End grain balsa/16 footer screw holes question.
Cutty Sark
City/Region: Kenmore, Sammamish Slough
Vessel Name: TBD
Photos: Cutty Sark
PostPosted: Tue Nov 17, 2009 10:39 am    Post subject: End grain balsa/16 footer screw holes question. Reply with quote
Does anyone know what year they started using end grain balsa in the floor of the 16's? I read somewhere that originally or for a while they were regular marine plywood. I'm looking at a boat that has a couple of screw holes that were not sealed properly and at least one of them was fairly wet inside. I know the theory with the balsa so it shouldn't have spread too far... anyone have any real life experience with this in say a late 80's angler?
Sark
Robbi
City/Region: Chambers Bay
C-Dory Year: 2023
Photos: C-Run
PostPosted: Tue Nov 17, 2009 8:03 pm    Post subject: Reply with quote
I'm pretty sure the 87 is balsa core with plywood transom.
Robbi
2023 C-Dory 23 Venture Sport
2003 C-Dory 19
sold 2019
2004 C-Dory 16 Cruiser
Sold 8/2015
2004 C-Dory 19 "C-Run"
Sold 8/2011
1989 C-Dory 16 Angler
Sold 2010
Cutty Sark
Vessel Name: TBD
Photos: Cutty Sark
PostPosted: Wed Nov 18, 2009 10:18 am    Post subject: Reply with quote
Wow alot of views but not alot of responses, I have done a search and checked previous threads. I guess my question is for those who have found moisture in the core, and how far did it travel. I have a line on a pretty decent 16 but one of the previous owners put a scuba rack in the middle of the cockpit floor and screwed straight into the hull without sealant, later when it was removed by the current owner the holes were never quite sealed properly. Most of the holes seem fine but one has a fair bit of wet balsa and moisture and I'm trying to determine how far the damage has gone, now I know it should only migrate a couple inches if the balsa is sealed properly, but I don't want to end up with a Thataway style project and repleacing the whole floor. So anyone with experience on this type of repair?
Sark
PostPosted: Thu Nov 19, 2009 11:48 pm    Post subject: Reply with quote
I cannot answer your question about plywood vs balsa, but I don't believe it makes a great deal of difference. If there is moisture in either, it needs to be repaired.
I would either find a person who has a moisture meter or buy one and examine both sides of the bottom with the moisture meter to see how far the moisture extends. The wet core, will read high on the moisture meter. If the area is more than a couple of inches, I would pass on that boat.
RonJr
City/Region: Olympia
Photos: Beagle
PostPosted: Fri Nov 20, 2009 8:21 am    Post subject: Reply with quote
Sark
When I bought Beagle, a 1987 cruiser, about 2 years ago I found the screws from the fuel tanks were loose. I spun an allen wrench in the holes and found wet mush. I started by removing about 1" of fiberglass around each hole, and in the end, cut out about a 2 foot wide section of glass across my entire back deck. I had to remove about an eight inch square of balsa at 3 of the holes and about an 8 x 15 inch section at 1 hole. I also had to remove a section at the forward bilge pump where 1 screw was loose.
I'd be happy to talk to you about it (360) 790-0481.
Ron
Ron & Rose
1987 22 Cruiser - sold 2012
2006 16 Cruiser - sold 2015
Page generation time: 0.0276s (PHP: 58% - SQL: 42%) - SQL queries: 18 - GZIP disabled - Debug on
