Dreamer
Joined: 01 Jan 2006 Posts: 1766 City/Region: Really Sunny SaddleBrooke
Photos: Dreamer
Posted: Fri Feb 05, 2010 2:47 pm Post subject: Dry bilges? |
I am considering drilling the hulls at their lowest point and installing some bronze drains like these:
I'm searching for a way to keep the bilges drier in the winter. Of course, I'll use the Dr. Bob approved method of epoxying the holes and mounting flange. Does anyone see a problem with this? It worked well on the old ski boats.
_________________ Roger
Dreamer- Sold 25 Feb. 2013 |
matt_unique
Vessel Name: Napoleon
Photos: Napoleon
Posted: Fri Feb 05, 2010 3:17 pm Post subject: Drain |
I don't see a problem with it using the Dr. Bob approved core sealing method.
My personal preference is to avoid drilling through the hull whenever possible though. I just bought a new wet dry vac and the first job will likely be in draining the few inches of anti-freeze in the hull and fish boxes (easier than holding a bucket with the pumps on).
There is the age old risk of forgetting to put the plugs in before you splash. Be careful about putting the plug in too tight (i.e. stress on core sealing). _________________ Captain Matt
Former owner of Napoleon (Tomcat) Hull #65 w/Counter Rotating Suzuki 150's. |
Posted: Fri Feb 05, 2010 3:31 pm Post subject: |
The smaller cat (Caracal 18) which I own, has these plugs. No problems, even though the boat is left in the water all of the time. I would check them occasionally for electrolysis and even take them out and make sure that the threaded part is intact.
I believe it is a good idea to put these in place. I have not done this on my Tom Cat, since it on a lift, and would be difficult to get to the drain plugs. _________________ Bob Austin
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Fri Feb 05, 2010 3:38 pm Post subject: |
Would there be an issue with the drains rubbing on the trailer bunks like on the earlier Tom Cats?
M/V Lori Ann
Anacortes, WA
Grumpy
Joined: 10 Oct 2005 Posts: 1607 City/Region: Whidbey Is
Vessel Name: Kingfisher II
Photos: Kingfisher
Posted: Fri Feb 05, 2010 4:44 pm Post subject: |
Roger,
The RF 245 has one of these. I just check it 1/yr as Dr. Bob suggests.
Never had to open it as we seem to have a dry bilge
Merv _________________ 2006 CD-22 Kingfisher Sold Jan 08.
2008 RF246 Kingfisher II Sold Apr 2013 |
Jeff & Mimi
Vessel Name: Kristen Rose
Photos: Kristen Rose
Posted: Fri Feb 05, 2010 5:57 pm Post subject: Re: Dry bilges? |
Dreamer wrote: | I am considering drilling the hulls at their lowest point and installing some bronze drains like these:
Our 1987 C-Dory 22FT. A has two bronze drain plugs that was installed at the factory when the boat was built, one inside the house right in front of the portapotty and one in the back of the house right under the back door. We have had the boat in salt water every year since she was new and both plugs and flanges today are as good as new. I'M sure they will serve you well  _________________ Jeff, 1987 C-Dory 22FT. Angler The Kristen Rose |
Posted: Fri Feb 05, 2010 6:04 pm Post subject: |
OK, Roger...I'm gonna ask the dumb-ass question of the day. Does the stern [on each hull] not have one installed on Tom Cats like they do on 25s? _________________ "We can go over there...behind the 'little one'....."
Dreamer
Photos: Dreamer
Posted: Fri Feb 05, 2010 6:24 pm Post subject: |
Mark, Nope, there are presently no holes in the hull below the water line. Thanks for the advice guys. This is a great site!
Warren, Shouldn't be a problem as they'll be on the vertical "transom" of each hull. Not on the bottom.
Roger |
Posted: Fri Feb 05, 2010 7:31 pm Post subject: |
Dreamer wrote: | Mark, Nope, there are presently no holes in the hull below the water line. Thanks for the advice guys. This is a great site!
Roger |
Huh....live and learn. |
BrentB
Joined: 15 Jul 2006 Posts: 4420 City/Region: Greenwood
State or Province: IN
Photos: BrentB
Posted: Fri Feb 05, 2010 8:13 pm Post subject: Re: Dry bilges? |
I have one on the Parker and lubed it with some Triple Guard type synthetic grease (blue) It is usually installed but considering removing it during storage and plan on installing a high water alarm in case the bilge pump fails and adding a second pump. Should also be useful if I forget the plug depending on the sensor location. A future project is a total overall with 2 bilge pumps with electronic switches and separate hoses, high water alarm, and pump switches and activity lights at the helm
Walmart has a spare (plastic) garboard plug on a key ring for $3 and I keep it the boat tool bag. _________________ Brent Barrett |
