Posted: Tue Oct 06, 2009 2:50 pm Post subject: |
Mike-
I just copied the image "as is" and figured the site would re-size it.
Will try to reduce it somewhat, if I can before the 30 minute "dead zone" sets in!
NORO LIM
Photos: NORO LIM
Posted: Tue Oct 06, 2009 3:11 pm Post subject: |
Papillon wrote: | Hey Joe, . . . was that a prop off of the Queen Mary? |
Man, that thing scared me!
Joe, if you do get it reduced to manageable size, compare the wear areas shown on this shot of just the damaged prop:
I have assumed all along this is a cavitation/ventilation problem, but remain mystified as to the cause in light of:
1. No problem with prior props on either engine;
2. No known changes other than two new props; and
3. No damage on starboard prop.
Bill _________________ Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014 |
oldgrowth
Vessel Name: C-Voyager
Photos: C-Voyager
Posted: Tue Oct 06, 2009 4:19 pm Post subject: |
_______
Dave |
NORO LIM
Photos: NORO LIM
Posted: Tue Oct 06, 2009 4:23 pm Post subject: |
Cool, Dave. Thanks. |
Posted: Tue Oct 06, 2009 9:32 pm Post subject: |
Thanks for the reduction and comparison, Dave!
While the Viking 65 prop and the one in question both show cavitation burn, what's more striking is that the pattern of bubbles on the prop in the video and the one in question are much more alike than the ones in the side by side photos of the C-Dory's prop and the Viking.
I think we've established that we have a cavitation burn problem, but the question is why is it on one prop and not the other?
Is there any reason that the water speed across the port side prop would be any higher than the one on the starboard side? In turns with a right handed prop on the outside of the curve? Downside vs upside movement?
If not, perhaps there is something ahead of the prop causing this?
Time to switch props and test?
Joe. |
Joined: 03 Mar 2005 Posts: 3597 City/Region: Valley Centre
Posted: Tue Oct 06, 2009 10:49 pm Post subject: |
Well, here goes. Joe, your example propeller had paint removed in a broad area near the hub. That looks like cavitation to me. Looking at NORO LIM's propeller, I don't see the same pattern and think it's just bad paint or sand scouring.
Remember what cavitation is: per Bernoulli's principle an increase in the speed of the fluid occurs simultaneously with a decrease in pressure. So as the prop accelerates the water, cavitation occurs when the pressure falls below the water's vapor pressure. As the water then slows down, the collapse of the vapor produces a shock wave, hammers the propeller, removing paint and in some cases bits of metal.
So I think that the larger paintless area in your example is the result of cavitation, since the prop looks eroded, but NORO LIM's is too fine/regular. I think that maybe some sand passed by, or the paint wasn't properly applied.
Just a different view.
Boris |
Posted: Wed Oct 07, 2009 12:48 pm Post subject: |
Boris-
Hi, and good morning to you!
I'm aware of the differences between the Viking prop and the one in question, just couldn't find a photo of a cavitated prop more like the one in from the C-Dory.
The pattern on bill's prop almost exactly matches the bubble formation pattern of the cavitating prop on the video, and is so regular that it doesn't seem to me to be a random pattern of oil left on the prop before painting or of abrasion occurring during usage. One would have to paint the oil droplets on carefully to get that regular of a pattern, I'd think. Wouldn't abrasion also show up on the front surface of the prop, too?
Studying the dynamics of and experiments with cavitation on propellers seems to indicate that patterns like the ones on Bill's props at the aback of the outer edges are the normal to be expected, though patterns differ as to whether the surfaces are polished metal or painted, as well as the specific props used and circumstances.
Joe. |
Posted: Thu Oct 08, 2009 11:35 am Post subject: |
Thanks, Joe. I'll accept that
Boris |
Posted: Thu Oct 08, 2009 12:00 pm Post subject: |
journey on wrote: | Thanks, Joe. I'll accept that
Boris |
Boris-
We could well both be wrong, too!
Hopefully, the prop switch will reveal something!
Nice visiting with you!
've enjoyed reading your posts and travel stories!
Are you coming to the Seattle Boat Show and C-Brat Get Together?
Cheers!
Joe. |
rjmcnabb
Joined: 01 Sep 2007 Posts: 159 City/Region: Pender Island (Southern Gulf Islands)
Vessel Name: Luna
Posted: Thu Oct 08, 2009 12:35 pm Post subject: |
Hi all,
This cavitation business is interesting stuff. On that five-bladed prop, most surface loss is on the leading edge, close to the hub. Does anyone know if that is the area of greatest compression? The tips are clear, but they would exhibit the greatest linear velocity. if velocity alone would exert the greatest compression. I guess that angular acceleration would be the same all along the length of each blade, but the chord varies with position on the blade. I hadn't thought about it before, but I guess the pitch of a prop is the sum total of its whole action, and not that each place on a blade has a constant pitch. I don't even want to think about cupping.
Rod _________________ Rod & Jane; Victoria 18 sloop (Vickie) - gone; Islander 26 Bahama sloop (Callisto) - gone; WW Potter 19 sloop (Spring) - gone; Com-Pac 16 sloop (Bummer II) - gone; Nimble 24 yawl (Chatelaine) - gone; Nimble Vagabond cruiser (Loligo) - gone; C-Dory 22 Cruiser (NoddyBleu) - gone; Com-Pac 19 sloop ('Winkle) - gone; San Juan 24 sloop (Loligo^2) - gone; C-Dory 16 cruiser (Luna); Catalina Capri 18 sloop (Later) |
NORO LIM
Photos: NORO LIM
Posted: Thu Oct 08, 2009 1:48 pm Post subject: |
rjmcnabb wrote: | . . . I don't even want to think about cupping.
That makes at least three of us - you and me, and Chandler Bing after Joey and Ross clued him in about the tailor!
Things do just get curiouser and curiouser, though, don't they. I got the new props in order to boost my WOT RPM a little. They have slightly less pitch, but also lack the cupping that the previous props had. One more thing to put in the mix, but still doesn't seem relevant since the burn is occurring on only one prop.
Next time I feel limber enough to do it, I will swap port and starboard props, and then we'll see what happens.
Bill |
Posted: Thu Oct 08, 2009 8:10 pm Post subject: |
NORO LIM wrote: | rjmcnabb wrote: | . . . I don't even want to think about cupping.
Things do just get curiouser and curiouser, though, don't they. .......
Bill |
OK, but just stay away from the tailor, or at least beyond arm's length from the curious........
Joe. |
NORO LIM
Photos: NORO LIM
Posted: Thu Oct 22, 2009 8:59 pm Post subject: |
The hunt continues. Here is a picture of the seam between the Permatrim and the engine's ventilation plate.
The sealant (I'm guessing 4200 or 5200) has some gaps that allow water through. Could this create enough turbulence to cause the burn?
The port engine (the side with the burned prop) has more gaps, but the starboard side also is not completely sealed.
And Joe, I did check the angle of the engine torque tabs. The two are not the same. The port side is not turned at as great an angle as the starboard side. I'm assuming that with twin engines, the two should be the same. Now, which one is correct? The whole issue of this angle is complicated - depending on several factors as I understand it.
So I now have too many variables to easily assess this by experimentation. But I will persevere, even if it means making more than one adjustment at a time. It's kind of fun.
Bill |
BrentB
State or Province: IN
Photos: BrentB
Posted: Thu Oct 22, 2009 10:06 pm Post subject: |
on flip side
Maybe backed into something on one side only? _________________ Brent Barrett |
tsturm
Joined: 01 Nov 2003 Posts: 1134 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Thu Oct 22, 2009 10:58 pm Post subject: |
Jack in Alaska wrote: | Poor paint job on the port side???? |
X-2? Poor primer under that paint?? |
