Monitoring House Bank/Charging System
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Wed Dec 30, 2009 6:12 pm    Post subject: Monitoring House Bank/Charging System Reply with quote
Who knows how much accuracy to expect out of a 7 buck item, but I think I'm going to try one of these as a simple monitor of at least the relative condition of the house bank. Too simple to work I suppose.
Chris
http://cgi.ebay.com/ebaymotors/Vector-12-Volt-LCD-Voltage-Meter-VEC008-NEW_W0QQcmdZViewItemQQhashZitem53debb20d6QQitemZ360219091158QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Chris Murphy
Alamo, CA
87 22' Angler 08 Etec 90/07 Johnson 9.9
ramos
City/Region: WASCO
Vessel Name: C-Squirt
Photos: C-Squirt
PostPosted: Wed Dec 30, 2009 6:42 pm    Post subject: Reply with quote
It may well be that it is too simple NOT to work!
Jon Ramos
2009 16C
50 EFI Honda
C-Squirt
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Wed Dec 30, 2009 6:58 pm    Post subject: Reply with quote
Also available at your friendly Wally World, in the auto dept.
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
PostPosted: Wed Dec 30, 2009 7:05 pm    Post subject: Reply with quote
We use one similar to that to monitor our batteries. Works fine. Like Dave mentions, picked it up at Wal-Mart.
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Wed Dec 30, 2009 7:11 pm    Post subject: voltage reg Reply with quote
we bought one last yr our garmin 498 shows 14,4volts and the yamaha gauges show 14.2 the vector shows 13.8 or so . So who knows which one is right ?
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Wed Dec 30, 2009 7:51 pm    Post subject: Reply with quote
I got one from Wally World and it pretty much reads the same as my LMF 200.
marvin
PostPosted: Wed Dec 30, 2009 9:00 pm    Post subject: Reply with quote
jennykatz/jim
All of those meters may be right. It just depends where they are reading. One could be reading at the battery, one at the panel and another the voltage through some gadget that has a high voltage drop because small wire was used. Or they could all be wrong. You can test that by having them all connected at the battery at the same thyme. Remember each circuit has a voltage drop. E still = IR.
I have one of those plug in doohickeys, but they use up a plug of which Journey On only has 2. Why not wire in a cheap meter (say about $5) and save that plug?
jennykatz
City/Region: naples
Photos: Jennykatz
PostPosted: Fri Jan 01, 2010 1:55 pm    Post subject: voltage reg Reply with quote
Boris My 498 gps and my yamaha guages and my plug in are all right next to each other The GPS and Yamaha never coincide? always off my a little the little volt reg shows lower .
I have a 27 series house and a 24 series battery starting battery when i use a voltage gage the batteries usually register about over 12.6-13.8
As long as the gauges are all over 13volts I dont worry to much about it
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Fri Jan 01, 2010 4:33 pm    Post subject: Reply with quote
I wouldn't worry about any of the readings that you guys have posted if I were you as they look just fine. Even 12.6 is ok if you have things running and are trying to charge the battery with your motor. Those inexpensive voltage meters are relatively accurate and give you a general idea if your charging system is charging. And that is why you bought it, not to nitpick over 3 tenths of a volt. Just to illustrate, my expensive after-market guage set for my F-350 diesel with dual alternators shows 13.8-14.2 volts almost all the time and under the hood right at the battery terminals my snap-on voltmeter says 14.2-14.7 volts. It really doesn't matter to me which one is right as both say all is fine.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Fri Jan 01, 2010 5:44 pm    Post subject: Cool Reply with quote
Looks like a great tool. I suspect most of us already have a multi-meter and I take readings right at the bat terminals before engines are running then after they are running to determine the charge.
This would be a handy/easy thing to use rather then getting down on hands and knees of course.
Captain Matt
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Fri Jan 01, 2010 7:08 pm    Post subject: Reply with quote
If you want to go completely overboard, install a Link 1000:
http://www.xantrex.com/web/id/98/p/1/pt/7/product.asp
We had one of these back when we were fulltiming in the motorhome and it was so useful I ended up putting one in C-Dory Naknek.
It shows the state of charge/discharge, rate of charge/discharge in AmpHours, and all sort of nifty stuff. You can actually see the amperage draw of various appliances, lights, etc in real time.
Pretty cool ... really brings out the Geek in ya.
Best,
Casey
Dreamer
Photos: Dreamer
PostPosted: Fri Jan 01, 2010 7:18 pm    Post subject: Reply with quote
Chris, Casey is right, if you really want/need to know what's left in your battery"tank", you would want one of these.
They display amperage being used, amp-hours remaining, voltage and more. May be overkill for the size house banks we're talking about here though.
Look here
Dreamer- Sold 25 Feb. 2013
Socrateur
City/Region: Danville
Vessel Name: Sea Skipper
Photos: Sea Skipper
PostPosted: Fri Jan 01, 2010 7:43 pm    Post subject: Reply with quote
Overkill is good. Here's one that shows voltage to .001:
Over the top, but fun to play with.
Capt Jay
cemiii
City/Region: Alamo
PostPosted: Mon Jan 04, 2010 7:42 pm    Post subject: Reply with quote
So the little Vector plug in volt meter came in the mail today. Didn't want to uncover the boat and all so I plugged it in the F250 06 6.0 diesel. Battery reading was 12.5v. Lit the glow plugs and cranking the meter came down to 9.3v. After starting, the meter raised steadily to 14.4v over several seconds telling me my alternator was working properly. On top of that there are 3 colored LED's, a change in which would alert me to monitor more closely.
Drat! now I have to get another for the boat because this puppy isn't leaving the truck.
Page generation time: 0.048s (PHP: 63% - SQL: 37%) - SQL queries: 31 - GZIP disabled - Debug on
