Impeller service on Suzuki 115 HP
petemos
State or Province: NS
Vessel Name: C-You-Later
Photos: C-You-Later
PostPosted: Sun Jan 10, 2010 4:39 pm    Post subject: Impeller service on Suzuki 115 HP Reply with quote
I have a 2007 Suzuki 115 HP 4 stroke and have never change the Impeller and don't currently have any issues. I only have 35 hours on the motor; it is used in salt water, but has only been in the water for an elapsed 4 weeks in the last 3 years. The other times it sits on my trailer. I was kind of wondering whether anyone had change an Impeller on a Suzuki and whether I’m pushing it never having changed it?
Thanks Jim
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Sun Jan 10, 2010 5:53 pm    Post subject: Reply with quote
It is a easy as falling off a rock...if you have ever changed one in anyother outboard before. But I would suggest you at least invest in a service manual so you are able to get the foot off the boat and back on if nothing else.
And as to the number of hours on your motor. It isn't just hours that count. Impellers don't age well. They become hard and brittle with age and being out of the water. They surcum to abraison form course and abrasive matter sucked thru the water pump as well. Changing your impeller at least every two years wheather it needs it or not will keep you from having to learn to walk on water someday.
Mike Taylor
330-936-1030
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Sun Jan 10, 2010 6:28 pm    Post subject: Reply with quote
I think it's a good idea to change the impellar if for no other reason to insure the bolts don't freeze/corrode in place reinstalling them with antiseize.
marvin
PostPosted: Sun Jan 10, 2010 7:11 pm    Post subject: Reply with quote
Jim-
There are those who will tell you to change the impeller every year, regardless, but a long as the motor's been freshwater rinsed and run only 35 hours, and you've got a strong tell-tale stream, I'd just sit tight, if the impeller, upon removal of the lower unit, looks good.
After all, it's Neoprene.
So what I'd do is take it apart and inspect it, mostly to remove, lubricate, and replace the bolts, which, otherwise, can become "frozen" from corrosion, then reassemble it.
Sorry about the lack of logical order in the above paragraph, but I'm watching the game at the same time!
PostPosted: Sun Jan 10, 2010 7:35 pm    Post subject: Reply with quote
At least it's FINALLY become a game! Wink
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sun Jan 10, 2010 9:38 pm    Post subject: Impellor Reply with quote
This is specifically for the larger Suzuki's but it may help (and could possible be the same).
http://www.c-brats.com/viewtopic.php?t=12563&highlight=impeller
Captain Matt
petemos
Photos: C-You-Later
PostPosted: Sun Jan 10, 2010 10:45 pm    Post subject: Impeller service on Suzuki 115 HP Reply with quote
Thanks Matt. This gives me a good amount of info and with the manual I have should let me get the job done. Really does not seem that hard, but this is my first outboard and with no dealers around i want to make sure i don't mess it up.
Have a good day.
Page generation time: 0.0319s (PHP: 65% - SQL: 35%) - SQL queries: 20 - GZIP disabled - Debug on
