leaking shower fittings/CD25
Nan-C
City/Region: Oakland
Vessel Name: Nan-C
Photos: Nan-C
PostPosted: Wed Feb 24, 2010 10:43 pm    Post subject: leaking shower fittings/CD25 Reply with quote
Leaking shower fittings on the 25' seem to be an issue for many people, which is understandable given the mismatch between the British threads on the fixture and the NPT threads on the hose. I know others have done the research that verifies the British threads and I assume others have experienced my frustration in finding an adapter or any way to transition.
I had resigned myself to a temporary cobble and changing out the whole fixture at some point when -- to give credit where credit is due -- Paul at a cool and very oldtime hardware store in Alameda suggested a possible fix that worked. I recut the threads on the fixture with a 3/8" NPT die and, of course, used about three wraps of Teflon tape. I make no guarantees, but my fixture does not leak at all now.
Regards to all,
Greg
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Thu Feb 25, 2010 10:14 am    Post subject: Reply with quote
Pictures please....what kind of DIY Plumber doesn't document?
PS:....Nice Genset stand....very nice.
Mike Taylor
330-936-1030
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Thu Feb 25, 2010 10:40 am    Post subject: Reply with quote
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
toyman
PostPosted: Thu Feb 25, 2010 11:14 am    Post subject: Reply with quote
Weird - I posted a reply, and edited it but nothing is showing - I'm gonna go see if I can see myself in a mirror Shocked
toyman
PostPosted: Thu Feb 25, 2010 11:17 am    Post subject: Reply with quote
damason
City/Region: Valparaiso, Florida
Photos: CHARITY
PostPosted: Thu Feb 25, 2010 11:46 am    Post subject: Leaking shower fittings Reply with quote
I have the same problem with my shower and so far have not been able to use it on my CD-25. It seem like when the people were installing the shower fittings they cross threaded the plastic coupling. I have never been able to make this connection without it leaking. I took the hoses off and plugged them up. At least I do not get water in the floor of the boat. I have tried teflon tape, I have tried using 4200, and I have tried new fittings. I think I will next try buying fittings that fit the hose and will at least screw onto the shower nipples and have somebody weld/braze them together. Thanks for your information.
Marlene and Dave Mason
Once a C-Brat - Always a C-Brat!
toyman
PostPosted: Thu Feb 25, 2010 11:52 am    Post subject: Reply with quote
Well, I've tried - and then tried again. For some reason when I post a link it blanks the page when posted to the forum - looks OK till then.
There are several adapters for BSP to NPT threads, here is one, I'll try by not making it in HTML
http://www.pegasusautoracing.com/productselection.asp?Product=3230
and another specifically for the Sandvik products
http://www.defender.com/product.jsp?path=-1|51|106370|316448|315121&id=1018542
PostPosted: Thu Feb 25, 2010 12:01 pm    Post subject: Reply with quote
Toyman wrote:
A DIY & documenting kinda like government intelligence isn't it ? Very Happy There must be an adapter out there for the BSP to NPT - I don't remember the configuration on the shower - but might this be it ?
(I can't figure out where the above leads-Joe.)
Or Here ?
toyman
PostPosted: Thu Feb 25, 2010 1:14 pm    Post subject: Reply with quote
I still don't understand, but thanks Joe.
If you copy and paste that entire link (first one) into your browser it works - for me any how.
Nan-C
Vessel Name: Nan-C
Photos: Nan-C
PostPosted: Thu Feb 25, 2010 1:26 pm    Post subject: Reply with quote
I apologize for no pictures. I'll try to rectify this soon, but we are away from home -- thank god -- and I not good at the computer stuff even there. Just so you know who you are dealing with, I have done about six major remodeling projects with nary a before picture or a process picture. I always have good intentions, but I have never been a picture taker. But I'll try to get on it.
Thanks for the compliment on the generator plarform. It has worked out well.
Now the leak. I did inadvertantly leave out some details. First, the leak is not due to cross-threading. When you locate this particular shower fixture online, the info makes clear that the threads are 3/8" male British threads. This mismatch between the British threads and the 3/8" male NPT threads on the cold/hot hoses accounts for the leak. The factory tried to solve the problem with tape. Didn't work.
As I said, I recut the male threads on the fixture with a 3/8" NPT die. Be very careful to get the die started straight. I forgot to mention that I tossed the plastic barbed fitting and replaced it with brass. In addition to the thread mismatch, the plastic barbed fitting was a problem because it would prevent full tightening because it would simply hop a thread.
Given the cramped quarters, you also have to be careful to get three or four TIGHT wraps of Teflon tape. If it's not tight enough, the tape just gets pushed up as you tighten the fitting.
I'll check back tonight to see if there are any more questions -- and I'll stop in at Pagano's today to thank Paul for a great fix for a very irritating problem.
Regards to all,
Greg
PostPosted: Thu Feb 25, 2010 1:31 pm    Post subject: Reply with quote
I think it's because it's a pop-up or extending link(?)
Try this one: http://www.defender.com/productsearchresult.jsp
Click on it for a larger, more detailed presentation.
toyman
PostPosted: Thu Feb 25, 2010 1:39 pm    Post subject: Reply with quote
Nope yours didn't work for me.
It is Item #: 990042 at http://www.defender.com
toyman
PostPosted: Thu Feb 25, 2010 4:55 pm    Post subject: Reply with quote
May want to check the galley faucet also - I believe it may be a Scandvik also. C-Dory must have had a Norwegian Owner at one time.
PostPosted: Mon Jul 26, 2010 10:59 am    Post subject: Reply with quote
Anyone know of a source for a replacement "head" for a TC shower? My lever is broken. Valves are fine as is the hose. It is Italian I believe.
Nan-C
Vessel Name: Nan-C
Photos: Nan-C
PostPosted: Mon Jul 26, 2010 11:06 am    Post subject: Reply with quote
Charlie --
You are correct -- it is Italian. Our lever broke a couple of years ago when we were in the Keys. While I was unsuccessfully trying to cobble something together at a hardware store, a clerk sent me to a local boat supply store. When I asked about putting something together, the boat supply clerk asked why I did not just order the exact part. I did not even dream it was an option. He seemed to recognize it and pulled it right up. Came from the wholesaler in a couple of days. I do not remember any details, but like I said, the boat supply store treated it like a no-brainer. I do remember it was ridiculously expensive -- maybe something just under $40 for the head only.
Regards,
Greg
Page generation time: 0.04s (PHP: 74% - SQL: 26%) - SQL queries: 28 - GZIP disabled - Debug on
