Battery Switch ??
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Sun Feb 28, 2010 2:20 pm    Post subject: Battery Switch ?? Reply with quote
I have a Honda 150, 2 batteries, and a Guest selector switch. The switch has 2 small terminals, that according to Guest wiring diagram, should each have a field wire from the alternator connected. Mine only has one wire - but everything seems to work fine. Should I fix it till it is broke ?
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun Feb 28, 2010 8:56 pm    Post subject: Reply with quote
I thought it depends on the alternator type and might need to use an isolator
Brent Barrett
toyman
PostPosted: Sun Feb 28, 2010 9:21 pm    Post subject: Reply with quote
I don't know - I'll probably not try to "fix it".
Here is my reference:
http://marinco.com/files/support/products/manuals/200956.pdf
BrentB
Photos: BrentB
PostPosted: Sun Feb 28, 2010 9:41 pm    Post subject: Reply with quote
Need to check
I expect the regulator is part of the alternator
PostPosted: Sun Feb 28, 2010 11:08 pm    Post subject: Reply with quote
The battery acts as a buffer for the alternator. If the engine is running and you turn the switch to "OFF" the batteries are disconnected from the alternator output, and somethings gotta give. Removing the field excitation shuts the alternator off so there's nothing to give.
Outboards typically do not bring the alternator excitation (field) lead out so you can't disconnect it. Therefore DO NOT EVER SWITCH THE BATTERY SWITCH TO OFF WHEN THE MOTOR(S) ARE RUNNING.
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Mon Mar 01, 2010 7:08 am    Post subject: battery Reply with quote
Yamaha also suggests not to switch from battery1 to battery 2 while engine is running .Always turn eng. off before switching . Don't ask me how I know .
toyman
PostPosted: Mon Mar 01, 2010 10:21 am    Post subject: Reply with quote
Still don't understand the single wire on my installation. But it is what it is.
jennykatz
City/Region: naples
Photos: Jennykatz
PostPosted: Mon Mar 01, 2010 3:40 pm    Post subject: battery sw Reply with quote
If you can take a picture that would help. My guest switch is wired to two batteries I have one wire coming from engine then two wires leading out to the house battery and starter battery . If you look close you might have the same setup ? Is your Guest switch 1or 2 or both or off then it should or could be wired this way ? PIctures ,Pictures
BrentB
Photos: BrentB
PostPosted: Mon Mar 01, 2010 5:39 pm    Post subject: Reply with quote
I have 2 battery switches and none have the alternator protection feature. I just have a circle using a China wax marker around OFF position to be careful using it when the motor is running.
toyman
PostPosted: Tue Mar 02, 2010 9:13 am    Post subject: Reply with quote
Sorry no pictures - don't know how - AND the job is finished. But mine is wired as shown on the wiring diagram referenced above for single engine, 2 batteries. Except only one wire on the small terminals.
Page generation time: 0.033s (PHP: 58% - SQL: 42%) - SQL queries: 27 - GZIP disabled - Debug on
