Shaft lengths
landika
City/Region: columbus
State or Province: OH
PostPosted: Mon Nov 23, 2009 2:43 pm    Post subject: Shaft lengths Reply with quote
What is the recommended shaft length for a 22' angler? what if one has a 25" shaft.Any advice on using this motor on a 22' angler?Thanks
PostPosted: Mon Nov 23, 2009 2:58 pm    Post subject: Reply with quote
The 22's take a 20 inch shaft.
A 25 will project down further enough to give you more drag, slowing the boat, and the longer lever arm will try to lift the bow. You will also draw more water, making shallow water operation more difficult.
Noto too much of a problem at displacement speeds, but at planing speeds, particularly higher ones, the boat may behave with a lighter bow, having a greater tendency to porpoise, and turn differently, probably being a bit squirreley. (sp.?)
Would work, I guess, but one would have to be careful.
If you really want to use that motor, try raising the transom 5" by adding to it, with adequate reinforcement.
Good Luck!
landika
PostPosted: Mon Nov 23, 2009 3:15 pm    Post subject: Reply with quote
Thanks, for the info...we thought we would raise the transom. Any pics or ways people have raised the transom? Or in your opinion....the best way??
Thanks
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Mon Nov 23, 2009 3:24 pm    Post subject: Reply with quote
I have a 25" etec on my 22 Angler. I added an adjustible mount aluminum bracket that gives me from 1" to 5" lift. I used every bit of it. (See pics in album "Motor setup" with comments under) Used big aluminum sandwich to build up. No problems yet in almost 2 years. Mount bolts right through the old motor transom holes. Glad to answer any questions I can.
Chris
Chris Murphy
Alamo, CA
87 22' Angler 08 Etec 90/07 Johnson 9.9
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Mon Nov 23, 2009 3:52 pm    Post subject: Reply with quote
We have used this CMC bracket for putting 25" motors on 20" transoms.
http://cook-mfg.net/cart/index.php?main_page=product_info&cPath=10_13&products_id=13
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
cemiii
City/Region: Alamo
PostPosted: Mon Nov 23, 2009 4:30 pm    Post subject: Reply with quote
Matt's suggestion is probably a better mousetrap for this, as when you 'set back ' from the transom you lose some height due to the transom angle (as well as being lighter and probably less expensive).
I wanted to be able to fine tune my height but found that in practice I needed all the lift it gave me.
Chris
landika
PostPosted: Mon Nov 23, 2009 4:49 pm    Post subject: Reply with quote
I tried to find the album "motor set up"....and I could not find it... Disgust any links to it?
landika
PostPosted: Mon Nov 23, 2009 4:50 pm    Post subject: Reply with quote
Thanks Matt for the link..for the bracket!
cemiii
City/Region: Alamo
PostPosted: Mon Nov 23, 2009 6:18 pm    Post subject: Reply with quote
It is a sub album of my photos clickable link at at the left side of page.
Chris
PostPosted: Mon Nov 23, 2009 8:16 pm    Post subject: Reply with quote
Nothing to add other than to say that I'm just thrilled that this topic didn't link to another You-tube video... Wink
landika
PostPosted: Tue Nov 24, 2009 7:54 am    Post subject: Reply with quote
Chris,
Holy crap...yep it is right there! LMAO Xmas LOL ....sorry very new to the site. Rolling Eyes
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Tue Nov 24, 2009 12:45 pm    Post subject: Reply with quote
This is a strong and simple solution .
Marc
Wefings Marine Website
Since 1909
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Tue Nov 24, 2009 7:21 pm    Post subject: Reply with quote
Like Marc I had a jack plate in mind...but, being a bit over the top and control freak and keeping set ups flexible... they make those that are hydraulic too...and can be adjusted without having to take out bolts and stuff...which is real handy if you have differing weight loads too. Thinking of using this application for a 30" shaft on another boat set up which was built for twin 150's....and now that just around the corner some new/improved 200-300s are about to come out with altenators on them.... I may need to be able to move the motor up and down based on sea conditions and boat speeds....particuarly in following seas.
Bunch of jack plates around our neck of the waters.
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
Wefings
Dealer
PostPosted: Wed Nov 25, 2009 9:17 am    Post subject: Reply with quote
The coolest new one from Huntsville [T&H Marine]is the Atlas .
Marc
Page generation time: 0.0594s (PHP: 47% - SQL: 53%) - SQL queries: 27 - GZIP disabled - Debug on
