Rub Rail
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sat Mar 06, 2010 2:54 pm    Post subject: Rub Rail Reply with quote
There is a very small space between the top of the rubrail and the boat. Should I cover this with a bead of clear silicone? If yes, what do you recommend? Thanks.
MartyP
PostPosted: Sat Mar 06, 2010 10:01 pm    Post subject: Reply with quote
Not a bad idea to run a bead of clear silicone along the top. You can use maksing tape above and on the railing--and use a small hole in the caulking gun you put the silicone down with.
Page generation time: 0.0407s (PHP: 57% - SQL: 43%) - SQL queries: 16 - GZIP disabled - Debug on
