Trailer Wheels
J & C
C-Dory Year: 1994
Vessel Name: TBD - previously "Plain D"
PostPosted: Sat Sep 05, 2009 1:02 pm    Post subject: Trailer Wheels Reply with quote
We have launched our C16 Angler twice now and it is barely possible at our local ramp with the Forrester as I"m having to back really far in order to get the boat to start to float off. The trailer has 14 inch rims and tires resulting in a total wheel diameter of 26 inches. They fit "snug" in the fenders. Any reason I couldn't swap into 13 or even 12 inch rims and drop the trailer lower? I have about 6 inches of clearance for the outboard when it is in the down position.
Thanks
Chris
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Sat Sep 05, 2009 1:55 pm    Post subject: 14 in wheels Reply with quote
If your 14 wheels have 5 lugs then you might be able to buy 13in wheels with 5 lugs it should fit . It would be pretty spendy to lose an in or two at the ramp .You might want to add a little more tougue on your trailer that would get the same results . 12in wheels would not be good to small and hard to find replacements when traveling. If you post a picture you might get some better advise Good luck
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Sat Sep 05, 2009 2:41 pm    Post subject: Reply with quote
Those plastic bunk slicks might help you to launch it? Especially on the vehicle end of the bunks. They are the first or second thing down on the link page. Those poly bunk rollers would be another thought.
http://shop.easternmarine.com/index.cfm?fuseaction=catalog.catalog&categoryID=221
Chris
Chris Murphy
Alamo, CA
87 22' Angler 08 Etec 90/07 Johnson 9.9
J & C
C-Dory Year: 1994
PostPosted: Sat Sep 05, 2009 3:09 pm    Post subject: Reply with quote
Thanks for the fast response. I hadn't thought about the glides for the bunks. I can get 13in rims with 5 lugs and tires that will drop me down from 26" to 22" diameter so 2" lower. Add the glides and I should be good to go!
Chris
cemiii
City/Region: Alamo
PostPosted: Sat Sep 05, 2009 3:18 pm    Post subject: Reply with quote
Suggest you might try the glides first. You may be able to save your bigger wheels and a few bucks. The bigger wheels will probably give you a better ride and greater load capacity. If it doesn't work you can always ad on plan B.
Chris
PostPosted: Sat Sep 05, 2009 3:25 pm    Post subject: Reply with quote
You might also take a look at this "Xtend-a-hitch" product. In brief, this is a hitch extension that mounts to the trailer. You tow with the normal coupler on the trailer but when you get near the ramp, you drop the trailer, extend this piece (with a new coupler) and reconnect for the launch. Different extension lengths area available. See the web site for more info.
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sat Sep 05, 2009 3:28 pm    Post subject: Reply with quote
I back in until the trailer fenders are under water. Then I wade in with my rubber boots and push the boat off. It's easy, but it does require a nudge. With your 4wd Forrester you shouldnt have any problem pulling out.
MartyP
Levitation
City/Region: Hemlock
C-Dory Model: R-25 Tug
Vessel Name: CHARLOTTE ANN
PostPosted: Sat Sep 05, 2009 3:29 pm    Post subject: Reply with quote
A hitch extension first, then if you can't quite float it off, add the slick bunks... New wheels and tires are last resort for me...
denny-o
J & C
C-Dory Year: 1994
PostPosted: Sat Sep 05, 2009 4:20 pm    Post subject: Reply with quote
More great advice. Thanks. One reason for choosing the C-Dory was the access to such a great resource here. The extend a hitch looks a little involved and starts at $329. What about one of these: http://shop.easternmarine.com/index.cfm?fuseaction=catalog.prodInfo&productID=6879&categoryID=215. Its the folding hitch - which isn't a feature I need - but it does add 34" and is only $150 plus shipping and looks easier to install.
In order to get the boat just starting to float the stern off the trailer the back end of my Forrester is buried under water - rear wheels, electrical hook-up and exhaust Shocked . The Forrester is fine for pulling it out - I have the 5 speed manual.
Alternatively I could try the "ejection" method I observed yesterday. A 22' Sea Sport launched by backing up and then braking to slide it off the trailer...
Chris
PostPosted: Sat Sep 05, 2009 5:12 pm    Post subject: Reply with quote
The hitting the brakes is a fairly common manuever. There are some down sides, in that you don't have total control over the boat.
There are also "low profile" tires. You might go to an auto tire, but with the C Dory 16, the load is so light that the stiffer side walls may not be an issue. My C Dory 22 came with auto tires on it, and I kept them--worked fine with lots of miles.
If you change the length of the hitch, you make some change in the trailer balance. I suspect that you can make your own, extend a hitch for considerably less than the factory built unit. Also with a boat as light as the C Dory 16, you might be able to use a tongue dolly and hand launch the trailer--use the car to pull it back out.
cemiii
City/Region: Alamo
PostPosted: Sat Sep 05, 2009 6:04 pm    Post subject: Reply with quote
even the most experienced have problems launching some days.
http://www.youtube.com/watch?v=OvAHYR5DnZE
http://www.youtube.com/watch?v=2Cc6koI0fDo&feature=channel
http://www.youtube.com/watch?v=9YLvVP9ZPP4&feature=channel
Chris
jennykatz
City/Region: naples
Photos: Jennykatz
PostPosted: Sat Sep 05, 2009 8:34 pm    Post subject: 16 c-dory power Reply with quote
If you have room in your garage or wherever you keep your boat I would add the one for $150 and be done with it it would give you another 3ft and launching should be good thats what i suggested before just add another 3b4 in galv piece about 3ft will do it
PostPosted: Sat Sep 05, 2009 8:36 pm    Post subject: trailor hitch extension Reply with quote
Adding a trailer hitch extension onto the trailer will work. The extension just slides out from the trailer frame. I had this built on my sailboat trailer for minimal cost and only adds about 2 min or less to the launch time.
SleepyC
J & C
C-Dory Year: 1994
PostPosted: Sun Sep 06, 2009 1:52 am    Post subject: Re: 16 c-dory power Reply with quote
I was initially thinking that a hitch extension would be too expensive/complicated but after further thought and looking at available options the extension using the folding hitch is both cheaper and more effective. Fabricating my own is a little beyond my abilities. A lot of woodworking, epoxy and some fiberglass experience but no metal work. Ordered the folding hitch today and will add it to the many pending boat projects...
Thanks everyone for the advice and insight.
Chris
PostPosted: Sun Sep 06, 2009 2:39 pm    Post subject: Reply with quote
Chris
I've used this "method" a few times @ the Everett boa ramps @ really minus tides with the 25. It has bunks, but they are just carpeted. Works great as long as you're controlled in your reverse speed.
I'd have to agree with some of the above advice. Wheels/tires would be my last resort. Smaller diameter tires=more revolutions=harder working bearings too.
Page generation time: 0.0577s (PHP: 63% - SQL: 37%) - SQL queries: 28 - GZIP disabled - Debug on
