Antenna Range Calculator
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Sat Oct 17, 2009 11:20 am    Post subject: Antenna Range Calculator Reply with quote
I stumbled across this interesting calculator which tells you the difference in range between different height antennas. If this is correct there really isn't a lot of difference in range between a 4' and a 8' antenna.
http://www.qsl.net/kd4sai/distance.html
marvin
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sat Oct 17, 2009 2:53 pm    Post subject: Reply with quote
It kinda looks that way....But I gotta tell ya they are wrong.... I have a 4' and Fishtales/C-Halk have a 8' ..... and there is a world of difference in the range.... I am not very impressed in my 4' West Marine pole..
I have gone through several radio's so I am fairly sure it is the pole and not the radio.
Joel
SEA3PO
PostPosted: Sat Oct 17, 2009 5:43 pm    Post subject: physics don't lie. Reply with quote
I am definately not the pro on this but there is a difference between db gain of each antenna. A 6db gain will have better reach than the 3. The higher the antenna is, the more reach you will get. It also make a difference in the connections, coax and route between the antenna and the radio as to interference picked up. There is also a difference in the quality of the manufacturing process. For good two way communication, it is not a good idea to skimp on the antennal. Of course, YMMV but physics don't lie.
PostPosted: Sat Oct 17, 2009 7:30 pm    Post subject: Reply with quote
That is the calculator I use. There are a host of other factors. But VHF is still close to line of sight. The higher dB signal will reach slightly further, but not much, it will be stronger at that limit. But heeling or listing, will decrease the strength of a high gain antenna, since the signal is focused in a horizontal plane. 6 dB is the usual recommended antenna.
The other factors have to do with SWR--if the SWR is elevated, the output of the radio will be reduced, and the antenna will not be as effective. Not all antennas are equal. Many of the Marine VHF antennas, are half wave, some are 5/8, some have base loading, and some have a stub. Some have better quality solder joints (they are basically just a wire inside of the fiberglass tube). I have found some antennas off the shelf with a high SWR, so I take my antenna tester to the store with me when I buy the antenna. My personal opinion is the "Digital" Brand is slightly better than the Shakesphere antennas. In either case buy the best of the lot for the best quality signal. If you want top end consider Comrod--that is used on a number of military and LEO boats.
The connections--including the PL 259 connector are another issue. I still prefer a well soldered connector. There are a number of cases of decreased signal because of the screw on/crimp on PL 259 connectors.
The coax from the radio to the antenna is also important. Most antennas come with a middle of the line coax and it is not worth changing on our small boats with short runs. You can cut the coax, as long as you leave 3 feet between the antenna and radio. Also it is advisable to keep antennas at least 3 feet apart.
Also the voltage to the radio. As I set up my new boat, I am putting a dedicated circuit directly from the battery switch (with fuse/breaker) to the radio. The radios are rated at 13.8 volts. If you have 11 volts (due to corrosion, poor connections, under sized wire, the signal output will be significantly less.
Page generation time: 0.0379s (PHP: 64% - SQL: 36%) - SQL queries: 17 - GZIP disabled - Debug on
