Removing styrofoam from sides of 16 angler cockpit
mshepherd
City/Region: Bellingham, WA
C-Dory Year: 1994
Vessel Name: Little Fella
PostPosted: Sat Dec 05, 2009 3:14 pm    Post subject: Removing styrofoam from sides of 16 angler cockpit Reply with quote
I just had to tear out the styrofoam from the side of my 16 angler to track down an electrical issue. I was just wondering if anyone leaves this out? I was concerned about strength of the gunnel without the foam in there but it seems like it is good. I would like to put some rod storage a a shelve in there.
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sat Dec 05, 2009 4:49 pm    Post subject: Reply with quote
When manufactured and sold new, the 16 ft C-Dory has to meet the USCG level floatation requirement. This requirement applies to all boats under 20 ft long.
Removal of the foam may defeat the level floatation and also the ability of the boat to remain above the surface if flooded.
Defeating the level floatation requirement could put you and your guests at risk and could void insurance coverage.
Larry H
A C-Brat since Nov 1, 2003
mshepherd
C-Dory Year: 1994
PostPosted: Sat Dec 05, 2009 5:09 pm    Post subject: Reply with quote
Thanks for the tip, I have noticed many mods on this site where people remove the styrofoam to create storage. I am just wondering if anyone thinks that the original design was expecting the foam there for strength or if it is there strictly for floatation.
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sat Dec 05, 2009 7:18 pm    Post subject: Reply with quote
It is strictly for flotation. There is also a block of foam behind the bulkhead up in the bow. The 16 I just bought had the side foam removed on one side when they repowered and replace the control cables. It wasn't replaced.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
PostPosted: Sat Dec 05, 2009 9:56 pm    Post subject: Reply with quote
Is this actually styrofoam? If so it is probably not structural. But many boats do have foam poured or molded in place. Although this is not essential, it will often dampen sound and gives some support. In the 16, I persoanlly would want to be sure that there is adequate foam floatation.
Montana Kev
City/Region: Bozeman/Yellowstone
State or Province: MT
Vessel Name: Grace
Photos: Grace
PostPosted: Sat Dec 05, 2009 11:25 pm    Post subject: Reply with quote
This is sort of related to the styrofoam question. On the 22's there is an open storage bin built into the side walls. Does anyone know where I can get these bins as an aftermarket item to add to a 16?
Kevin
Page generation time: 0.0242s (PHP: 62% - SQL: 38%) - SQL queries: 19 - GZIP disabled - Debug on
