Forty Two
Joined: 16 Nov 2004 Posts: 114 City/Region: Prince William Sound
C-Dory Year: 2017
Vessel Name: Black Cat
Photos: Barrel O Monkeys
Posted: Fri Jan 15, 2010 8:30 am Post subject: Honda 90s fuel restriction? |
Our TomCat has twin 90s, each with a completely independent fuel system- separate tanks, lines, filters. Often, and becoming more common, when I hit the throttles after idling for a while one or the other of the engines will bog down. Throttles back to idle, I find that the squeeze bulb for that engine is empty. Squeeze the bulb a few times, hit the throttles again and away we go with no problem.
I replaced the fuel lines between the filters and engines with no effect.
What could be causing this? _________________ John & Susan |
matt_unique
Vessel Name: Napoleon
Photos: Napoleon
Posted: Fri Jan 15, 2010 9:05 am Post subject: Vacuum |
My first thought is vacuum pressure...check the fuel vents for proper flow. On another vessel I once had a situation where she would idle fine and when I hit the gas it would stall out. When I finally went to open the fuel tank cap you could hear a rush of air as the pressure equalized. The fuel pump could pull in fuel at idle but not at a higher throttle/vacuum pressure.
I assume you already looked at the fuel filters and fuel water separator?
Maybe it's a problem with the fuel pickup...do you hear any funny noises near the fuel pickup at any time? The antisiphon valves (balls) sometimes get stuck or otherwise act funny.
Good luck - sorry to hear about the engine trouble - but it definitely appears it's a problem getting sufficient fuel or possibly air via vacuum pressure. _________________ Captain Matt
BrentB
State or Province: IN
Photos: BrentB
Posted: Fri Jan 15, 2010 10:52 am Post subject: |
I agree with Matt and add sometimes the primer bulb can degrade but not in your case. The fuel pickup tubes can breakoff, be too short ( does this happen the tanks are low in fuel?) or have a screen at the end of tube which can clog with debris.
Do you have an external fuel filter? ex Racor
Since this has occurred to both engines and I would replace the motor mounted filters and external ones, thinking the common denominator is the fuel _________________ Brent Barrett |
matt_unique
Photos: Napoleon
Posted: Fri Jan 15, 2010 12:21 pm Post subject: Vacuum |
BTW - any easy way to test if you have a vacuum pressure problem is to temporarily remove your fuel tank caps and run it up. If that solves the problem - it's likely a clogged fuel vent. |
BrentB
Photos: BrentB
Posted: Fri Jan 15, 2010 6:57 pm Post subject: |
You can isolate the fuel tank and its components, by taking a 6 gal OB fuel tank and connect it directly to the fuel filter inside the engine.
You would need 2 tanks. |
Forty Two
C-Dory Year: 2017
Posted: Sat Jan 16, 2010 3:49 am Post subject: |
matt_unique and Brent:
Thanks - I appreciate the ideas.
One of the anti-siphon balls stuck closed a couple of years ago, but that prevented any fuel at all getting through.
The fuel vents seem to work properly, but I will loosen and listen to a gas cap next time.
Fuel level seems to have no effect. I have external fuel filters with no water in the bowls. I will replace these before I go out next time - many months from now. Will also replace the anti-siphon balls and the fuel lines from there to the fuel filters.
It has to be something simple, but it happens with both engines at different times. Drives me crazy. |
jennykatz
Vessel Name: Little Treasurer
Photos: Jennykatz
Posted: Sat Jan 16, 2010 8:38 am Post subject: f115 fuel problem |
I had the same problem with my(06) f-115 Yamaha fuel injection engine I traced it down to the ball bearings(anti siphon bearings) in the fuel system .my fuel bulb would collapse and any thing over idle would cause it to bog down .I fixed it by taking out the little anti siphon bearings and replaced the fuel filter every 6 months or as needed also I put in startron fuel cleaner
Now no more problems,good luck _________________ retired 8/08 from UAL, still working pt tm
Almas Only
Vessel Name: Alma's Only
Photos: Alma's Only
Posted: Sun Jan 17, 2010 6:39 am Post subject: |
fishbob:
Need a little more info. Assume your motors are not injected, and that the fuel bulb for the motor that is not acting up feels different than the one you describe????? _________________ 2003 CD22 Cruiser with Honda 90 |
Forty Two
C-Dory Year: 2017
Posted: Tue Jan 19, 2010 12:42 am Post subject: |
Almas Only wrote: | fishbob:
Need a little more info. Assume your motors are not injected, and that the fuel bulb for the motor that is not acting up feels different than the one you describe????? |
2004 Honda 90s are not fuel injected.
The bulb on the motor that acts up does feel different.
So what do you think? |
Almas Only
Photos: Alma's Only
Posted: Tue Jan 19, 2010 11:14 am Post subject: |
fishbob:
If a carb’d motor such as a Honda 90 stalls when the throttle is advanced from idle to mid- or high- rpm settings, it’s usually because the fuel/air mixture, which was already quite lean, has leaned out to the point that you don’t get combustion. In other words, too much air, not enough gas, motor hesitates or stalls. That can happen for several reasons. First, there could be problems at the fuel tank, or elsewhere, that result in the carbs being so fuel starved that they are only capable of delivering enough gas to support an idle. This could result from a vacuum in the fuel tank, partial plug in the fuel line, etc. Next, the fuel could be of such a poor quality, or sufficiently contaminated or degraded, that the effective octane rating is outside that for which the motor was designed. Finally, there might be sufficient quantities of adequate quality fuel delivered to the motor, but not on through the motor’s fuel filter, pumps and carbs.
Since the fuel delivery system begins at the tanks, and ends at the carb throats, it might help to isolate parts of the system, and see if they are a part of the problem.
Some isolation points have already been suggested: once a motor stalls, open the fuel fill cap, and listen for air rushing in. If you don’t hear any air, and the problem doesn’t go away, you’ve already eliminated the fuel tank vent.
The next isolation point I’d suggest is the fuel line quick disconnect at the motor. The next time a motor stalls, assuming you can do so safely, immediately disconnect the quick disconnect, and shut the motor down. Now you’ve got something you can work with, assuming you can safely do so. Since you’re going go be playing with the fuel system, turn off the other motor and shut down electrical appliances, bulge pumps, etc. when you can safely do so.
To check whether you’re getting fuel to the motor, use a plastic or wood tool (not a toothpick) to depress the ball valve in the part of the quick disconnect that’s in the fuel tank side of the line. It’s the one that you’re holding in your hand, not the one that’s built into the motor. I like to use the rounded end of an electrical cable strap, and gently push it slightly into the ball until it stays in place by itself. Gently and slightly are the operative words, since you don’t want to damage the ball, or have trouble removing ALL of the cable strap. The fuel line should be full right up to the connection, so hold it with a rag, above the top of the fuel tank, and pointed away from you before you depress the ball. It’s possible this part of the system is under pressure, so be very careful, because if there’s pressure, the fuel will want to spray. Lower the connection slowly, with the ball depressed, and fuel should run out of the connection. If no fuel comes out, you’ve got a problem somewhere between the tank pickup, and the quick disconnect. If fuel comes out, it’s time to start looking under the motor cover. Go ahead and reconnect the quick disconnect.
Remove the motor cover, and do a little more detective work. The first thing I’d do is inspect the opaque in line fuel filter, and see if it looked full or empty. Next, get a rag and flat bladed screwdriver, and beginning with the top carb, put the rag under the drain at the bottom/side of the float chamber, crack the drain screw in the bottom of the float chamber (it’s the one that’s about ¼ inch diameter on the side of the float chamber, at the very bottom, not the small one higher up) and see what comes out. You should get about ½ of a shotglass of something that smells a lot like gas – don’t stick your nose in it, but get just a slight wiff from a distance. You’ll know if it’s good. You can also catch the fluid in a clear container and look for water, but that’s easier said than done. Then, snug the drain screw back in place, and head on down the line, doing all 4. You should get the same amount of liquid from each, and each batch should look and smell the same. If you have a medical concern with the smell test, don’t do it – just look.
I’d strongly suggest going through this drill on dry land first, so you are familiar with the process, and have the rag, cable strap and screwdriver on hand for later. Just lower the motor into position, pump up the fuel bulb, and have at it. If you test the quick disconnect on dry land, be aware that if you pump it first, the gas will be under pressure, and squirt over everything, including you, if you depress the ball valve. Use extreme caution.
If the quantity of gas removed varied significantly from one carb to the next, you’ve got a float or fuel pump problem, and should consult a mechanic. If the gas was contaminated, buy fresh gas. Otherwise, with the motor cover still off, and the carb drain screws closed, reconnect the fuel supply line, pump up the bulb, and watch and listen to how the fuel flows through the motor’s in-line filter, and on as the carb bowls refill. If this happens smoothly, without your having to wrestle with the bulb each time you press it until the carb bowls are full, you’ve just confirmed that the tank, line, external filters, bulb and in-line motor filters are pretty much working. There might be defects in those parts, but they aren’t causing the problem you’re worried about. At this point, the focus should be on the carbs, and the diaphragm acceleration pump. There’s been a bunch written on the website about these, but since messing with the carbs is costly, whereas the diaphragm pump can be checked out for less than a case of beer, I’d focus on the diaphragm pump.
If you get to this point, and need more help, or want to discuss the diaphragm pump adjustment a little more, just do a post.
Either way, let us know what you find.
Good luck! |
