quote
That sounds like "toe-out" to me. In the automotive world, toe-in means that the front of the tires are closer than the back of the tires. In a boat, the thrust lines are convergent. There is not an automotive counterpart.
lloyds
PostPosted: Fri Mar 05, 2010 5:00 pm    Post subject: Reply with quote
Yep, I would guess toe-out as well, from what I have read in the thread. Heck, maybe it doesn't even matter. If I can get on the water this weekend I am going to try 1/2" toe-in and check the wakes.
Chester
City/Region: home
Photos: Chester
PostPosted: Fri Mar 05, 2010 5:30 pm    Post subject: Reply with quote
True, I was just trying to paint a picture of what toe in is.
Page generation time: 0.0472s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
