Spare Carrier
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Fri Sep 25, 2009 9:37 am    Post subject: Spare Carrier Reply with quote
I'm looking for a carrier for my spare tire/hub & bearings. I'd like one that I could mount a spare spindle on, then mount the rest of the assembly. I have an Aluminum I-beam trailer frame.
Takk !
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Fri Sep 25, 2009 12:06 pm    Post subject: Reply with quote
Look at this site
http://shop.easternmarine.com/index.cfm?fuseaction=catalog.catalog&categoryID=164
Brent Barrett
cemiii
City/Region: Alamo
Photos: The Last One, III
There was plenty of room on my EZ alum to mount my spare horizontally on the yolk behind the post (Trailer Mods 9 of 13). I carry my spare idler hubs separately in my trailer bag because it was so much easier to use the rim holes to fix the tire in place. As you can see there is not a lot of room to "lift" it off a long spindle.
If yours fits, I don't see why you could not mount the tire ,with the hub, so long as you had a (removable) spindle, or large bolt /washer(nyloc) to hold in place to an added cross plate across the bottom of the yolk, set up so it could not rotate.
May be way different on a 25 or your trailer. Just thinking.
Chris
Chris Murphy
Alamo, CA
87 22' Angler 08 Etec 90/07 Johnson 9.9
Reviresco
City/Region: Russellville
State or Province: AR
Vessel Name: Reviresco
PostPosted: Fri Sep 25, 2009 12:34 pm    Post subject: Reply with quote
My McClain Long Haul has the spare complete with bearings on a spindle bolted to a bracket welded to the bow post. Everything I could need is right there Very Happy
http://www.mcclaintrailers.com/mcclain_doc.pdf
Capt Frank M Howell
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sat Sep 26, 2009 2:23 pm    Post subject: Reply with quote
My MajicTilt aluminum trailer also has a complete wheel/tire/hub/bearings mounted on a stub spindle near the winch post.
You may order parts from them to fit on your trailer.
The stub spindle in bolted to the trailer frame. Easy install.
In fact I may move mine forward so I can also move my winch forward so the boat will be better supported at the transom.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Page generation time: 0.0522s (PHP: 46% - SQL: 54%) - SQL queries: 18 - GZIP disabled - Debug on
