Transducer
Nunya
Photos: Nunya
PostPosted: Sat Dec 26, 2009 4:35 pm    Post subject: Transducer Reply with quote
I need to replace my old one and wanted to go with a little more wattage. I'm looking at the Airmar TM260. Anyone running one of these?
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Sat Dec 26, 2009 6:19 pm    Post subject: Reply with quote
There is a recent thread on this on thehulltruth (electronics).
Since the OP is in AK, I assume it's not your post.
Chris Murphy
Alamo, CA
87 22' Angler 08 Etec 90/07 Johnson 9.9
PostPosted: Sat Dec 26, 2009 6:47 pm    Post subject: Reply with quote
Airmar makes most of the "factory original" transducers. There are some, like the 260 which may have different characteristics and handle more power.
But to give an intelligent answer, one would need to know the brand and model number of the depth sounder/fishfinder, and what the intended use was. Also what transducer is currently used.
Nunya
Photos: Nunya
PostPosted: Sat Dec 26, 2009 9:20 pm    Post subject: Reply with quote
Thataway,
I'm running a Garmin 4208 with an airmar P66. I believe the P66 is only rated for 500 or 600 watts. I tend to lose bottom in deeper water. The reason to go with a 1000 watt transducer.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sun Dec 27, 2009 11:19 am    Post subject: Depth Reply with quote
I'm running the Airmar p79 In-Hull transducer (600 w) for depth and I keep good bottom lock through about 250' before it will blink. It will find the bottom again and the deepest depths I have crossed have been just shy of 300'.
What type of transducer are you looking for? In-hull, Thru-hull, etc. Are you looking for fish or just depth?
Captain Matt
Page generation time: 0.0295s (PHP: 59% - SQL: 41%) - SQL queries: 18 - GZIP disabled - Debug on
